Question about Kodak EasyShare C703 Digital Camera
How to replace the battery door on a kodak digital camera c703
Can you please help. I'm trying to replace a battery door on a kodak c703 camera. Thanks for your time!
    Problem Solver:
  • 30 Answers
If it's the door you are needing, try ebay. I've seen people sell items simply for parts. Good Luck!
Posted on Jan 12, 2008
How do I formate memory card
The C703 works with MMC and SD cards, 2GB and smaller. It will not work with higher-capacity SDHC cards such as your 4GB card.
Apr 03, 2013 | Kodak EasyShare C703 Digital Camera
My c703 won't format a new memory card. The old memory card is full (2GB), but I've tried two NEW Lexar 4GB cards and neither will format. Help!
Hi, The reason neither 4GB card will format is because that camera is only able to support, at most, a 2GB card. I'd suggest returning the 4GB card and getting another 2GB one.
May 13, 2011 | Kodak EasyShare C703 Digital Camera
I have a camera Kodak EasyShare C703. Every time i turn it on, it say lens error 115,0,0,106. Its been sitting at the top of my closet for about a year. Please help! Thanks
This is such a common fault that I hope you don't mind me pasting my stock generic answer below. No point in reinventing the wheel!
Stuck lenses are probably the most common reason that compact digital cameras get thrown away, but there's a fair chance of recovering use of your camera again
The fault is commonly caused by dirt or grit blocking the mechanism, or due to it having suffered a recent fall. Another common cause is that the camera was in a pocket or bag and the power button accidentally activated and tried to open the lens against resistance. The mechanism may have simply become dislodged or there may be parts which have broken.
If your camera is still under warranty and has definitely not been subject to misuse then contact the Kodak service department in your country to find out about a free repair. If the warranty has expired though a professional repair will far exceed the cost of replacing your camera. You will therefore have nothing to lose by trying to fix this yourself.
Please click here and you will be taken to an excellent article provided by the Camera Repair website. For the most part, you'll be guided on how to physically manipulate your camera to try and clear the fault.
If the link doesn't work then cut and paste the following address into your browser:-
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Good luck, I hope you manage to use this information to fix your camera. Please take a moment to rate the free answer I have provided for you.
Sep 24, 2010 | Kodak EasyShare C703 Digital Camera
How do i repair a lens on a kodak easy share C703 that will not retrack?
hope i have interpreted this correctly.. It does not move out to full extent or soes not pull back all the way.. no matter.. try this kludge fix....
OK you are probably going to think I am loony giving you this advise But No I am completely sane!
Get a can of compressed air OR acces to a compressor at your local garage Get them to fit the triggered air blower tool to it.
Blow around the lens in all the extension joins the firmly slap it in the palm of you hand with the side of the camera making contact with you palm. Do the procedure two or 3 times and inbetween the slaps turn it on to activate the lens mechanism. I have now fixed about 180 of these cameras with this method. I obtained the fix from Sony who charge $90 to do exactly the same. Keep at it as it will eventually work. One tip, make sure the battery is charged before you do this.
Please rate my help++++Thanks for using FIXYA
now 180 cameras fixed by this trick works on all brands and these types of cameras
Oct 22, 2009 | Kodak EasyShare C703 Digital Camera
Kodak easyshare c703 - even with brand new batteries it often won't turn on - just flashes red. may then turn on later in day,totally unpredictable and annoying!!
Sounds like a loose connection in the energy pack... this will require a professional to crack it open and re connection the loose connections...
Please rate advise.
Jun 22, 2009 | Kodak EasyShare C703 Digital Camera
Camera will not turn on
This problem is frequently due to corroded battery terminals inside the camera. Remove the batteries and wipe the terminals with a soft cloth (heavy corrosion may require a fine wire brush, steel wool, or sandpaper). Remove any residue left in the camera by the cleaning. Clean the terminals on the batteries in the same manner, and then replace them in the camera. This cures most problems, but if it doesn't work for you, check the Kodak troubleshooting guide at:
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
It uses a simple Q&A format to diagnose problems and propose solutions.
Jan 14, 2009 | Kodak EasyShare C703 Digital Camera
Slat water in camera
Digital cameras will not tolerate any moisture inside them. Sorry to say you will have to get another.
Aug 16, 2008 | Kodak EasyShare C703 Digital Camera
LCD Screen
I was told by a Kodak tech that the cameras are identical. The different numbers were a marketing thing.
May 31, 2008 | Kodak EasyShare C743 Digital Camera
Kodak EasyShare C703 Digital Camera Logo
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
