Question about APC Miniview (58098) 4-port KVM Switch
APC mini chopper scooter ignition switch
I lost my key and i want to bypass the starter switch how do i do this?
  • Anonymous May 17, 2009
    I have a 4-wire ignition sytem with my 50cc Mini Chopper, but no key...any solutions?
    Brigadier General:
  • 6,966 Answers
Most of this 2cycle engines uses any or a combination of the following wiring:
1. engine off is a wire from the CDI that needs to be grounded. The opposite therefore is to unground to allow the engine to run;
2. IGN on, when switched to ON, there is a +12VDC supplied to this wire; and/or
3. START, momentary +12VDC supplied to this wire that goes to the starter relay which then supplies the high current/big wire to the starter motor.
Due to inconsistency of Taiwan/China manufacturers, color coding of the wires is sometimes not standardized and therefore would require that you "wing" it using a DVM.
Hope this be of some help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Posted on Jan 12, 2008
    New Friend:
Take off the ignition switch and you'll see 4 wires red black green whitish black wires.connect the red and black wires together to turn on the bike. then use the electric start or pull cord. leave the green and whitish black wires alone! if you want to turn it off disconnect the red and black wires and connect the green and whitish black wires to kill the engine. hope that helps cause i lost my key too and hats how i start mine!
Posted on Aug 07, 2013
  • Tyler Fanska Aug 07, 2013
    take off the ignition switch and you'll see 4 wires red black green whitish black wires.connect the red and black wires together to turn on the bike. then use the electric start or pull cord. leave the green and whitish black wires alone! if you want to turn it off disconnect the red and black wires and connect the green and whitish black wires to kill the engine. hope that helps cause i lost my key too and hats how i start mine!
6ya staff
SOURCE:
Electra Mini Chopper 88905 wiring diagram
Hi, Sherman for more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Electra Mini Chopper 88905 wiring diagram Google Search
apc mini chopper pepboys Page 2 Pocket Bike Forum Mini Bikes
Electra Accessories 88905 Assembly And User Manual
Electra 43cc Mini Chopper Parts
mini harley parts
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
May 08, 2018 | Motorcycles
Trying to find info on a 2009 mini chopper/ scooter that looks like a harley
Hi, Andrew for more information about your question and valuable "FREE" downloads that you will need for viewing and printing please click on the blue links below. Good luck and have a wonderful day.
Motorcycles Unlimited EatSleepRIDE
49cc harley mini chopper Google Search
Custom Mini Choppers Gas Powered mini choppers Powerboard Gas Moped Gas...
Buying 49cc mini harley chopper scooter
ForSaleChoices com Mini Choppers Super Sale 49cc mini chopper
Jul 22, 2017 | Motorcycles
I need to know the size of the center hole on a 19 tooth transmission sprocket for an apc mini chopper Thanks
Why do you need to know the size of the centre hole. That one look in great condition. The size is the size of the shaft it fits on, so you measure the narrower distance, which is between the sprocket tooth that is under the middle of your thumb nail, to the second tooth past your index finger. All this links have info.
  • mini chopper sprockets ' eBay www.ebay.com > Search > mini chopper sprockets Refine your search for mini chopper sprockets. ... Mini Chopper Pocket Bike Parts 19 Tooth Front ... 28 Teeth Rear Driven Sprocket L for #410 Chain APC Mini Chopper ...
  • mini chopper sprocket in Parts & Accessories ' eBay www.ebay.com > Search > mini chopper sprocket Find mini chopper sprocket from a vast selection of ... Mini Chopper Pocket Bike Parts 19 Tooth Front Chain Sprocket ... APC MINI CHOPPER 48" THROTTLE CABLE ...
  • I need to know the size of the center hole on a 19 tooth ... www.fixya.com > Forum > Motorcycles > APC ... a 19 tooth transmission sprocket for an apc mini ... on a 19 tooth transmission sprocket for an apc ... rear 28 tooth sprocket for an apc mini chopper.I ...
  • Mini Chopper Sprocket and Clutch - DIY Go Karts www.diygokarts.com/chopper-plans/drive-assembly.html ... a torque converter can be used which effectively gives the project an automatic transmission. ... mini-chopper's clutch ... tooth #35 pitch. This size sprocket ...
  • mini chopper parts ' eBay www.ebay.ca > Search > mini chopper parts mini chopper parts 352 listings. ... 28 Teeth Rear Driven Sprocket L for #410 Chain APC Mini Chopper ... #428 Chain 17 Tooth 14mm Pitch Sprocket Part Gear Go Kart ...
  • Sprockets - PartsForScooters www.partsforscooters.com/Pocket-Bikes-Parts/Pocket-Bikes-Sprocket Mini-Chopper Parts; ... 127-19 . Stock 6 Tooth Front Sprocket with M10x1.00 thread size for 47 and 49cc 2-stroke cag style pocket bikes and mini-quads.
  • Mini Chopper Parts ' Mini Bike Parts ' We Ship https://www.gokartsupply.com/chopper.htm Home >> Parts Catalog> Mini-Chopper Parts. Parts For Mini Choppers Seats - Hand Controls - Fenders. ... SPROCKET 60T #35. 7-1/4" 28.50. 04-470. SPROCKET 72T ...
  • Electra / APC Mini Chopper w 49cc PS engine - Pocket Bike ... www.pocketbikeplanet.com/showthread.php?t=84442
    • 20 POSTS
    • FIRST POST: 2014-06-29
    2014-07-26 · Electra / APC Mini Chopper w 49cc PS engine Mini Choppers. ... Sounds like you got a transmission with slag on the internal gears ... do a search as mini chopper parts.
  • mini chopper bike ' eBay www.ebay.ca > Search > mini chopper bike Find great deals on eBay for mini chopper bike and ... 43CC 49CC APC MINI CHOPPER MINI BIKE MONKEY ... 17 tooth sprocket gear Pocket Bike Mini Chopper ...
  • Rawge's Mini Chopper Information Site - Gearing and Sprockets www.rawge.bravepages.com/minichoppers/speedo.htm Rawge's Mini Choppers ... The Simple Mini Chopper Drive ... you can expect from your mini chopper, given the size of the sprocket on your ...
  • Pagination
  • Apr 08, 2016 | APC Motorcycles
    Hi I need to purchase a 19 tooth drive sprocket and rear 28 tooth sprocket for an apc mini chopper.I also need 5ft of #410 chain
    Hi, Paul for this situation I would call my local dealer or reputable shop's service/parts department (Pep Boys) and inquire about any possible quick fix, answers, or parts inquiry. If necessary, transport your bike to the dealer or shop and have a professional technician take it for a test drive, if it is in running condition, and give you a written estimate of repairs and answer any specific questions you may have about your problem. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
    APC Mini Chopper Parts Accessories eBay
    Mini Chopper PartsThere are232products
    Mini Chopper Bike Parts 33cc 43cc 49cc Stock Replacement
    Apr 07, 2016 | APC Motorcycles
    What is the gear size on the motor and chain size on a 43 cc mini chopper?
    Hi Paul the front sprocket is 19 tooth and chain size is # 410 don't know how many links though. For more information about your issue and valuable "FREE" downloads that you will need please click on the websites below. Good luck and have a nice day.
    http://www.ebay.com/bhp/apc-mini-chopper
    Chain too loose
    http://www.aliexpress.com/49cc-2-stroke-mini-chopper_reviews.html
    APC Mini Chopper Questions
    Apr 06, 2016 | APC Motorcycles
    How do I find a wire diagram for a 4949cc mini choppers ga-643f
    Hi, Anonymous for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. If necessary, transport your bike to the dealer or shop and have a professional technician take it for a test drive, if it is in running condition, and give you a written estimate of repairs and answer any specific questions you may have about your issue. For more information about your issue please visit the website below. Good luck and have a nice day.
    http://www.tootoo.com/idetail/49cc-mini-chopper-with-two-strokes-ga-643f_24495635_721073_6878978_16262765
    49cc mini chopper wiring diagram Google Search
    Download 49cc mini chopper wiring diagram
    APC Mini Chopper Key Switch
    Dec 15, 2015 | Motorcycles
    Can i start my scooter without my key
    if you cut or connect the correct wires you can bypass post ignition switches
    Nov 13, 2014 | 2008 Genuine Scooter Roughhouse R50
    What could be causing my 49cc mini chopper motor from starting?
    If its a brand new carb and you have compression and spark most likely the problem is the idle mixture screw is turned in too far or turned out too far I think the proper setting is 1and a half turns out from being lightly seated .if that doesn't work check your spark plug for proper gap or clean it
    Oct 12, 2013 | Garden
    Lost key need to bypass vatts without having key have already drilled the ignition switch will turn now i need to bypass the starter and fuel system
    here is a great write-up that will help. This system will bypass the entire security system and will take care of starter and fuel system. It was the only thing that saved my car : http://newrockies.com/vatsbypass
    Nov 07, 2009 | 1994 Chevrolet Camaro
    APC Miniview (58098) 4-port KVM Switch Logo
    2,627 people viewed this question
    Top APC Computers & Internet Experts
    Shawn DuRee
    Alun Cox
    Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
