Question about KLH R5100 Receiver
Can get either 1 or 2 speakers working at the same time.
I hook all 5 small speakers up properly with the sub. When I change theaters and such to get all 5 speakers working with the sub, I can only get either the center speaker with the sub, or just the front left and right speakers with the sub to work. When I run a test I get sound from all speakers individually. What's going on? The manual has no such help with this problem.
Many Thanks!
Jim
  • 2 more comments
  • Anonymous Feb 28, 2008
    I have a similar problem. When I hook up all five speakers, I can only get the left and right to work in stereo mode on analog. When I try to go to DVD/COA the left and right icons simply blink with no sound whatsoever. When I run it in test mode, I get no sound from any speakers. Is there a problem with my coax hook-up? What do I have to do to make the 5.1 channels work?
    Jeff Giles
    jgiles872@yahoo.com
  • Anonymous Oct 18, 2008
    i can only get two speakers to work
  • 80oldsblueba Oct 18, 2008
    cant get all my speakers to
  • kstfrk Jan 11, 2009
    All 5 speakers work when i'm using a dvd player or a gaming system but when i try to run the tv through it, i only get sound from the center and the sub on surround mode but on stereo the left and right work with the sub. I've tried about everything i can think of and have never had any problems until now so i'm guessing it has to be the receiver but i tried different inputs on that and it still didn't work. I've tried hooking it up to a different tv to see if it was the audio outputs and it didn't work on the other tv either. I've tried different cables and still nothing. I'm all out of ideas...
JimRod80,
You say you change theaters which is different than what I propose. Have you tried the "SURR MODE" button on the front or on the remote? the only mode I use is prologic. it has all speakers in surround and doesn't sound like you are in a cave.
Posted on Jan 11, 2009
    Problem Solver:
  • 4 Answers
U can't do use a 5 with a cox only with fiberoptic than it will work
Posted on Feb 12, 2008
I have a klh home theater speakers with a subwoofer the sub work but when i hook up speakers no sound comes out?
The sub works but the speakers don't? Do you hook up the speakers to the subwoofer output "loop"? This is a circuit issue when it works and stops working. I have the same issue so I wound up joining the wires that go to the sub and the wires that go to the speaker together and place those connections into the sub. The sub works, the satellite speaker works and the impedance load is no issue for my system. Confused? Simply run your neg/pos wire to the sub and where it connects to the sub, run another cable to the speaker (pos to pos., neg to neg).
The only way to repair it would be to deal with component level repair. Although I have the experience, it is too petty and it works fine the way it is.
Apr 12, 2011 | KLH ASW10-120 Subwoofer
I just bought the coby csp96 surround sound package and am having trouble hooking everything up. It came with the dvd player to hook all the input cords to, which i did. Everything is working accept when i...
there is a nobb on the subwoofer, one is to dial down or up the sub (noob1) , and the other is to dial up or down the 5.1 speark (noob 2). turn noob 2 to the left to dial down the sound, first time i got my setup it was totally down, btw the 5.1 works wonderous if you use a home theater system. Iam using a 1,000watt sony home theater system. 100/200watt RMS per channel at 5 channel those little speakers really can handle well, I never experiance any blow outs :) Coby outdid themselfs with this system
Sep 05, 2010 | Coby CSP-94 Speaker
Subwoofer turns on and is hooked up, but no sound.
The signal don't seems to be present to the sub input.
Try change the wire betwen the audio system and the subwoofer.
Spider Guy
Mar 15, 2010 | Onkyo 630-Watt 7.1 Channel Home Theater...
How do I hook up a non powered sub woofer on my htr-5630?
You will need an amplifier or 2 channel receiver. Hook the sub out rca jack to the rca inputs on this new amp or receiver and hook the speaker terminals on sub to speaker terminals on same amp or receiver. Your Yamaha receiver doesn't have any power for a passive sub.Just pick up any old fairly high powered receiver for fifty dollars and you're good to go.I use old dolby pro logic receivers as they are a dime a dozen today. Good luck.
Feb 20, 2010 | Yamaha HTR-5630 Receiver
Center and wireless speakers not working
are you tryng to get digital surround ? you can only get left and right audio or virtual surround sound if there is no optical or coax digital audio input connected from the sources digital output for that selection
Mar 06, 2009 | Panasonic 1000W 5.1-Channel Home Theater...
Cannot get the surround to work correctly gpx dvd home theater
Check your setting it may be set to 2.1 or stereo. As for hooking up the tv check for aux or tv audio inputs on the dvd player and attach to the audio outs on the tv. You may need to change the settings on the tv, go to the audio menu on the tv and change from variable to fixed.
Jan 12, 2009 | GPX HTD2204 System
Can't get the surround sound to play the rear speakers and small front speaker
Sounds like it's just in 2 channel stereo mode, only 2 speakers working out of 5 and a sub, look for a selector switch for switching to 5.1 surround, as far as the no video problem try replacing the cable for the video connection.
Aug 04, 2008 | Panasonic Home Theater System System
Subwoofer volume and sound
i had the same problem when i tried to adjust speaker output levels, distance and equalizer manually without using audessy setup..so i reset everything to factory setting (0s)..and then ran
audessy setup..reduce volume on your subwoofer to slightly above minimum(behind the subwoofer) before running the setup..once audessy setup is completed successfully..i started changing setup
manually..changed speaker config for front speaker to small (it is set as large by audessy setup), this should automatically adjust center and other speaker configuration (if not make sure to set them to small as well), then set the cross over frequency to 120..increase the volume on your subwoofer and now you should hear it fire..if this does not help..try playing some rock music with all channel streo mode..if your subwoofer does not fire even for this..then take the system back for exchange..
Dec 28, 2007 | Onkyo HT-SR800 System
KLH R5100 Receiver Logo
263 people viewed this question
Top KLH Audio Players & Recorders Experts
 Grubhead
Grubhead
Sam Palermo
Sam Palermo
Are you a KLH Audio Player and Recorder Expert? Answer questions, earn points and help others
