Question about Western Digital Caviar SE WD1600AAJS 160 GB SATA Hard Drive
Installing new hard drive
I just install a WD 160 hard drive. When I turn on the computer there is a black screen with a message Command or filename not recognized x:\> What do I put here? It's a Dell Computer with Windows ME with a XP upgrade.
  • 871 Answers
its brand new right? have it reformatted for the first time. you can do this by installing an OS and it prompts you to reformat it. actually, there are other ways to do that but for me, this is the most secure way to reformat a new harddrive in your situation.
hope this helps.
Posted on Jan 21, 2008
6ya staff
SOURCE:
Installing Windows 7 from a flash drive. " $WIN_NT$.BT\biosinfo.inf could not be loaded. The error code is 14 ". Pretty sure it's not an error on the flash drive seeing as how I have used it succe
Click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured
or click start type in event viewer press ENTER
you might be able work your way through the problem.
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
If done properly the user should get to a screen similar to the below screen.
Select the option for Safe mode command prompt only
Windows Advanced Options Menu
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice.
select safe mode with command prompt then type in chkdsk/f/r which will scan for and and attempt repair of bad files and bad sectors on hard drive
you should have no input while chkdsk utility is in progress any input might further damage your computer or
Use the System File Checker tool (SFC.exe) to determine which file is causing the issue and then replace the file.
Type the following command and then press ENTER: sfc /scannow The sfc /scannow command scans all protected system files and replaces incorrect versions with correct Microsoft versions.
Hope this helps.
Nov 17, 2012 | Dell Computers & Internet
Black screen with cursor
Windows is corrupted or the hard drive has issues. If you have a backup cd recovery disc try it now, if that fails have the hardware tested for possible replacement.
Jul 27, 2012 | Toshiba Satellite L500 Series Notebook
Computer problems
make sure the boot order is starting from your hard drive the directions on how to change your boot order usually vary depending on what version of bios you have but they are usually self explanatory.
During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key
this will vary depending on your computer and operating system
Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
this changes the boot order and see if that solves your problem if not you will need to replace your modem I do hear that a modem can also cause this.
hope this helps
Jul 19, 2012 | eMachines T5224 PC Desktop
I have samsusng rv511, and it appeared operating system not found, i checked bios and it didnt list my hard drive so i bought new ssd ocz hard drive, i tried to install OS but it didnt supported. It keeps...
Did you replace a SSD (Solid State Drive) with a SSD Drive? You have to replace the drive with the same type of interface that it had.
It sounds to me like there is a setting in your bios that needs to be set. Check for something like AHCI and see if it is set on something like SATA. If so change it.
I think your old drive is ok. Most times when the drive is bad the system will tell you and it's not the message that it can't find the operating system. Put you old drive back in and lets see if we can work through this.
Make sure when you boot that it is booting from your hard drive and not from a lan or from a music cd or movie video that is in the cd/dvd drive. There should be nothing in the cd/dvd drive when you boot. Watch the screen and see which key it says to press to change your boot order or boot sequence and hit that key. You have to hit that key when you see the message or it will not work and you will have to reboot. Select your hard drive as the boot device and lets see what happens. If you still get the Operating System Not Found message lets try to run the check disk utility.
To run the check disk utility you will need a repair disc or a operating system disc. Put the disc in the cd drive and boot from it. You want to get to the Dos Command Prompt (Black screen with white letters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice the percentages going from high to low, this is normal. Let it run to completion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows. Try doing a Repair Install that way you don't loose your data, documents, music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair when the options appear.
In Vista and Windows 7 you want to get to the recovery console and look down at the bottom of the window for the Dos Command.
Jun 03, 2012 | Computers & Internet
When I press F8 key and it's not giving a option to restore my computer
No bootable device means the system cannot boot from where ever you are trying to boot. If you have something in the CD Drive other than a Repair Disc or Operating System Disc remove it.
Try booting from your hard drive. Turn off the computer then turn it back on and watch the screen for which key it says to hit to Change the Boot Sequence or Boot Order. Hit that key when you see the message or you will have to start over. Select the Hard Drive as your boot device. If you get a message about an unbootable device then you will need to run the Check Disk Utility. If it boots, then you will need to make a permanent change to the Boot Sequence or Boot Order.
To make a permanent change turn the computer off, then turn it back on and watch the screen for which key it says to hit to get into the Bios or System Setup. When you see the message, hit the key otherwise you will have to reboot and start over. When the Bios or System Setup window opens tab over and Change the Boot Order or Boot Sequence and save your changes.
May 27, 2012 | Dell Computers & Internet
If hard drive is not detected will i loose all my pic and files?
That's not a hard drive is not detected message. That messages is simply saying that there are missing or corrupt boot or system files. Yes your files and pictures are still there. In fact if you took the drive out and slaved it on another system you will be able to see the Windows directory and get to you files.
First and foremost make sure it is trying to boot from the hard drive and not from some Music CD that you have in the DvD/CD drive. This will cause a no bootable device error message. So if you have something in the cd drive remove it and let it boot from the hard drive. If you still have the problem try the steps below.
To fix this the best thing to do is run the check disk utility.
To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.If the check disk utility does not solve the problem, then you will need a Windows Operating System (the same as your operating system). The D600 for the most part has Windows XP and it came with a reinstall disk. Just put the disk in the cd drive and boot from it. When The windows instruction screen comes up you want to INSTALL WINDOWS, (don't select the option to Repair). After you select the option to install windows the next screen will ask you to hit F8 to agree to the license. Press F8 and the system will go out and look to see if windows is already installed on your system. It will find the windows installation and it is at this time that you select to REPAIR the installation. This will ensure that your documents, data, music, pictures, videos and programs are not deleted.
May 02, 2012 | Dell Latitude D600 Intel Pentium M 1.3GHz...
When the computer boots, it display bluescreen
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.If after running the Check Disk Utility you still have problems you will probably need to reinstall windows. Look into doing a Repair Install so that you don't lose your data.
Apr 24, 2012 | HEWLETT-PACKARD 630 Notebook
Acer aspire 5000 laptop. black screen says NTLDR missing, press any key to restart..but it will not do anything just stays on the black screen with the message
try repairing the OS with the installation disk. if this doesn't work, try formatting the hard-drive, but remember to connect the hard-drive to another computer and backup your important files. this is the simplest way to solve it, as trying to restore the system manually requires lots of command lines and a system boot disk.
Feb 06, 2010 | Acer Computers & Internet
Want to install new WD hard drive into my old computer
You say you see data on disks on your existing system, yet they appear blank when trying to install? Please try to dig a little deeper and find your setup file. Data wouldn't disappear unless your running NTFS now and the disks are FAT.
Jun 23, 2009 | Sony VAIO PCV-RX450DS PC Desktop
Open Questions:
See all Western Digital Caviar SE WD1600AAJS 160 GB SATA Questions
Western Digital Caviar  SE WD1600AAJS 160 GB SATA Hard Drive Logo
106 people viewed this question
Top Western Digital Computers & Internet Experts
Ekse
Alun Cox
Marvin
Marvin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
