Harmon Kardon reel to reel tape player
I need a main drive belt for my Harmon Kardon TD3 Tape Player. Serial # 3770446.
  • Anonymous Mar 12, 2014
    harmon kardon avr1710
I have a Harmon Kardon TD-3 that I'm looking to sell. It's not in its original cabinet, but in a smaller box that takes up less space.
Posted on Oct 19, 2009
Need an Eicor 1950 Home Tape Recorder and Player repaired. Local to Washington, DC Metro area.
That is; supply wheel turns, and take-up wheel doesn't. Isn't it? The tape deck mechanism fault. Should be a broken belt [loading belt] can cause this. Check for it.
Nov 29, 2015 | Audio Players & Recorders
I have a Yamaha KXW302U audio tape player. And when I play a tape on the A deck, after one second, it stops.
The auto stop function is activating due to lack of reel rotation on the TU reel and so you may need a reel drive Idler tire or a new belt.
Apr 02, 2015 | Yamaha Audio Players & Recorders
The issue is, that I purchased a set of 2 belts via eBay for my deck. I fixed the problem with the belt to move the cassette. But there is a second set in the pack and I cannot install this. Perhaps it is...
The belts you have replaced are used to operate the loading/unloading mechanism I assume. On the bottom of the cassette mechanism you will find the other belts...one from motor to idler wheel assy. or actual reel hub. Older cassette decks also used a belt to drive the tape counter mechanism.
Sep 10, 2013 | Harmon Kardon Harman Kardon Td 420
Perhaps, my message has already sent, but I am unable to check. I purchased a set of two new belts vor my Harman Kardon TD420 tapedeck but don't know how to install them. The larger belt (square) is...
Older cassette decks used belts from the motor to the capstan, another from the motor to an idler assy. or tape reels (FF & RR) and another belt driving the mechanical tape counter.
Sep 08, 2013 | Harmon Kardon Harman Kardon Td 420
HI, I purchased new belts for my tapedeck (2 actually: a flat and a square one) but I don't know how to install them. The square belt is visible but I cannot find the flat one. Can you help me?
The flat belts are usually the one from the motor to the flywheel or "capstan." Most people don't realize this, but the capstan and pressure (pinch) roller is what actually drives the tape in the play mode. The reels are used to maintain tape pressure and perform rewind / fast-forward.
Cassette player plays tapes for awhile then will go garble like and auto reverse back and forth once then shut off. I noticed it seems the tape is getting kinked up or stuck on the rollers. looked for...
The reel drive of your set is not taking up the tape and resulting in no detection of reel pulse. this makes it switch over and the result happens again. Please clean up your drives, the rollers, change the belt and check the reel drive arrangement, the motors. I am sure the mechanism must be reset with new belts . This must solve your issue. Good day
Jun 20, 2010 | Panasonic RQ-SW33VA Personal Cassette...
Tape gets stuck
It sounds as though the tape player mechanism isn't working correctly. Either the machine's tape heads are't engaging fully, but usually this is a result of the drive belts becoming worn and not turning one of the tape reel's at the same speed as the other. Culminating in a difference so one reel will run faster than the other, this can cause bunching of the tape as it goes through the tape heads jamming it up. The VCR will need to be inspected by a technician for repair or replacement of the drive belts.
Hope this helps,
James
Apr 25, 2010 | Insignia IS-DVD1001 DVD Recorder/VCR
Durabrand Tape/CD Player twists up all cassettes inserted
We have two of these with the same problem. The belt that drives the pick up reels is broken. We are trying to find a place to purchase new ones.
Mar 26, 2009 | Durabrand CD Player with Cassette...
Reel to reel tape payer
i changed the main drive belt on a reel to reel stereo tape recorder model no A1340 serial no 3642 there is a small wire arm under the play/ record head platform . I believe its the record switch . the arm is not straight looking at machine the arm is straight from switch and go at a 45 degree angle then turns straight and then angles up about a half inch or less . i need to know how to replace this arm ( switch) back into the the head platform so i can start using this recorder
do u have rhe service manual for this machine if so ca i get a copy ?
thanks
Arthur Hathaway
Nov 20, 2008 | Audio Players & Recorders
TEAC reel to reel tape player
Hi jvanheul
You can get a belt kit from these guys for 15 plus some post. Fresh belts, good service Bob will help you out. Cheers. A FixYa for this would make my day :)
regards
robotek
Jul 18, 2008 | Audio Players & Recorders
203 people viewed this question
 Grubhead
Grubhead
