Click start control panel
administrative tools computer management then select event viewer this may vary
depending on what operating system you have
extend the events there you
will see errors in red you will no what exactly what the error was and at what
time it occured
Right click on the error
message select properties you will see all details about the error
or click start type in
event viewer press
ENTER
this should give you some
sort of understanding of the error and
you
might be able work your way through the problem
You could run the chkdsk disk
utility
Click start run
type cmd then type chkdsk/r/f which will scan for and attempt to
repair any bad sectors and automatically fix any corrupt files on your Hard
Drive.
or an easier way to run the
chkdsk utility
Windows 7 chkdsk
http://www.w7forums.com/use-chkdsk-check-disk-t448.html
Click start control panel administrative tools
computer management ,disk management right click on your drive select
properties click tools click check now click start two boxes
automatically fix files and scan for and attempt
recovery of bad sectors place then a tick in both boxes then select check now,
start should schedule this task when restart
have no input while the chkdsk utility is in progress
any input may further damage your computers Operating System and Hard Drive
http://download.cnet.com/jetclean/3000-18512_4-75627788.html
JetClean tidies your registry,
gets rid of junk files, deletes broken shortcuts, and attempts to give your
computer that like-new feel again.
Optimizers
and Diagnostics.
http://download.cnet.com/360Amigo-System-Speedup-Pro/3000-18512_4-75332741.html
5E3422139C19CBED35C14826A44D4605 also you might need to delete some stubborn files
http://www.malwarebytes.org/fileassassin.php
