Question about Zebra Eltron LP 2824 Thermal Printer
Zebra LP 2824 Comm port problem
I am having problem communication with the printer through the COMM port. When I send some jobs to the printer, the jobs were displayed in the printer queue and then gone. It looks like the jobs were sent to the printer but nothing came out on the label.
I couldn't send the command "^default" through COMM port.
I did try to hook up other LP 2824 printers with the same computer and they work fine.
Is there anyway to get this to work or anyway to reset this printer to the factory default?
Thanks
  • Anonymous Dec 07, 2008
    i have the same problem and i can't solvet
  • 32 Answers
I believe if you hold the button down that has the green ring around it and power it back on it resets the printer to the factory defaults.
Posted on Aug 23, 2008
COMM ERROR CODES
yes and explain. what equipment, type, problem, errocode,
most com ports are using
com 1 (normally the mouse on older pc)
com 2 in the past communication port
com 3 usually to convert to other kinds of ports
you can rearrange these ports in the hardware settings list off you're pc, windows take some time to accept it. if you change you're port think about the consequences.
May 04, 2015 | HP LaserJet 3030 All-In-One Printer
I am using the PE 16 & suddenly I get a comm. error when I try sending faxes, both using the automatic dialling or dialling manually - I tried unplugging from the elect. & the phone line &...
comm error could mean numerous things is the phone line cord your using new? do you hear it dailing or a dail tone? are you on dsl as far is Internet these use filters that can mess with communication.Does it use standard dailup to send faxes
Jul 04, 2011 | Xerox WorkCentre PE16 All-In-One Laser...
Printing - print job arives @ printer no output
Sounds like a driver problem. Some printers require eoj (end of job) character & will wait forever.
Do a test print (search internet on how to print status page- usually button press combo). If you get a printout, you know the print engine is good.
If the printer is able to parse text, then try sending an ascii test file & see if anything prints. This will tell you whether it's a comm issue or rendering issue.
Jun 02, 2010 | Office Equipment & Supplies
Comm error 634
Receiving fax never picked.
Aug 14, 2009 | Panasonic PanaFax UF-8000 Laser Fax
Am having problem communication with the printer through the USB port.
There should have been some software that came with the cable. This is a utility that has to run on the system to enable the printer to communicate across the USB to paralell jump.
May 25, 2009 | Zebra Eltron LP 2824 Thermal Printer
9403 monarch printer/hooked to lantronix print server
If the printer doesn't react when you send a print job to it (either prints, or displays an error code on the display) and just sits there doing nothing, it generally means the print job didn't get to the printer. Check your communication settings. The printer comm settings must match the settings in your software. The default comm settings on the printer are:
Baud : 9600
word length: 8
stop bits: 1
parity: none
flow control: dtr
Apr 27, 2009 | Monarch 9403 Thermal Label Printer
Not Printing correctly
This may me due to various factors.
- The parallel port is only unidirectionnal. You should use ATcompatible for this port instead of ECP on the computer.
- The driver sends data in topix compression not understood by your printer.
- there is problem on your parallel port
Mar 12, 2009 | Toshiba TEC B-572 Printer
Hp laserjet m2727nf mfp - fax errors - sending and receiving. comm error 350, and comm error 232. Dedicated fax line. Any advice?
Check if you have the latest firmware for this multifunctional on www.hp.com, installing newer firmware fixed communication problem for us.
Apr 17, 2008 | Office Equipment & Supplies
Comm. Error
Try this website: http://www.instruccionesweb.com/u2/pdf/fax/Canon-L120-en.pdf
Jun 25, 2007 | Canon L120 Fax Laser Printer
Zebra Eltron LP 2824 Thermal Printer Logo
1,054 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
