Question about RCA Cable Modem DCM315R (11603540)
RCA router how do i port forward to port number TCP 6112?
  • 25 Answers
First, go to: 192.168.0.1
the username is blank, and the password is "admin"
go to the advance tab
click forwarding
fill in the information, and then click "enable" to the far right of it
then click "apply" at the bottom of the page
Posted on Jan 12, 2008
Connect two tigerswitch 6724AL2 via fiber port
How do I open ports in the Virtual Server? pix.gif pix.gif pix.gif You need to forward the ports used by the application to the server running the application in the Virtual Server, which is present in the router's management screen, as follows.
  1. Open your web browser, type in the router's IP address (standard: 'http://192.168.2.1') and press enter.
  2. Click on Login, Advanced Setup, NAT, Virtual Server.
  3. Enter the port details and enable it as follows:
Private IP Private Port Type Public Port 192.168.2.x xxx TCP xxx 192.168.2.x xxx UDP xxx To access the application, you can open up the ports specific to the application in the special application, which is present in the router management screen as follows:
  2. Click on Login, Advanced Setup, NAT, Special Application.
Trigger Port Trigger Type Public Port Public Type Enabled 3724 TCP 3724 TCP Y 6112 TCP 6112 TCP Y 6881 TCP 6881-6999 TCP Y
* The port numbers given are just an example. You need to open the ports depending on the application you are using and should get the information from the application provider.
Jan 05, 2011 | SMC TigerSwitch SMC8612T
Tip
Solution for War Craft 3 behind Linksys routers.........
As the application requires certain ports to be opened on the router,try to follow the steps below to configure the router. Since you are connecting behind the router, you are going behind a NAT firewall.Therefore, you would need to allow ports for the remote access application to go through the firewall. You would need to know what port number application uses. You can check with the program manufacturer for the information, or see the Help menu.
For routers with old firmware versions (without the Cisco web interface):
1.Open Internet Explorer.
2.After "Internet Explorer" opens, please typehttp://192.168.1.1 into the "Address Bar" and click GO.
3.The "Enter Network Password" window will appear. Skip username and type admin (admin is the default password) as the password,and click OK.
4.You will need to click on the Advanced tab to the very right. Once the "Filters" area appears, please click on the Forwarding tab.
5.Once the "Forwarding" area appears, click the Port Triggering button. Once you've done this, a new window will appear.Enter the ports needed to be opened > Click Apply
For later firmware (that has the Cisco web interface)
4.Click on "Applications and Gaming" then click on the "Port Triggering" Sub tab. Enter the ports needed to be opened >Click Save Settings.
Example:
Customized Trigger Port Range Incoming Port Range
Application From ~ To From ~To
WARCRAFT 6112-6112 6112-6112
WARCRAFT 6113-6119 6113-6119
Hope this help everyone that has problem with the game.
on Jan 05, 2010 | Linksys Wireless-G Broadband Router
Tip
How to Upgrade Firmware of Linksys routers........
Example:
on Jan 05, 2010 | Linksys Wireless-G WRT54G Router
I am trying to portforward azareus ip adress 192.168.0.1 dlink dir 165
Port-forwarding allows connections from the network, i.e., to TCP port #80 at the IP-address assigned to your router, to be "forwarded" (much like a switchboard operator at a university)
to any specific TCP port (but usually the identical port-number) on a SPECIFIC computer "inside" your network.
If your router is '192.168.0.1', then it probably will give-out IP-addresses like '192.168.0.100'
and '192.168.0.101', and '192.168.0.102' to the first 3 computers on your network.
So, "port-forwarding" is used to designate one of those 3 IP-addresses as the one to receive/process all the 'TCP port #80' traffic.
On the router's web-interface, on the "port-forwarding" page, just add an entry for 'TCP port #80'.
Dec 22, 2010 | Computers & Internet
How to fix nat settings to open /on router
I presume you need this for Xbox Live?
if so you need to go onto your router and configure port forwarding for these ports:
  • TCP 80
  • UDP 88
  • UDP 3074
  • TCP 3074
  • UDP 53
  • TCP 53
  • this procedure will vary slightly for each router manufacturer but will usually have a port forwarding section and boxes for the port numbers and a drop down or radio button to specify either TCP or UDP
    Feb 28, 2010 | Microsoft Xbox Console
    Belkin 54 g wireless router....cant find on the net. need to port forward to host blizzard.net games HELP!
    Make sure your private IP address is statically set.  Your public IP address is obtained from your ISP and is what other users will be connecting to.  You can not manipulate your public IP address so if your ISP is running DHCP, it is very possible that your public address is changing.  Also if you are frequently disconnecting your modem, it is possible your ISP is leasing you a new public IP address each time.  So try to keep things as static as possible.  As far as the battle net stuff.
    Diablo, Warcraft II Battle.net Edition, and StarCraft:
    Allow port 6112-6119 TCP and UDP out and in
    Diablo II:
    Allow port 6112 TCP out and allow established sessions in
    Allow port 4000 TCP out (realm games)
    Allow port 4000 TCP out and in (hosting open games only)
    Warcraft III:
    Allow port 6112 TCP in (hosting custom games)
    Allow port 6113-6119 TCP out and in (hosting custom games if you've changed the default port in the Options/Gameplay screen)
    If you are still having problems after you open up the required ports, try opening 116(TCP) and 118(TCP). I don't really know if these ports are required or not.
    I have had people tell me that opening up those two ports have helped them connect to battle.net.
    Hope that helps.  For manipulating ports in your router I suggest consulting your user manual, or online FAQ.  Save your router config before applying any changes, and always remember, opening up ports subjects you to different types of security threats so be aware that is a risk you are taking.
    Mar 12, 2009 | Belkin Computers & Internet
    World of Warcraft
    Sounds like you need to do some port forwarding.
    World of Warcraft communicates on port 3724 with the TCP protocol. The patching process requires port 3724, 6112, and 6881-6999. Once again to download the patches for World of Warcraft you should forward the following ports.
    3724 TCP6112 TCP6881-6999 TCP
    If you can not forward ranges of ports and are only planning on having one computer playing WoW, just forward ports 3724 TCP and 6112 TCP. The 6881-6999 port range is mainly used where multiple computers on a network may be trying to play WoW at the same time.
    Ventrilo: From their web site: Click on the "Port number" input box and enter the servers port number. The program will automatically display the default port number of 3784 but you can change this to what ever the server needs it to be.
    So forward 3784 or the port number you chose.
    http://portforward.com/english/routers/port_forwarding/Motorola/SBG900/SBG900index.htm for a walk through on how to do the forwarding.
    Hope that helps!
    Jun 02, 2008 | Arris SURFboard SBG900 (49402201900) Modem
    Port Forwarding with BR-6104K
    hope this helps
    In vegas to forward a port with the zytell modem Sprint/Embarq our DSL provider you have to bridge your modem first and allow your router to pull your IP from your ISP. Then you can forward the port.
    If you have DSL I would start by going to my ISP's website and look for instructions for setting up port forwarding or Bridging your modem.
    Bridging your modem passes off traffic control to your router. on zytell modems you can also forward ports but bridging is much less technical
    I have not run into CABLE providers cable modems having to do this
    did you allow that port in your computers firewall?
    Did you set up a static ip on the computer you want to forward your port for? sounds like it is required for you router
    User manual: http://www.edimax.com/images/Image/manual/Wire/BR-6104K/BR-6104K_M.pdf
    instruction site
    http://portforward.com/english/routers/port_forwarding/Edimax/BR-6104K/ICUII.htm
    to test the port connection you can go to http://whatsmyip.org on the left pane click on port scanner and choose custom to scan the port number you are attempting to open. you do have to have the application that will use that port running to get a result if it is a game ALT+TAB should let you out of the game without shutting it down to open a web browser this tool can save you a lot of time testing the port it will give you a open status when you have succeeded.
    Mar 29, 2008 | Edimax BR-6104K Router (br6104k)
    How do I open ports in the Special Application?
    To access the application, you can open up the ports specific to the application in the special application, which is present in the router management screen as follows: 1. Open your web browser, type in the router's IP address (standard: 'http://192.168.2.1') and press enter. 2. Click on Login, Advanced Setup, NAT, Special Application. 3. Enter the port details and enable it as follows: Trigger Port Trigger Type Public Port Public Type Enabled 3724 TCP 3724 TCP Y 6112 TCP 6112 TCP Y 6881 TCP 6881-6999 TCP Y * The port numbers given are just an example. You need to open the ports depending on the application you are using and should get the information from the application provider.
    Feb 19, 2006 | SMC Barricade 7004
    Feb 19, 2006 | SMC Barricade 7004 Router
    RCA Cable Modem DCM315R (11603540) Logo
    456 people viewed this question
    Top RCA Computers & Internet Experts
    Julie Endres
    Jose Velazquez
    Jose Velazquez
    Are you a RCA Computer and Internet Expert? Answer questions, earn points and help others
