Question about Dayton Electric Heater
Dayton 3e219e unit turns on and fan blows for apx 5 sec but will not light. I did just put a new inginter on it any ideas?
  • Cntrctr Dec 23, 2008
    I have the same problem. I followed the instructions, checked the eye, cleaned the filters, etc. But my heater still will not ignite. Ant other suggestions?
This is normal operation for this heater IF it does Not light. This has a photo 'eye' that looks for the flame and if it does not see the flame it will shut the unit down. It could be one of a few things. First.....Does the ignitor get hot and 'glow' cherry red? If not, either the ignitor is bad or the ignition board may be bad. You can check this by removing the top and watch it (the ignitor)while you plug it in, just be careful for the fan as it should start. If the ignitor glows then it is not the ignitor or the board. At this point you can make a sure bet it is in the air pump circuit. There are several filters in this unit. Very carefully take the four screws out of the back to remove the cover( it is a rectangle piece about 3 inches by five inches by 1.5 inches...about as this is off the top of my head) These are very fragile so be VERY carefull. There are three filters in this. One is removeable from the outside before anythis is disassembled. It is like a sponge and must be cleaned on a regular basis. Inside there is a cork like gasket TAKE CARE NOT TO BREAK IT. If you kreak it you must replace it. They do not work very well spliced together. Now that you are inside check the other two filters. One is very small like the size of a pencil eraser or smaller. Note where it came from so you can replace it afler you clean it. The other one is quite larger and is like a piece of filter paper. When it is new it is white. They clog up with the carbon from the air pump. You can carefully try and clean it but your best bet is to just replace it. Next clean and inspect the cover. They do crack on occasion and when they do it is LIGHTS OUT for the heater. Look Very close as it may be just a hairline crack, but that is all it takes to stop this from operating. Take the hose that leads to the nozzle off at the pump and blow a little air through it and make sure you are getting fuel spray out of the nozzle. Make sure the fuel line is clear and the filter, if it has one and it should, is clear as well. Reassemble and be carefull on torquing the screws on the cover. If you over tighten them SNAP the cover cracks and it's LIGHTS OUT again. The majority of these that I have worked on, about 98% the problem was either the inner filter and/or the cover was cracked. GOOD LUCK
Posted on Feb 15, 2008
I posted previously after carefully following the cleaning process. I found a parts supplier and spoke with Tech support. Going through the problem with them they mentioned the disk behind the filters that siphons the fuel out of the tank. My fan rattles when spinning. I dismantled the filter compartment and exposed a shattered pump disk. I should have the part and a filter kit in a few days!
Posted on Dec 23, 2008
Dayton gas furnace model 3e385 works and lights but as soon as fan comes on the unit shuts off and lights again wondering what was wrong
Check heat exchanger for cracks or holes which will cause the fan to blow out the flames. The flame sensor on the pilot or burners has to be in constant contact with flame to operate normally. If the flame is put out by a cracked exchanger the exchanger or furnace needs to be replaced.
Nov 22, 2011 | Dayton Gas Furnace Heater
Been sitting for a while, filled with fuel, turn on runs for 5-10 secs then shuts off and light blinks ?? model 3ve51
You need to pull a little maintenance on this unit. Locate and remove the burner tray, on the tray you will find a flame sensor, this detects flame and permits the unit to run. These collect carbon deposits, dirt and the occasional insect seeking shelter. So clean it with windex and a soft terry cloth rag. Next is the fuel nozzle, find it , remove it, and they say you can not clean these but I say q-tips, tooth pick and carb cleaner will do the trick just be careful not to damage the nozzle. Directly behind the nozzle is a screen these like to corrode durring storage, so clean it good too. Put assembly back together and inspect all fuel lines for holes, leaks,or dry rotten conditions. Now inspect fuel lines to the filter, if an in line filter (small plastic filter) clean with compressed air and blow gun, blow air backwards thru the filter instantly cleaned. If a large oil type filter replace it with a new one and do not forget to fill the filter before putting it on.Make sure that your fuel is clean and no water has developed in it from condensation, if water is present drain fuel and clean out the tank put new fuel in and it should now work for you. Happy heating
Dec 22, 2010 | Dayton (4LX41) Heater
I need ignitors for heater model number 3e219e
The part number for the ignitor kit is PP200 (new number) Old number was PN HA 1000.
Also from the parts list, this PN: 102548-03
Parts list:
http://www.bealsmotor.com/105553_219E.html
Burner head parts: (Ignitor is item 5)
http://www.bealsmotor.com/105553_burner.html
Actual Ignitor Kit:
http://www.amazon.com/Desa-International-Hot-Surface-Ignitor/dp/B000DZDPVI $39.95 + shipping
Downloadable manual: http://www.desatech.com/manuals/Construction%20Heaters/105553-01.pdf
Dayton Portable
Oil-Fired Heaters
PARTS:
Ph. 1-800-323-0620
24 hrs / 365 days a year
105553
2E510F, 2E511F, 3E218E, 3E219E
Please provide following information:
-Model number
-Serial number (if any)
-Part description and number as shown in parts list
102548-03 (part you need)
Thanks for choosing FixYa,
Kelly
Nov 19, 2010 | Dayton Heating & Cooling
Have 30,000 btu Dayton heater m#3e3665 when reaches temp. fan
Hi blow heater out with air line flame sensor could be dirty check out pressure switch jump this out see if it lights
Feb 09, 2010 | Dayton (3E379) Heater
I need a service manual for a Dayton 3e219e heater.
I have a manual for a Dayton 3E219E. If you want a copy email me at Edwards0202@aol.com and put "HEATER MANUAL" in the subject line. I can scan it in and email it back to you. This manual is for 2E510F, 2E511F, 3E218E and 3E219E. I also found a great web site for parts for all these models as well: http://www.bealsmotor.com/
Jan 08, 2010 | Dayton E50 Heater
Dayton heater Model 2E400. Does the fan draw the air in and than blow the heated air out of the botton of the unit? Does fan turn CCW or CC.
yes, you have the direction of flow correct. The rotation of the fan will be marked on the motor of the fan
Jan 07, 2010 | Dayton Electric Heater
Hi, looking for a Dayton Oil Fired Heater Manual for model 3E218E
I have a manual for a Dayton 3E218E. If you want a copy email me at Edwards0202@aol.com and put "HEATER MANUAL" in the subject line. I can scan it in and email it back to you. This manual is for 2E510F, 2E511F, 3E218E and 3E219E. I also found a great web site for parts for all these models as well: http://www.bealsmotor.com/ They might be able to get you a manual for you specific model: Dayton E52
Dec 11, 2009 | Dayton E52 Utility Heater
I need a service manual for a Dayton oil fired 350,000 BTU heater.
Nov 30, 2009 | Dayton E50 Heater
Dayton Electric Heater Logo
546 people viewed this question
Top Dayton Heating & Cooling Experts
Paul Carew
Mack Baxter
Dan Webster
Dan Webster
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
