Question about Jaton iRok AST503 MP3 Player
Will not turn on after putting music on it will not play without computer
After putting music on after deleting previous files, perhaps i removed a component or something is there a driver i canb use to reinstall it
0 characters
1 Points
Downloading music and removing songs
MP3 players can only play music files in mp3 file format.You can download mp3 music files from the Internet toyour computer and then copy them to your MP3 player.For your CD collection, you need to convert your CDs tomp3 music files onto your computer or download them from the Internet and thencopy them to your MP3 player after you have connected the USB cable tothe MP3 player and the computer.
You can do this using Windows Media player and Rip the CDs - Media Player willcreate a MP3 music file for each music track.Click on this link for instruction on converting musicfiles to mp3 file format :-
Feb 17, 2012 | SanDisk MP3 & Digital Media Players
Missing mp3's in music folder
try using windows media player and sync it, perhaps the ipod is failing to update the playlist. this is most likely the case if you can still locate the files when connected to the computer.
Apr 22, 2010 | Apple iPod nano 3rd Generation
How do I delete files?
The files on your music menu are connected to the folders on your computer. You can't delete the files from your music menu. You have to delete them (or move them) from the folder you took them from.
I suggest that you create a special folder on your computer for only the files you wish to put in coby media manager so that when you get a message like you mentioned you can get the files off your list by moving them back to your normal music folder.
I hope this helps!
Mar 31, 2009 | Coby MP-610 MP3 Player
Computer can't find files on Nextar MA933A, but player works fine
the part you plug the wires into may be dirty and the computer may be unable to read the files. you should clean your mp3 player slots by blowing into it.
Jan 01, 2009 | Nextar MA933A MP3 Player
My philips audio player not working???
The PSS series only recognizes an obsolete DRM-9 license for WMA files. IF the songs were working previously on this mp3 player, make sure your music service subscription is up-to-date - delete every song off of here and then reload them. IF there were never working: You will need to stick to songs that are in true mp3 format if you want to get any use at all out of this player.
-Tha Mp3 Doctor
Dec 27, 2008 | Philips PSS110/17 MP3 Player
Can't delete folders. response is devise not responding
to delete files there are 2 ways to do this.(1) first is with the on and facing you. on top the is the black menu switch. (2)hold down until it reads play music,and release (3) cycle either way until it reads delete.(4) cycle the switch until it reads del / push switch in (5) cycle to voice (6) push switch in to delete files. (cycle to exit and push switch again it should go to your music.
Second way is to plug it into a computer with plug and play.with the Trio MP3 on, the computer should open up a menu, chose open files (2) the screen should have music, voice and other files on the display. chose the voice file and click it open. use the mouse to delete files / or point and use the key board delete key to delete files. IF PLUG and Play does not open up goto MY Computer and openit up. drop down to the removeable disk and click open. you should be where you can delete the voice file. good luck and have fun.
Dec 17, 2008 | Digital Audio TRIO MP3 Player
Problem with My SanDisk Sansa m230
try formatting your device then try to put mp3 files on it. check if it works. on your my computer right click you mp3 device ( it is usually a removable storage) then select format.
Feb 21, 2008 | SanDisk Sansa m230 MP3 Player
MP5 "crashed"
my mp5 was out of sound when i play music my mp5 was buzzing
Jul 02, 2007 | Panasonic SV-MP510 MP3 Player
Music Uploading to Wrong File
change the USB setting in the settings screen
Feb 07, 2007 | SanDisk Sansa e250 MP3 Player
Jaton iRok AST503 MP3 Player Logo
20 people viewed this question
Top Jaton MP3 & Digital Media Players Experts
Gyula Lacz
Are you a Jaton MP3 and Digital Media Player Expert? Answer questions, earn points and help others
