Question about Marantz SR-5200 Receiver
Loud distortion on Front Channels
Hi, my SR5200 has loud distortion on both Left and Right Front channels only, regardless of input selected, regardless of surround mode selected. Volume still increases and decreases but appears about twice as loud as all other channels, degree of distortion increases and decreases with volume. This is the same from the pre outs too (hooked power amp into front pre outs and same result). When volume is set to -infinity, channels are silent. Problem began as soon as amp was powered on (after being off for about 6hours, prior to which it was fine). Have tried 24hour shutdown, no improvement. All other channels work fine in all modes.
Any suggestions would be greatly appreciated.
  • calibre Jun 22, 2008
    Marantz SR 5200 The front right and left speakers suddenly pop, crackle, and static after an hour or so of operation. The problem only exists after using amp for a while. Sometimes after one hour sometimes two never consistent. Restart same problem. Need to shut the amp off for for four or five hours then it works great until it heats up again.
    Took it to the shop and tech said nothing wrong. I purchased a new amp and everything works fine.
    Any suggestions
  • 579 Answers
Well, the nice thing about the newer amps is that the actual amp circuitry is all contained in a module and you don't have to do much troubleshooting. Just replace the module for that pair of channels. Bad news of course is the modules can be pricey. Should say right on it the part number, order it from or whoever, solder it in, use new conductive grease (many times I think these modules fail because the grease gets old, the module overheats and toasts) and you should be fixya'd
Posted on Jan 12, 2008
Ok I have an alpine mrv-m500 when I plug the RCA outputs from my head unit they only work if the inputs go across channels ex; left ch(1) right ch(2) or vice versa. When the RCA inputs are correctly...
what type of radio do you have? next in ur radios menu there mighht be a selection of using and amp or not u might to to adjust ur stereo selections for using amp/rca/wattage/loud.fader you get kinda where im going my kenwood and alpine both have this feature in the menu tab..goodluck
May 18, 2014 | Car Audio & Video
My teac MA-7 amplifier makes a very loud bang (rather a very loud clicking noise) a few seconds after I turn it on, and then every 5 minutes or so. Even with volume all the way down, even with no inputs...
All I can tell you is that if the noise is on both channels the cause of it has to be something that is both channels running to it or is something to do with the power supply. If the main amp channels are outputted by one device I would blame it on that. But if they are separate you will need to look elsewhere.
Jul 30, 2013 | Teac Audio Players & Recorders
Hi i am having problems with my lg home theatre system. The front right speaker will every now and then make a loud distortion noise like static and its annoying. I,ve tried new speaker wire, new contacts...
First make sure all connections are firmly in place. Not only speakers, but any other inputs too.
swop the left and right channels over at the amplifier end. If the sound happens on the other speaker now, you have a faulty av receiver. If it's still on the same speaker, that speaker is "broken" and requires replacing.
Jan 14, 2011 | Audio Players & Recorders
My Harman Kardon AVR 220 reciever's front-right channel isn't working. I have switched the two front speakers and the right speaker works on the left channel so it is not a problem with the speakers or...
if front left is working it is possible u have a dry solder on ur right channel line. try resoldering or if u want to know exactly where dry solder is, shake gently every right channel components and connections. if resoldering does not work it is possible u have a faulty ouput amp for ur right channel. if ur not sure about this i suggest u get it checked by a qualified tech.
Apr 05, 2010 | Harman Kardon AVR 220 5.1 Channels...
Extreme distortion/static in music.
you might have blown your speakers. Thats what it sounds like, if it got loud with a lot of low-end then it got all staticy and distorted, you fried teh speakers.
May 27, 2009 | Phase Linear PLC 400
Need instrutions for this model.
Please hook your dvd player and tv as follows...
Find Yellow color pin as Video Out, Red and White pins for Audio Out (right and left channels) and same goes to rear input-1 or input-2 what ever is available in your TV. watch out color of pins, same color in both units should be hooked up.
Now play dvd player and select input in tv and enjoy.
Still needs help, please mention model and brand of DVD Player and TV to guide you in better way.
Sep 29, 2008 | Televison & Video
I have low volume on two channels of my STR DE975 receiver
I been replied you in chat thread, please check and feel free to ask any question.
Aug 20, 2008 | Sony STR-DE975 Receiver
Technics SU-G91 Left channel bad
Did you ever find the solution to the left channel issue? I have the same problem with mine.
Dec 02, 2007 | Technics SA-AX540 Receiver
Marantz SR5200 - front speakers not working unless direct
If you try and unplug it at least 12 to 24 hours and it does the same thing, then its time to take it in to the shop.
Aug 26, 2006 | Marantz SR-5200 Receiver
Marantz SR-5200 Receiver Logo
465 people viewed this question
Top Marantz Audio Players & Recorders Experts
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
