Question about Kenmore Dryers
Dryer wont run
Push start and timer clicks
  • Anonymous Jan 02, 2009
    The lights light up, but when you hit start, nothing happens.
  • 3,230 Answers
Well most gas dryers have one thermal fuse and some have two thermal fuses wired in series with the motor. If any of the thermal fuses are blown that could be one of the reasons of your dryer not starting. So first of all you may check out the fuse.
Good Luck!!
Thanks for using FixYa!!
Posted on Jan 26, 2011
My roper dryer wont start
Sid you test the thermal limiter fuse in line to the dryer motor.
Oct 06, 2017 | Computers & Internet
Kenmore 600 series dryer.model # 110.67622600. wont start. light goes on & off when i push and release the door switch. when i push the starter switch it make a clicking buzzing sound. more noise when...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jun 27, 2011 | Kenmore 67632 Electric Dryer
heatman101
Jun 27, 2011 | Dryers
Dryer makes a clicking sound in the timer when you push the start button, but will not run or heat up, drum will not turn, it will not come on, any suggestions?
sounds like the motor, there maybe a reset on it. if there is it will be on the wires running to the motor, there will be two one trips the other resets. Here is a website that may help:
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
Dec 23, 2010 | Kenmore Dryers
I have model #110.76712645 The dryer does not
open the door and push on the door switch paddle,if it doesn't click the door switch is broken.when you open the dryer door while it's running the dryer should shut off,if the switch breaks the dryer will either not run or will stay running,if the switch is clicking and is good then you have a broken push to start switch.this is the button you push on to start the dryer,this could break in the on position.let me know what you find
Jul 14, 2010 | Kenmore Dryers
I have a Kenmore gas dryer model 97591220. wont
Disconnect power to the dryer and remove the screws attaching the console rear panel to the console and pull the panel off.
Inspect the wires connected to the timer and ensure a snug fit connection. Clean the connectors and terminals then reseat it several times to ward off dirt within the connectors.
Reconnect power to the dryer and start it; replace the timer (part number 3398195 ) if the dryer still won't stay running. Unplug the dryer and pull the timer knob off the console. Remove the screws securing the timer to the bracket and remove it. Secure the new timer in place then disconnect the wires from the old timer one at a time and connect it to the corresponding terminal on the new timer.
Push the timer back into position on the console and secure the console rear panel in place.
Apr 14, 2010 | Dryers
My 1987 GE Dryer, Model # DDE5300GALWH,will not run all the time.
sounds like you need a new timer you can actually take the timer apart to check for a burnt connection
Jan 07, 2010 | GE Dryers
Wont start
Is the motor running but the tub not spinning? You can tell by feeling for air movement out the exhaust after you start it or by listening to the dryer (put your ear against it and listen for a humming sound).
If motor is running your belt is broken and will have to be replaced.
Sep 02, 2009 | Dryers
My whirlpool dryer wont start.
check the door switch and also the push to start button. Timers will advance even if the unit is not on
Mar 30, 2009 | Dryers
Dryer won't stop running
the dryer wont stop running only when open door will it start a fire?
Sep 14, 2007 | Kenmore 62802 Electric Dryer
Dryers Logo
83 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
