Question about Panasonic CQ-DFX972U CD Player
Blowin fuses fuse panel has 15amp fuse do i still need in-line fuse on battery lead
  • 4,102 Answers
It is always best to have fuse on battery lead but as long as the leads are definately going through the fuse panel then you should have no problem but if you have the fuse and it blows then their is deffinately something wrong.
The fuse on the battert leads is a backup as long as the wires are running through main fuse panel the reason for extra fuse is because the main fuse works other things running off it not just the one for radio so the fuse on the battery lead is their so that if something wrong with the unti then that fuse blows and only that 1 unit wont work but if main fuse blows other things might not work so its always best to have inline fuse so that only the 1 unit stops working incase of problem.
so its not vital you have one but it usefull so that you know where the problem is coming from and saves time tracking down fault
Posted on Jan 12, 2008
Where where do i find the fuse for the speedometer on a 2001 Crown Vic
There are three fuse's for the instrument cluster , all located in the central junction box (fuse panel ) inside the vehicle ,under the dash !
Fuse # 14 a 10 amp , fuse # 23 15amp. and #6 15amp . Look behind right and left kick panel . But i don't think this is a fuse problem , gauge itself could be bad .
Dec 09, 2016 | 2001 Ford Crown Victoria
2002 van. Which fuses do I need to check/replace for instrument panel lights?
Fuse #2 15amp , fuse #36 5amp. ,location central junction box .
Central Junction Box
Below left side of I/P, near left kick panel
Fuse #4 under hood fuse box ( BJB ) battery junction box
Sep 20, 2015 | Ford E-250 Cars & Trucks
My 2008 suzuki grand vitara keeps blowing the fuses for the ACC outlets. both are 15AMP, but even with nothing plugged in, nothing down in the outlets and even with larger AMP fuses, they keep blowin
If you use too large a fuse, the wiring can catch on fire, and the whole car could burn up. You'll need an auto electrician to trace that problem. You can remove any bulb and unplug any device that is on the Acc(essories?) circuit; then see if a fuse will stay; start replacing items till you blow the fuse. It seems like a dead short which can surely melt wires if you keep taking chances. good luck.
Feb 14, 2015 | 2008 Suzuki Grand Vitara
I need to know which fuse is for the headlights in my 2001 Hyundai elentra. I have no diagram.
The Headlight fuses are in the engine compartment fuse box. they are (2) Blue- 15Amp fuses that will be right together at the end of the fuses of which are in a line. The very end one is for the "Low" beams and the next 15Amp fuse is for the High beams. They will be right in line with 2 Red- !0A fuses
Jan 07, 2015 | 2001 Hyundai Elantra
'05 HD FXSTD ......New Battery exploded!! When putting another battery in , the battery 15amp fuse blows. Where to start diag??
you'll need to look for a dead short in the system use a volt ohm meter to trace the short to verify short touch + lead from volt meter to + battery wire then touch the = lead to ground then trace from there
Sep 17, 2012 | Harley Davidson FXSTD Softail Duece...
Replace fuse on ge microwave oven model no. jvm230
remove all outer screws, take off cover, has fuse panel inside, probably ceramic style fuse ?
Jan 30, 2011 | GE Microwave Ovens
Fuse box diagram for volkswagon beetle
depending on the vehicles engine configuration it should be fuse no. 42 in the fascia fusebox.
Please try this first and drop me a line if it´s not no. 42, i´ll post a complete list and diagram then.
Jun 25, 2010 | 2001 Volkswagen Beetle
F 450 instrument cluster has no power and is inop need to trace wires to power source
Interior fuse box fuse no.33(15amp) supplies power in run/acc postion to BK/PK wire pin 19 of cluster.
Interior fuse box fuse no. 45(10 amp) supplies power in the start or run postion on the RD/YE wire pin 20 of cluster.
Interior fuse panel fuse no. 41(10amp) supplies power to the battery saver relay on LG/OG wire pin 11.
Interior fuse panel fuse no. 35(10amp) supplies power to interior lamp relay on BK/LG wire pin 12.
The last 2 are hot at all times.
Apr 11, 2009 | 2004 Ford Super Duty F 450
Cant find fuse for my radio in 05 Taurus
There are several fuses to check. 2 fuses to rear control unit are in the battery junction box(underhood fuse panel) are no. 27(5amp),no. 17(20 amp). In the interior fuse panel 3 fuses to the intergrated control unit are fuse no. 32(10amp),no. 33(15amp), and no. 22 (15amp).
Feb 26, 2009 | 2005 Ford Taurus
Fuse problems
output leads shorted by chance?
Jul 05, 2007 | Scosche Industries Scosche High...
Panasonic CQ-DFX972U CD Player Logo
130 people viewed this question
Top Panasonic Car Audio & Video Experts
xxxxxx xxx
Are you a Panasonic Car Audio and Video Expert? Answer questions, earn points and help others
