Question about Blodgett Ovens
Blodget conveyor oven Mt 21 G
Oven works,
BUT.I have a few nagging questions...
The rear "Control Box" fan, should it be sucking air out or in,
If it sucks the air out will it affect the amount of air the gas burner blower gets from inside that box,because the whole thing is reasonably sealed once the side pannel is screwed on..
The cooking Tunnel Extensions, can they or are they supposed to have a baffle that cuts the openings down to half hight. I'm cooking pizza and they are not very high.
It's just that the coveyor belt is not very long on both ends and the Tunnel Extensions covers shorten the time you have to see the pizza coming out and be ready to grab it before it fall over the edge.
I have not been using the tunnel extensions but the oven takes longer to heat.
Can I put half hight baffle plates in front of both tunnel openings so as to keep the heat in Or will it affect the burner and or air circulation for exhaust gasses.
  • 17 Answers
SOURCE: lincoln pizza conveyor oven
have you checked the speed control?? it maybe off on the speed run some empty pans thru and time each one I will need a model to give you the entry and exit times for your model before we can futher. do it 3-5 times let me know
Posted on Dec 04, 2007
  • 254 Answers
SOURCE: power outage Blodgett Conveyor Oven
On the back of the motors there are safty overload reset's, these are small red push in buttons. Also there are fuses for each motor inside the control panels assembly.
Posted on Jun 10, 2008
SOURCE: oven failed to work; F5 error message
replacing the microprocesser febc208
Posted on Sep 05, 2008
  • 250 Answers
SOURCE: stoves 720ef fan oven cutting out
I confirm that you should get an oven thermometer as I did as my 720 wasn't behaving itself. Lakeland do one that works well and is not to expensive. I found that the fan oven was working ok but the top oven was way out, i.e. setting 160 on the dial produced 140 in the oven. The thermostat sensors for both ovens are located at the rear of each oven at the top right. They should be clear of all congealed fat etc and should be bright and silver in colour. If they are dirty this may cause them not to work correctly. Lakeland again do an oven cleaner that you paint on with a brush. It may take more than one go but it cetainly removes all the rubbish and may well restore the thermostat to near normal operation. When cleaning the sensors be careful of the thin wire from them as if this is damaged you will have to have a complete new thermostat.
(The oven cleaner works on everything inside the oven including the stay clean lining).
As a final thought is the cooling fan running when the oven fan is on as this may cause the oven to overheat?
Best of luck.
Posted on Jan 05, 2009
  • 1869 Answers
SOURCE: how to reverse the conveyor belt on a blodgett pizza oven
reverse the wires on the conveyor motor
Posted on Apr 22, 2009
  • 3463 Answers
SOURCE: Heat escaping, uneven baking, longer cooking times
Either the seals need to be replaced, or you may have weak oven door hinges, and the door is not closing properly.
Only solution would be to replace both hinges if this is the case.
Please rate my solution.
Posted on Feb 01, 2010
0 characters
1 Points
Middleby Marshall 360 pizza conveyor oven is making clanking noise by circular fan grate in back bottom left of oven. Please help
Is it the rear of the oven or the left side?
  • Rear of the oven, it is a obstructed or malfunctioning axial fan. Replacement cost $10-$20 - 30 minutes labor
  • Left side of oven, possible main blower fan malfunctioning. Depending on type of motor "S" or "Q". It might be the mount or a bearing wearing out. Replacement motor $200-$400, motor shop rebuild instead $150. Squirrel cage will need to be removed if damaged $100-$300. Labor 2 hours, if you know what you are doing, 4 to 6 if this is your first time. Check your heat slinger also. This might have come loose.
Call me for parts or further info. I have been here before.......
Marcus Bramhall
Shimmmer LLC
Feb 17, 2011 | Ovens
Lincoln Conveyor oven Md. 1000 Suddenly turns off
Check the burner-blower centrifugal switch (S5 on the wiring diagram).
Jun 19, 2010 | Lincoln Conveyor Oven - 1133-000-A
Ovens conveyor belt is working, but the heat and air are not working
A conveyor belt oven would make things so much easier for the staff of a pizza restaurant . Is it possible to get a wood fired conveyor belt oven? If not .... could I build one?
Apr 18, 2010 | Lincoln Conveyor Oven - 1130-000-A
Fdp 231 tcp 21 The bottom oven the fan is working but the oven does not get warm
It is likely to be the oven element that is faulty, if the fan is working o/k, then replacing the element should solve the problem. it is located at the rear of the oven compartment, where the fan is.
if there is no visible sign of fixing scews in the oven for the element or cover, then you are going to have to access it from the outside rear panel of oven.
Hope this helps you.
Please leave feedback.
Dec 14, 2009 | Candy Ovens
Can my lincoln conveyor oven 1130 be switch to run to either direcction
Yes. UNPLUG THE UNIT!!!! Inside the control box there is a motor control board.On the motor control board there are two sets of terminals to look for. Set one is labeled T1-T2. Make sure you have lots of light and a magnifying glass in case it is hard to read. Carefully pull the two wires and switch them. Set two are labled A+ and A-. switch these as well. You must switch both sets at the same time or the conveyor will run at full speed with no control. The wires might be hard to pull off so carefully wiggle them as you pull.
Aug 21, 2009 | Lincoln Conveyor Oven - 1133-000-A
Middleby Marshall PS360 pizza oven won't maintain HEAT
sounds like the control cabinet overheated and the controller starts to break down at 140' F I would replace the controller and keep the cooling fans clean
Aug 06, 2009 | Ovens
Conveyor oven motor won't start
does the motor have a start capacitor. It could either be that or it could also be the control board. Good luck :)
Jun 23, 2009 | Ovens
Go here find what you seek. Great Co.BLODGETT
44 Lakeside Avenue, Burlington, VT USA 05401
Toll Free: (800) 331-5842 Phone: (802) 860-3700 Fax: (802) 864-0183
Feb 25, 2009 | Blodgett Model Mark V Single Electric Oven
I have a lincoln impeger pizza oven and it wont come on
The oven temp high limit is on the back. Depending on model there is a control box high limit that you need to open the control box and locate. If this is the case, make sure the cooling fans are running.
Dec 13, 2008 | Lincoln Conveyor Oven - 1133-000-A
Power outage Blodgett Conveyor Oven
Jun 02, 2008 | Blodgett Ovens
Ovens Logo
185 people viewed this question
Top Blodgett Ovens Experts
Dan Webster
Dan Webster
Level 1 Expert
Jeremy Tucker
Level 1 Expert
Are you a Blodgett Oven Expert? Answer questions, earn points and help others
