Okay I have gateway gt5404 and when I want it to turn on so
etimes it beep 3 times and says no RGB and sometimes it doesn't beep so tell what to do please
In order to connect your laptop to your TV using RGB, you need an RGB adapter. RGB is also known as component video; it breaks up a video signal into red, green and blue. laptops do not have RGB outputs. However, many laptops have VGA, DVI or HDMI outputs. An RGB adapter connects the single VGA, DVI, or HDMI cable to an RGB cable, which is actually three different cables tied together.
INSTRUCTIONS:
1. Connect either the VGA, DVI or HDMI (in the order of increasing video quality) cable to the VGA, DVI or HDMI port on your laptop, depending on what is available.
2. Connect the other end of the cable to the side of the RGB adapter with the single input.
3. Connect the RGB cables to the red, green and blue ports on the other side of the RGB adapter.
4. Connect the other end of the RGB cables to an available component input on the back of the TV.
5. Tune the TV to the component video input you used through your television's menu.
6. Turn on your laptop. The laptop should now display on your TV screen.
Neichi could this monitor be set to receive dvi signals and not rgb even if he has the rgb hooked into the monitor? so in menu select rgb input?
Mitch, monitors don't conflict with windows generally usually they(windows os) will install a basic generic driver to run the monitor, and you should do this when changing monitors before you hook up the new one, your description really lacks any concrete description where are the "black and blue errors" what do they look like last I have had problems with modems interfering with video so I would remove the modem and see if the problem goes away.
