Question about Apple iPod nano
My ipod has a code and i do not no it so i'am jast trying to reset it
    President:
  • 317 Answers
First make sure your hold switch isn't on. It's on the top or bottom and slides back and forth. It needs to be switched to the left. Once it is to the left, here's how you reset:
You can reset your ipod by holding down the menu and select (round button in the center) buttons down for at least 10 seconds. You'll see an apple logo flash, that's when you stop pressing the buttons. It will shut off, then back on.
Posted on Jan 12, 2008
I put music on ipod from windows media player . i (safely remove)ipod .the ipod screen displays(ok to disconnect)and is frozen on that screen it will not power down or go to main menu
first clear the ipod memory form all songs.
move jast one song, if it's working you have blocked the memory to full, if not.
hard reset the ipod
hold both power & home button for 30 sec.
than run it one nor time
if that didn't help, instal a fresh ipsw.
injoy
Dec 15, 2013 | Apple iPod Nano Seventh-Generation
Remove security code
Try resetting the ipod, this usually works. As follows: How to reset iPod To reset an iPod with a Click Wheel, including: iPod nano (3rd generation) iPod classic iPod (5th generation) iPod nano (2nd generation) iPod nano iPod with color display (iPod photo) iPod (Click Wheel) iPod mini iPod mini (2nd generation) Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center. If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep. To reset iPod, iPod (scroll wheel), iPod (touch wheel), and iPod (dock connector) Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Play/Pause and Menu buttons simultaneously until the Apple/iPod logo appears, about 6 to 8 seconds. You may need to repeat this step. If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep. If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button. When you reset iPod all your music and files are saved, but some customized settings may be lost. Date and time is preserved (unless the iPod reset itself because it had no power and then was reconnected to power). Other customized settings, such as Bookmarks, On-The-Go Playlists, Shuffle, Backlight timer, and so forth are preserved from the last time the hard drive turned on. Good luck, and I hope this helps.
Sep 20, 2007 | Apple iPod nano
My printer problem is service require.. please help me... i'm bob
where is your printer model. Please post your problem with your printer model.
Now jast go to google search and type ' -------printer reset tool free of cost' and click search.There are many result are shown. Jast click and download your printer resetter tool. and run it in your pc and reset your printer.
Thank you
Apr 23, 2011 | Office Equipment & Supplies
I need to know how to reset my ipod because for some reason I can't get in itunes it want even let me create a new account all it keep saying is sorry can not connect to itunes so i already tryed to reset...
1. Read this this from Apple "How to reset iPod" @ http://support.apple.com/kb/ht1320 , and
2. Restoring iPod to factory settings @ http://support.apple.com/kb/ht1339
Since you cannot acess to your code, you have to reset your ipod back to factory default, but all your data on your ipod will be lost!!!
Hope it helps.
Jul 05, 2010 | Computers & Internet
My dumb ipod volume code:(
use itunes to roll back/reset ipod you will have to replace all info back on ipod after it resets but should take care of it my sister gave me an ipod without giving me code
Aug 18, 2009 | Apple iPod nano
Help
try a hard reset by letting the ipod drain the full charge and then start the unit.
this will reset the codes.
Aug 01, 2008 | Apple iPod nano
Reset ipod nano code
restore your ipod using itunes, and it should reset that pass word
Jul 25, 2008 | Apple iPod nano
Ipod lock code
You should be able to reset the ipod by pressing/holding down the center button and the menu button the same time (6-10seconds). If that dosen't work, plug in your device to the computer and you should be able to reset it on the itunes program.
May 13, 2008 | Apple iPod nano
Problem unlocking
need help lock 8gb ipod need big help now
Dec 05, 2007 | Apple iPod MA446LL/A MP3 Player
Apple iPod nano Logo
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Parshiv Luthra
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
