Question about Compaq Presario 5000US (D70008-261) PC Desktop
Case problem?? presario 5000
Hi, Im Brett and I simply cant get the front of the case off to repair the power button....are there any hidden buttons or tabs??
    Genius:
  • 1,601 Answers
    Genius:
  • 1,067 Answers
Inside 4 big screw holding it on take both side panels off look behind it ok
Posted on Jan 12, 2008
Front power-switch wiring for Presario 5000 Desktop
it will depend on the motherboard you purchase. if i were you I would look up the schematics for that motherboard in google search. or tell me what your planing to buy.
Jan 03, 2010 | Compaq Presario 5000 PC Desktop
Can figure out how to remove the cd drive from the actual case
I work at a computer repair shop and I have had a similiar problem with the new compaqs, but the solution is simple. take the side cover off, look in the front of the machine right in the corner where the front bezel and the metal frame meet. There are little plastic tabs on the top and bottom corner. You need to push those tabs either toward you or away from you(depending on model). While those tabs are moved, pull gently on the front bezel. After the bezel is removed, you should be able to remove the drives by taking out the screws and pulling the drives out the front of the case. Hope this helps
Jun 18, 2009 | Compaq Presario 5000 PC Desktop
I have a Microsoft Bluetooth Notebook Mouse 5000 and i need to change the battery. I cant find any latch or button to open the mouse to put new batteries in it! I looked on the MS site and found nothi
There is actually no release button on my 5000. Between the white on-off button and the bluetooth synch button there is a finger notch. If you put your index finger in the notch (pointing toward the base of the mouse you can put your nail under the lip and the batter compartment opens right up. There is a horizontal slot in the battery cover - trying to pry that open does not work. The whole thing is well-cloaked but surprisingly easy when you figure it out!
May 27, 2009 | Microsoft Bluetooth 5000 Mouse
Dead compaq presario 6000
try a different power lead and if doesnt work it sounds like the power supply has blown, had it on a few pc's
Jan 13, 2009 | Compaq Presario 5000 PC Desktop
My computer not powering up
probably that's because of faulty hard disk bus. replace that bus, and your problem will be most probably solved.
This mostly happens when the bus connecting to hard disk are fault or not connected properly. because of this pc fails to load os....
Jan 07, 2009 | Compaq Presario 5000 PC Desktop
Setting up a Compaq Presario 5000 tower and HP pavillion monitor
since your computer didnt recognize your monitor just add it manually ...if its an hp lcd screen hit the button above the power button on the monitor and it will auto adjust itself..if it still dont work go under control panel to monitors and add it.
Sep 01, 2008 | Compaq Presario 5000 PC Desktop
Replace CD-Rom Drive
solution: open front blue magnetic case door, look on either side of the power button, there are finger holes in the other blue cover.
lift out from bottom to top. this cover comes off, not the whole
case. inside find tabs next to cd drive, squeeze and pull out. note: the side sliders were they come out, they will come off the
cd drive when removed. it is easier to replace the top drive by removing the bottom drive, put in the top half way, then put bottom back in half way and slide them in together.
voice of experience. hope this helps
Jan 12, 2008 | Compaq Presario 5000 PC Desktop
Red light flashing on power button (2)
I just tried the link again and it worked fine. Let me walk you through the links I clicked to get there: Goto -> http://www.hp.com/ Click Support & Troubleshooting Enter Presario 5000 in the Select a task and enter a product name/number section and make sure See support and troubleshooting information is checked. Click your model (Any Presario 5000 should do. I chose the Compaq Presario S5000T Desktop PC). Click on Solve a problem. Click on Boot-up / power / port issues. Click on Troubleshooting Power Supply Issues. And there you go.
Sep 26, 2006 | Compaq Presario 5000 PC Desktop
Compaq Presario 5000US (D70008-261) PC Desktop Logo
50 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
