Question about RCA P52937 52" Rear Projection Television
RCA R52WH74 We have an RCA R52WH74, and the unit doesn't want to turn on, it's giving us 1 LED blink then 9 Blink code. I'll apreciate if any one can help me with this problem. Thank you...
  • Anonymous Aug 26, 2008
    TV will
  • James Carr
    James Carr Dec 20, 2008
    I am having the same problem. It was purchased about a year ago so it is not very old. I turned it off last night and went to turn it on this morning and the on button blinked 9 times but never turned on. I unplugged it to do the reset but that did not work either.
    I have tried everything but a local tv tech or RCA tech support. I searched the web but have only found problems but no solutions..
    I hope someone can find out what this is and fix it.
    Problem Solver:
  • 15 Answers
I took the boards out of the case and checked the capacitors and on was bad so i had my wife ( a certified solder tech) to replace it and it is working like new.
Posted on Jan 09, 2010
    Sergeant:
    Champion:
  • 346 Answers
Check diodes on G board and the switching regulator on the G board.
Posted on Apr 30, 2008
    Problem Solver:
  • 14 Answers
Dear Video77301,
Good Day greetings from me. Please verify or be specific about blinks. 1 LED blink then 9 blink code. I this the number of times ? or 1 and 9 appear? If so pls. check the error coding in your Users' Manual, it is found in the Troubleshooting Pages..Then give us the instruction of each number.... If your set is newer,then you have your warranty, call the store where you purchased. This kind of problem might be in the Stand By circuits , an IC or Microcomputer chip is defective....
BEST RGRDs,
Eriez
Posted on Apr 25, 2008
I need to kno how to program my 8 in 1 jumbo remote to my rca tv
http://www.jumboremotecontrol.com/innovage_jumbo_remote_manual.PDF
RCA codes: 000,003,004,005, 007,009,011, 015,048,082,092, 094,096,098, 101,102,103,107, 113,125,129, 167,179,187,188, 191,194
1. Press and hold down the CODE SEARCH button •for at least 3 seconds until the red LED lights up solid red.
2. Press the device button , e.g. TV, DVD, VCR, etc. and the LED light will blink once and then remain solid red.
3. Press each of the number buttons 0-9 until the LED blinks once. This will signify the 1st number in the 3-digit code for the device that is programmed in your remote control.
4. Repeat same process to find the 2nd and 3rd digit for the 3-digit code.
5. Once you have found the 3rd digit the LED will turn off.
Aug 14, 2011 | Televison & Video
I have a 25-inch RCA television and a one for all remote URC-4330BO4 I need the code for the TV.
The manual for your control lists a bunch of codes for RCA:
0047, 0747, 1047, 1147, 1247, 1347, 1447, 0090, 0051, 0093, 0019, 0679, 0018, 0135, 0038.
They also list the code search steps to see if some other programmed code will work if none of the listed ones do:
  1. On the remote control, press TV once.
  2. Press and hold SET until the LED blinks twice, then release SET.
  3. Enter 9 - 9 - 1.The LED will blink twice.
  4. Aim the remote control at the TV and slowly alternate between pressing POWER and TV. Stop when the TV turns off.
  5. To lock in the code, press and hold SET until the LED blinks twice, then release SET.
Jun 29, 2011 | RCA Televison & Video
My R52WH74 projection tv is giving me a code 9 then 5 blinks
Replace the deflection board. You need the ITC222A deflection board PSB-260 available with installation instructions from www.tvrepairworld.com
Jul 07, 2010 | RCA R52WH73 Projection Television
How do i get this remote programed to work with my television?
I hope this would help you.
1, Turn on the tv.
2. On the remote control, press the tv key once.
3. Press and hold SET until the LED blinks twice, then release SET.
4. Use the code to locate the typ of device and brand name and then enter the first four digit code for the device. If performed correctly, The LED will blink twice.
NOTE: If the LED did not blink twice, repeat steps 2 through 4 and enter the same code again.
5. Aim the remote control at the tv and press power once. The TV should turn off. If it does not repeat steps 2 to 5. trying each code for your brand until find one that works. If it doesn't work, try searching for you code.
BTW, I don't know the brand of your tv so you might as well try these steps to search for you code but if you want to use the steps above just reply to this and send me the brand of your tv so i can search for the code.
1. On the renote control, press TV once.
3. Enter 9 9 1. The LED will blink twice.
5. To lock in the code, press and release SET. The LED will blink twice.
Jun 10, 2010 | One For All URC-6131 Remote Control
Need remote codes for one for all URC4220
2. Press and hold SET until the LED (red light) blinks twice, then release SET.
4. Aim the remote control at the TV and slowly alternate between pressing POWER and TV. Stop when the TV turns off. If the device does not have a Power key, you can substitute another function such as digits 0 ~ 9, CH +, or PLAY.
6. To search for the codes of your other devices, repeat steps 1 through 5, but substitute the appropriate device key for the device you are searching for.
Straight from the manual.
Hope this helps. =)
Oct 22, 2009 | Televison & Video
Urc-3021Boo one for all set up and codes for a sanyo tv
To control a Sanyo TV with a One for All URC-3021, follow these steps:
1) Turn on your TV.
2) On the remote, press the TV key once.
3) Press and hold SET until the LED blinks twice, then release SET.
4) Enter the code 0154.
If it does not blink twice, go back to step 2 and try the same code again.
5) Aim the remote at the TV and press POWER.
The device should turn off.
If it does not turn off, try the auto-search function.
To search for a code for your TV:
  4. Aim the remote control at the the TV and slowly alternate between pressing POWER and TV. Stop when the TV turns off.
Hope that helps.
Oct 17, 2009 | One For All URC-3021 Remote Control
HD50PLW164 Blue LED blink 10 times fast 1 time slow , TV restarts
For clarification of code/blinks significance you should check at mfg web site .
Sep 15, 2017 | RCA HD50LPW164 50" Rear Projection HDTV
No power
Check the ribbon cable connections between the boards to insure they are correctly seated as a 19 code usually means
Chassis detection, which means its not detecting a valid chassis usally the ribbon connections are the cause of that.
Jul 31, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have a phillips universal CL034 remote control and i dont know the code or how to program it to my television
without knowing the brand of the tv i have to give you generic instructions on how to program the remote without knowing the codes:
  1. Turn your tv on manually
  2. on the remote press TV once
  3. Press and hold the set button until the LED red light blinks twice, then release the set button
  4. enter 9-9-1. the led will blink twice
  5. aim the remote at the tv and slowly alternate between pressing POWER and TV. Stop when the TV turns off after pressing power.
  6. lock in the code by pressing and releasing the set button. the led will blink twice.
Jul 02, 2008 | Televison & Video
RCA P52937 52" Rear Projection Television Logo
376 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
