Question about Sony Grand WEGA KDF-55XS955 55" Rear Projection HDTV
Blue screen THE SCREEN WOULD POWER OFF THAN ON . I HAD A PROBLEM WITH THE THERMAL FUSE IN THE PAST SO I REPLACED IT. THIS DIDN'T FIX THE PROBLEN AND I REALIZED IT WAS THE TUBE. THAT WAS REPLACED AND THE SCREEN WAS ON AN ANGLE. I REALIZED I PROBABLY HAD THE OPTICAL BLOCK IN CROOKED SO I FIXED IT. THE SCREEN IS STRAIGHT NOW BUT IT IS BLUE . YOU CAN SEE THE PICTURE THROUGHT THE BLUE HORIZONTAL LINES.
  • Sony Master
  • 8,617 Answers
Sounds like you have something faulty in the blue drive circuit. You can get a service manual and unlimted support to diagnose your set for 10.99 at the following link. If you click on the contact us link and provide your email they will send the service manual and instructions on how to obtain support. Hope this helps. Heres the link.
http://servicemanuals.vstore.ca/
Posted on Jan 15, 2008
Thermal fuse part number
TURN OFF THE POWER NOW!!
25851826-kucbmckx3u3x3wmaw0z02dzb-3-0.jpg Hello. The part numbers are as follows:
42 THERMISTOR 8577274
47 & 48 THERMAL CUT-OFF W/ THERMISTOR-HC STAT 280148(one part number for both thermals in a kit)
51 THERMAL FUSE 3390719
TIP--use a magnetic screwdriver that will take nut-driver bits
You will have to raise the top cover, then, on the right side corner, disconnect the door switch connector. Next, using a headlamp, look inside the unit, back towards the front near the upper left and right corners about 4 inches down on either side. Notice there is a screw on each side. Remove these 2 screws and that will release the front cover. Arc the top of it towards you and lift it off the metal positioning tabs at the bottom and set it aside. Remove the lint screen now. Remove the 3-4 screws that hold the lint duct assembly(metal blower cover) in place. CAREFULLY pull the cover away from the lint screen holder(be *darn* careful that you don't damage the wires connected to the moisture sensor bars on the upper right side of the lint screen holder). Now, carefully look for the thermal fuse attached to the blower housing. It will be the one towards the front, slightly to the left of the exhaust thermistor. It will have a pair of light blue wires attached to it. Note P9-1 BU(blue), thermal fuse, BU(blue). Replace the fuse and reassembly is the reverse--caution--don't forget to re-connect the door switch connector at the right corner--cause "It ain't gonna do a thing" (even if you pray for it to work! LOL)
25851826-kucbmckx3u3x3wmaw0z02dzb-3-1.jpg I hope this helps you!
Sep 05, 2015 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
BLUE SCREEN ON KDF-55XS955
Check the LVDS cable. That is the multi conductor (actually individual little tiny shielded twisted pairs) cable that feeds the video signals to the light engine. It is very easy (don't ask me how I know) to damage the thing when moving the modules around. The cable is a real piece of work and impossible to repair.
The manufacturers have seemingly no consideration for the people that have to work on these things. (let alone the poor owners that shell out big bucks thinking they will last a long time)
Hope Ya Fix It!
Jan 12, 2008 | Sony Grand WEGA KDF-55XS955 55" Rear...
I have a Kenmore Dryer, Model 96292110. It runs, but it does not heat the air. I have checked the circuit breakers. They are fine.
If your Maytag dryer has mysteriously stopped producing heat, a blown thermal fuse may be the cause of your problem. In Whirlpool dryers,thermal fuses are safety switches that are designed to disrupt the flow of electricity to your dryer's heating mechanisms once the dryer reaches a predetermined maximum temperature, usually somewhere around 180 degrees F.
Thankfully, troubleshooting the thermal fuse in a Maytag dryer is easier than it sounds.
Instructions And Things You'll Needed.
  • Screwdriver,Towel,Electrical tape,Replacement thermal fuse, if necessary.
1 Clean out thelint screen in your Maytag clothes dryer. Lint buildup can cause your dryerto overheat, triggering the thermal fuse to disrupt power to your dryer'sheating mechanisms. Take the lint screen out of your Whirlpool dryer and washit in warm water. Dry the screen thoroughly before replacing it.
2 Look behindthe dryer to check its flexible exhaust hose for kinks or obstructions.Disconnect the exhaust hose from the back of your dryer and clean out any lintthat has built up.
3 Go outside andcheck your Maytag dryer's exhaust vent for obstructions. Lint buildup, birdnests or other obstructions in the outside exhaust vent can trigger yourdryer's thermal fuse.
4 Disconnectyour dryer from its power source before attempting to access its thermal fuse.
5 Access the thermal fuse in your Maytag dryer byremoving the back panel. Remove the screws that hold the back panel in placeand it should easily come free.
6 Look betweenthe dryer's blower housing and exhaust to locate its thermal fuse. The thermalfuse in a Whirlpool dryer looks like a white plastic strip that has two wiresconnected to it.
7 Bypass the thermal fuse in your Maytag dryer whileyou perform a quick diagnostic test. Use electrical tape to tape together thetwo wires connected to the thermal fuse. Reassemble your dryer and plug it backin. Set the dryer to a timed heated drying cycle and press "Start."If the dryer produces heat with its thermal fuse bypassed, it means the thermalfuse needs to be replaced.
8 Replace a blown thermal fuse in your Maytag dryer.Disconnect the power and remove the back panel. Remove the electrical tape thatyou used to perform the diagnostic test and disconnect the wires from thethermal fuse. Remove the screws that secure the thermal fuse to the dryer anddiscard the blown fuse. Attach the replacement thermal fuse by replacing andtightening the screws. Attach the wires to the new thermal fuse.
Thanks for using fixya.
Jul 31, 2011 | Kenmore Dryers
Whirlpool AWZ7303 condensing tumble dryer . Drum not turning although it is heating
If your Whirlpool dryer has mysteriously stopped producing heat, a blown thermal fuse may be the cause of your problem. In Whirlpool dryers, thermal fuses are safety switches that are designed to disrupt the flow of electricity to your dryer's heating mechanisms once the dryer reaches a predetermined maximum temperature, usually somewhere around 180 degrees F. Thankfully, troubleshooting the thermal fuse in a Whirlpool dryer is easier than it sounds. Instructions:
  • Clean out the lint screen in your Whirlpool clothes dryer. Lint buildup can cause your dryer to overheat, triggering the thermal fuse to disrupt power to your dryer's heating mechanisms. Take the lint screen out of your Whirlpool dryer and wash it in warm water. Dry the screen thoroughly before replacing it.
  • Look behind the dryer to check its flexible exhaust hose for kinks or obstructions. Disconnect the exhaust hose from the back of your dryer and clean out any lint that has built up.
  • Go outside and check your Whirlpool dryer's exhaust vent for obstructions. Lint buildup, bird nests or other obstructions in the outside exhaust vent can trigger your dryer's thermal fuse.
  • Disconnect your dryer from its power source before attempting to access its thermal fuse.
  • Access the thermal fuse in your Whirlpool dryer by removing the back panel. Remove the screws that hold the back panel in place and it should easily come free.
  • Look between the dryer's blower housing and exhaust to locate its thermal fuse. The thermal fuse in a Whirlpool dryer looks like a white plastic strip that has two wires connected to it.
  • Bypass the thermal fuse in your Whirlpool dryer while you perform a quick diagnostic test. Use electrical tape to tape together the two wires connected to the thermal fuse. Reassemble your dryer and plug it back in. Set the dryer to a timed heated drying cycle and press "Start." If the dryer produces heat with its thermal fuse bypassed, it means the thermal fuse needs to be replaced.
  • Replace a blown thermal fuse in your Whirlpool dryer. Disconnect the power and remove the back panel. Remove the electrical tape that you used to perform the diagnostic test and disconnect the wires from the thermal fuse. Remove the screws that secure the thermal fuse to the dryer and discard the blown fuse. Attach the replacement thermal fuse by replacing and tightening the screws. Attach the wires to the new thermal fuse.
  • Apr 20, 2011 | Whirlpool AWZ7303 Electric Dryer
    The dryer will not start. I replaced the on/off switch thinking that was the problem. The dryer is still dead. An old dryer I have works fine, so the problem is not electrical from the circuit breaker....
    Replace the thermal fuse . If the lint screen is on top of the dryer , remove the back dryer panel and look for a 1 " long white piece with 2 wires going to it . Disconnect the power cord from the wall , and connect these 2 wires togather . Then plug the dryer back in and press start . If the dryer starts , replace this thermal fuse .
    If the lint screen is by the dryer door , remove the front panel and the lint screen and the lint screen holder ( 2 screws ) and behind the holder , you will see this white piece . Replace it ( cant turn the dryer on without the front unless you disconnect the belt to test .
    Always disconnect the power when working with electrical appliances .
    ALSO , if you can use an ohm meter , you can check for an open thermal fuse , which would be the easiest way .
    Aug 05, 2010 | Whirlpool Dryers
    What start
    check thermal fuse it is located n the back or on the inside behind the lint screen its usually white plastic and is round or oblong you can check it by jumping it out .if that is the problen you need to clean out the lint trap and hose dont forget to clean the port outside the house,after the fuse is replaced otherwise it will overheat and pop the new fuse
    Mar 20, 2010 | Amana DLE330RAW Electric Dryer
    My screen stays black but my pc is on
    it sounds like your mointer is ****, i highly doubt the game caused it. try another mointer, or sell that one on ebay and buy a new one
    Jun 14, 2009 | HP Computers & Internet
    Olevia T.V problen
    Try selecting a different input, or checking the device which you are receiving the signal from. A blue screen typically indicates that there is no signal.
    Mar 16, 2008 | Olevia LT37HVS 37 in. LCD HDTV
    Screen goes black, 5 blinking red lights, screen back on for 20 seconds....cycle continues
    Let me first say that if you are getting 5 blinks its not the thermal fuse. Your problem is your Lamp. You have what we call an intermittent Lamp. The only way to fix this is to replace the lamp. Part Number A-1085-337-A. Average cost $217.00
    Circuitcity
    Dec 09, 2007 | Sony KDF-E55A20 55 in. LCD Television
    PXE Rom
    In replaceing the h/d, did u forget a screw that holds something down.?, sometimes metel to metel acts like a heat sink to get rid of  harmful heat. If u started getting "blue screen" of death after h/d replacement. look for anything loose on mother board .Check connections to cpu\fan\heat sink.
    Oct 11, 2007 | HP Pavilion ze2000 Notebook
    Sony Grand WEGA KDF-55XS955 55" Rear Projection HDTV Logo
    54 people viewed this question
    Top Sony Televison & Video Experts
    Jerry Greenberg
    Jerry Greenberg
    Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
