Question about GE WDSR2080D Top Load Washer
GE WBXR2060V1WW won't agitate...
My GE topload WBXR2060V1WW washing machine is not agitating although it still spins and drains the water out. It sounds like there is water collected beneath the tub too. I can hear the agitator try to work and if you press down on it, it does seem like it tries to turn, as though it's no longer connected or something. Any ideas?
  • 4 more comments
  • Anonymous May 27, 2008
    I have the same problem but my washer start off making a lot of noise in the beginning of the cycle and than it becomes quiet again until it done.
    thank you
    ngj
  • Anonymous Jun 30, 2008
    Same problem. I pulled the agitator, and the agitator alone spins and "locks", but it does look like that coupler has striped and I do not see any way how in it's current condition that it could grab the agitator to turn it. I order the coupler and hopefully that's it. Thanks!
  • telijah Jul 08, 2008
    So I replaced the coupler, and it still does not agitate. If I reach in and hold the air bell, and try to spin it counter-clockwise, it will then agitate (using a screw driver to keep the machine running with the lid open...). What's next?
  • l88r22z15 Oct 06, 2008
    How do you take the agitate off mine is not agitating but spining to drain the water but I need to know how to take it off to check if it is connected or stripped. thanks my machine is wjsr2080v1ww
  • di44ane Dec 21, 2008
    my washer is doing the same. It doesn't agitate, but it spins and empties in the wash and rinse cycles.
  • telijah May 11, 2010
    Spidy4u: When you say replace the agitator, do you mean the entire bell at this point? I replaced the coupler and it still does not agitate.
There's a part under the agitator(which lifts off if you pull up from the bottom evenly on two sides) called the "Air Bell Coupler" that attaches to a metal toothed motor shaft with one bolt. More than likely the plastic teeth have stripped off from this coupler, preventing it from sitting tightly on the shaft, thus causing the agitator to not "agitate" properly. You can get this from www.partselect.com. PS1517844 KIT - AGITATOR COUPLING
Cost is $7.15 plus shipping.
Posted on May 06, 2008
  • 20 Answers
Sound like the agitator is striped.try to take the agitator off and see if the shalf is turning and if it is u need a new agitator
Posted on Mar 12, 2008
Washer fills with water but doesn't begin to agitate to wash. It also drains but doesn't spin when we set the dial to that
Your agitator pindle. has come loose From the spline. Try to lift up on the agitator. If it lifts off the spindle easily then it has worn out the spline. That is what connects the agitator to the s
Feb 06, 2013 | GE Profile WPRE6100G Top Load Washer
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Jun 14, 2011 | Whirlpool LSR7333 Top Load Washer
My GE WCSR4170D AWW top loading washing machine will not stop filling with water. i can get it to agitate when i blow into the air line hose attached to the water level switch. BUT it never stops filling...
Thanks for choosing FixYa and welcome. You probably have a bad water level switch. As for the agitation, the drive motor controls the agitation, spinning, and draining. It is possible for the machine to not agitate, but yet spin and drain. The motor runs clockwise and counterclockwise. It may be bad and if so, will need changed.
Apr 30, 2011 | General Electric WCSR4170D Top Load Washer
No Spin or agitation After move
Reset computer. Unplug for 2 minutes, plug back in, open and close lid 7 times slowly to reset computer. This should solve your problem.
Jul 27, 2009 | GE WBSR3140DW Top Load Washer
Replaced belt but machine will not agitate or spin , but does let water in it
if it is a topload u have a bad transmission thats what broke the belt was trying to spin and couldnt
Apr 16, 2009 | Washing Machines
GE profile washing machine won't agitate it spins out, drains,
Pull the agitator out and check the drive collar splines.If you have the model I think you have just pull straight up on the agitator. Once removed you will see the drive collar with a 7/16 head bolt,remove it and pull off the collar.First before pulling it off spin it if splines are stripped it will spin freely.
Mar 25, 2009 | GE Profile WPRE6100G Top Load Washer
GE Top Load Washing Machine -- Agitator will not cycle
Agitator's don't spin on wash cycle.
I would suggest washing the clothes without soap until they rinse clear. If you have hard water, the soap will not easily rinse out of clothes, or off of you when you use soap to wash or shower.
Reduce the amount of soap you use in each wash if this is the case. It sounds like your washing machine is working right.
Jan 26, 2009 | GE WBSR3140DW Top Load Washer
Washing machine won't agitate.
Depending on type of washer, typical top load Maytag, motor turns in opposite direction for wash and spin. Your problem will no doubt be the transmission.
Nov 01, 2008 | Washing Machines
GE WDSR2080D Top Load Washer Logo
2,013 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
