Question about Samsung HLN5065W 50" Rear Projection HDTV-Ready Television
Samsung dlp rear proj model # HLM5065W
After the tv warms up it starts flashing the lighter colors on the screen, now it does within 20 minutes of being on. Bulb was replaced last year along with the color wheel, any ideas ? thank you for you help it seems other on your siter are having the same problem
  • gbreedingj Jan 30, 2008
    just spent $126.00 to find out its not the color wheel it is the DMD mirror Board and color board total cost to repair including labor $ 1,012.78. i am throwing the damn thing out ! it s only 3 yrs old, i will never buy samsung again
  • gdm27 Feb 04, 2009
    ihave the same problem like a strobe light on screen. changed bulb same problem. tv works for 1 hr then it starts to flicker white and blk flashes .tuurn tv off 10 min and problem goes away. comes back in 30min or so. no led lights problems and picture is excelent when its been off and turned back on. if anyone has a solution please let me know . im ready to buy a new color wheel am i wasting my money
  • 4,402 Answers
Samsung color wheel fix
http://www.jaGet a new cable if everything else works that is your problem
Posted on Jan 16, 2008
  • Cary Farah
    Cary Farah Jan 30, 2008
    Few things you could do first before you toss it!
    Resit the boards (take them out and put them back in)
    see if can test the boards and or replace them
    I was just reading a post :
    My HLN-5065 has a problem... it has developed a
    flickering/flashing that is present on all inputs, even a blue "no
    signal" screen.
    Several repair attempts have been made.. new ballast/bulb... new analog
    board... new DMD board... and none has solved the problem....
    Has anyone had a similar problem? If so, what was done to fix the problem.
    My extended warranty company is starting to get nervous.... I am now
    talking to the Senior Service Manager, having to convince him that
    there is really a problem... not just in my mind... or eyes.... I'm
    worried that they may start to balk....
Samsung HLN5065W Color/Power problems
Good day!!!!
Kindly check the power supply board..Look at the capacitors within check the visual condition if it is look like bulged,leak or burnt..
If that so,try to replace it with the same type ratings and can order that parts on local or online..
This is the sample images:
Dec 19, 2011 | Samsung HLN5065W 50" Rear Projection...
I have a 50" Phillips
Check ur owner manual or call Philip support Tech. ask it this tv model have a colors wheel design into it tv.Not sure for a Philip model tv 50" DLP tv,but the Samsung model 50" DLP tv this problems alway causes by a dying colors wheel that design into it tv.Which the colors wheel it is warp worn out and spinning off of it motor mount axis to cause grinding noises and tv colors to mess up and flashes or have flashes Black & White within it picture.
Jun 07, 2011 | Philips 50PL9126D/37B 50" DLP TV
We have 50" Samsung DLP
Yes,the tv have a colors wheel and it is the cause of these problems.Humming noises,motor noises,picture flashes black&white or colors pictures within the pictures.The colors wheel,is dying or already dead.Hire a tv tech. replaced the colors wheel,will solved ur tv problems.
Nov 06, 2010 | Samsung DLP HL-P5663W 56" TV
TV Picture problems
My samsung did the same thing right before my color wheel went out. Can't be sure but that is what was wrong with mine. hope this helps.
Jan 25, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung HLM5065W DLP shuts itself off for no apparent reason
I just had the same exact problem. New bulb and all. Tech. said it was the Light Engine assemble was going bad. Here is some photos of the Light Engine.
Nov 22, 2008 | Samsung HLM5065W 50" Rear Projection...
I have the HLM-5065W DLP TV. Replaced lamp 1 year ago. It attemps to start 3 times before shutting down. then all light are flashing. I hear an electrical sparking and I see the bulb flicker but that it. Did the bulb go out again? IF so why so soon. If not what is the problem??
Apr 17, 2008 | Samsung HLM5065W 50" Rear Projection...
HL-P5063W Green lines when the tv warms up
My Samsung DLP is having the same problem.  Not sure what to do, but I will contact my warranty place for the second time.  Hopefully they'll fix it.  Any other suggestions?
Mar 23, 2008 | Samsung DLP HL-P5663W 56" TV
I am currently having the same problem. It started they way you are discribing, but now the TV will do that after the TV has been on for 20min and then will shut off within 30min. Then all the lights up front flash. I have replaced the bulb and that was not the problem. I also NEED HELP! Occasionally the picture on my TV will be inverted and sort of "dance" back and forth on the screen.
Apr 30, 2007 | Samsung HLM5065W 50" Rear Projection...
HDTV Rear Projection
The color wheel is the most common problem when it comes to noise from DLP's. To determine if it is a color wheel or fan: Turn on the set. When the noise starts, turn off the set. If the noise goes away within 5 seconds, then the color wheel is bad. If the noise goes away after one to one and a half minutes after the set was shut off, then one of the fans are making the noise.
Apr 01, 2007 | Samsung HLN617W 61" Rear Projection HDTV
Samsung HLN5065W 50" Rear Projection HDTV-Ready Television Logo
154 people viewed this question
Jerry Greenberg
Jerry Greenberg
