My computer that is connected to the internet through my linksys befsx41 router which goes to a dell running vista. the second computer which i can't get connected is a gateway running on xp. It's driving me crazy i can't get it to connect i've tried reseting ip adresses also set to auto detect with no results. Also i can't reset my router i've tried reseting it it still will not connect me to the routers setup page. Can someone help??????
Comments:
Jan 12, 2008
- yes the dell on vista works fine and all lights are on. the light is also on for the gateway for xp
Is the Dell/Vista PC connecting to the Internet okay?? Does a link light come on...on the router...when you plug in the network cable from the Gateway?
Same Problem
Mar 30, 2008
-   have a gateway 2 wire has a dell window 98 dsl connected I want to connect a compac window xp via linkskey 802.119. All test indicate that hardware is in place even get the screen. Have populated linskey data to no avail. Will not connect automatically.-   Guest
I have listed several things here that you can use to find the problem. Sorry this is so long...network problems can be very tedious to find.
First check your version of Windows: Double click on "My Computer", then click on "View System Information" to make sure you have at least Service Pack 1...or better yet....Service Pack 2.
Next check your Windows XP network settings: Click on Start....Control Panel....Network Connections...Local Area Connection...Properties(button). Scroll down the list to find Internet Protocol(TCP/IP) and click on it to highlight it. Now click the properties button below the list. You should now be able to click the small buttons to select both of the "Obtain....automatically" choices for IP address and DNS server. Click on "OK" to close each of the windows.
Now you can test your computer to see if it is "talking" to the router: Click on Start...Run...and type "cmd" in the small box and click "OK". This will open a black command window where you tell the computer what to do. Type the command "ipconfig" and press return (enter). This will list your ip address, subnet mask, and default gateway. Make a note of the default gateway address so you can use it for the next test. If the IP address begins with 192.168...then your computer is probably communicating with the router okay. If your IP address is blank or starts with 169...then your network connection to the router may NOT be working.
The final test!!! Use the default gateway address from the last step to do a "ping" test. In the black command window...type "ping" followed by the default gateway address. For example: IF the default gateway happens to be 192.168.1.1....then type the ping command this way: ping 192.168.1.1
If the result is a list of replies from the gateway address...great!! Your network connection is working. If the ping command results in a list of "request timed out", or something else, then your network connection needs more help.
The ultimate test is to try using the Internet with your browser. If this works, next try typing your gateway address into the brower address bar. It should connect you to the router setup page.(?)
Let me know the results of each of these tests, and I'll be happy to assist you further, if needed.
My BT home hub will not recognise the ethernet connected hard drive connected to the router, how do...
(More)
My BT home hub will not recognise the ethernet connected hard drive connected to the router, how do i get it to be recognised. It works when conneceted in usb mode to the p.c. but does not work when connected via LAN to the p.c ? can you help pls.
It will not connect to internet. The ip address is not changing automatically even though I have...
(More)
It will not connect to internet. The ip address is not changing automatically even though I have checked to assign automatically.
will d-link airplus xtreme G+ work on windows 7? I have installed from CD under win 7 but Dell...
(More)
will d-link airplus xtreme G+ work on windows 7? I have installed from CD under win 7 but Dell Dimension cannot see it.
