Jamming 5.5 X 8.5 postcards are getting jammed on roller upon entry
    Problem Solver:
  • 8 Answers
Please state the brand and model if you really want to get some real helps to your problem. Basically all copiers required you to set the type of throughput material and the size on the particular paper tray that you are using. You may have set a different size for your postcard printing/copying.
Posted on Feb 21, 2008
We have a Ricoh Priport HQ9000 which keeps jamming at the paper entry and we are getting a small mark in the middle of the paper
check the rollers well. sometimes they get grime an dust into them and stick or roll rough an hard or not at all. just a touch of spray cleaner works.
Jan 30, 2015 | Ricoh Office Equipment & Supplies
Paper jam in cannon lbp3300 printer
Unplug printer and check paper entry feed ,especially the right side,will probably be dirt or a piece of paper stuck in feed roller, use an air duster (aerosol) to blow out dust etc.
Jan 14, 2018 | Office Equipment & Supplies
Take apart hp3005dn
Analyse what type of jam it is...based on that we can shoot the trouble.1. Paper is jamming before entry in fuser and its folds like curl in the cartridge area.. A. Fuser Teflon sleeve not rotating or slow rotation results media(paper)unable to reached the destination in specified interval. Replace fuser assm or Teflon sleeve.2. Paper jamming after fuser assembly crossed little bit ( approx 1-2 inch).A. Clean fuser out paper sensor, check sensor flag & flag spring located in fuser assm.3. Paper jammed after fuser crossed more than 6 inches..A. Check paper pick up roller warn out(tray1 or 2), check registration sensor located under registration assm.How to remove fuser assm: remove back door, see the snap shot...
Registration sensor location:
Pick roller roller tray 2 :
1_9_2012_3_54_49_pm.jpgPl try it carefully..Best of luck...
Jan 09, 2012 | HP LaserJet P3005n Printer
Oki C5500 printer keeps jamming
Open the tray and find yout imput roller. You can remove this roller and put it back on the other side. Normally this is caused because it is worn. The inside of the roller is like a new one.
Jan 11, 2010 | OKI C5500n Printer
Paper is jamming during printing process. Gets half way round and jams. please suggest solutions
There are rollers that the paper has to go between to be pulled forwards. When the rollers get dirty with paper dust, paper starts jamming. So you need to clean the rollers with a moist (not wet) soft cloth, Keep rolling the rollers manually and keep cleaning them. Then allow a few minutes to dry them up. And no jam after that.
Dec 10, 2009 | Dell 1100 Laser Printer
Paper is jamming right as it exits
The "wrinkled"pressure roller should be replaced, but how does the Upper fuser roller look? It is probably the main culprit of the jamming. Is the surface deteriorated? It should be fairly flawless (teflon looking). If the surface is looking "rough" it is causing the paper to stick, because this "roughness" is usually a build up of toner that is not being released to wear, so the pages get "stuck" to it rather than passing smoothly through.
Please rate response ;)
Apr 24, 2009 | Office Equipment & Supplies
Fax Machine keeps jamming
Depending on where the jam is, it could be the rollers at the exit. I have found that these rollers become sticky and cause intermitted jams. I suggest using methylated spirits to clean the black rollers where the paper would come out. You might have a few problems getting to them from the front so I would open up the back and see if you can get to them from there and clean the little grey rollers while you are there wont do any harm. :)
Careful you don't pop the black rollers out of position or you will get constant jams.
:) Good Luck
Dec 08, 2008 | Brother IntelliFax-2820 Laser Fax
Konika Minolta Bizhub 7228
Have the document feeder rollers been replaced? Also how about the Clutches for above rollers been replaced?
Jan 04, 2008 | Office Equipment & Supplies
54 people viewed this question
