Question about Kenmore 20172 Top Load Washer
Light stuck on Rinse, won't run but has power...
I recently encountered this problem with my kenmore 20172 commercial washer and I found out that it was due to the lid switch.  Over time if you allow the washer lid to drop down hard it can cause the lid switch underneath to separate.  When this happens the switch won't respond and the washer won't run.  To solve this problem I  took the switch off by taking off the two small screws that hold the switch together and used some electrical tape and taped the switch closed.  I ran one horizontally and one vertically.  This solved the problem and it's easy to do.  Hope this information can help someone out.
How can i replace the dog agitator
Posted on Apr 26, 2008
  • 1,294 Answers
Posted on Jan 12, 2008
Agitation does not stop when lid is open... Kenmore 20172 Top Load coin-op Washer needs new lid switch? Cost? Easy to Fix? Do I need a expert to do? Thank you...
sounds like the lid switch is jammed on- you can try to spray it with WD 40 or replace it it usually requires taking the machine apart to get at the wiring. Easy fis, just need patience. the switch should be able to be ordered online.
Oct 21, 2010 | Kenmore 20172 Top Load Washer
Kenmore 80's series top loader only works on wash and rinse cycle
This is a problem with the pump being stuck so the motor cant turn the whole thing. Turn the washer on its side, underneath you can acces the pump, which is connected to the motor by two long clips. remove the pump and take out the colg that caused it to get stuck.
Jul 01, 2009 | Washing Machines
Kenmore 90 series washer will get stuck in between cycles
Sounds like the timer has failed. It's a common problem.
Part number 8545379, $83.69 from
Feb 04, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 70 series model #11020712990 won't rinse
The TIMER is what is bad in this case.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 13, 2009 | Kenmore 20172 Top Load Washer
Kenmore washer stops
if washer resumes operation when left alone after 30-45 min suspect motor overheat ..also could be bad timer contacts or connection on motor end at plug
May 20, 2008 | Kenmore 20172 Top Load Washer
Kenmore 20172 Washer does nothing when coins drop
Sounds like the lever for the coin box needs an adjusment. It may not be far enough back to engage the lever to start it.
May 07, 2008 | Kenmore 20172 Top Load Washer
Kenmore Elite Calpso washer
i am having the same problem with my calypso model 110 top loading washer. i found that the drive to the pump was spinning on it and stripped out the teflon gear. i believe the motor to the pump is working but, the pump isn't spinning i don't think. thats why the water isn't coming out, and the cycle won't move on. i can't seem to find the 8527775 pump by itself. the geneic ones i found have a different fitting to the motor.
Sep 17, 2007 | Kenmore 20172 Top Load Washer
Kenmore Series 90 washer problem
i am a recently retired engineer of 20 years, this sounds like the outlet pump, maybe just a blockage, but could be a faulty unit, remove plug before checking, start with that and see how you go on, thank you, if this has worked rate me please
Sep 12, 2007 | Kenmore 15864/15862 Top Load Washer
Kenmore 20172 Top Load Washer Logo
Sal De
 Brian Main
Brian Main
