Question about Maytag MAV2755A Top Load Washer
Maytag MAV2755AWW Washing Machine is leaking water
The water is not leaking from any of the hoses, the water coming from the bottom of the washing machine. Is it the pump?
  • tinkthis71 Jan 31, 2008
    my top load washer is leaking water from the bottom...it looks like the water is coming from the front area of the washer or somewhere close to the front. Its not the hoses as I have checked and they all seem in good contidion.
  • Anonymous Mar 31, 2014
    Keeps leaking while it is washing and says overflow
    Sniper:
  • 68 Answers
It sounds like you have a leaking pump. The pump is easy to replace:
#1 Use a shop vac and pull all the water out of the drain line. This will keep you from having to clean up about 1 gallon of water off of the floor.
#2 Lift the front of the machine enough for you to get under and see.the pump just inside the front of the washer.
#3 Lift the 2 retaining clips off of the pump. This will allow you to pull the pump off of the motor.
#4 Remove the 2 clamps off of the hoses.
#5 Install the new pump into the hoses, and reinstall the clamps.
#6 With the retaining clips installed into the motor housing, install the pump.
#7 Attach the retaining clips, and set the washer back on the ground.
You have now replaced the washer pump.
If you have any questions, let me know
Please rate this solution
Posted on Jul 29, 2008
During the washing cycle when the agitator is twisting the inner tub keeps moving making a rubbing noise. I have tried moving the outter tub as well as the clothes in the washer to make sure it is not off balance but nothing is working.
Posted on Jun 02, 2008
    Scholar:
  • 196 Answers
There are several places to wich tohis water could be coming from. Knowing where you are seeing the water when it first appears would help us to solve this problem.
Posted on Jan 12, 2008
Maytag washing machine leaking
it could be coming from different sources. Most likely is the hose. You might need to replace hoses that bring water to the machine, but first check that they are not loose or have cracks that could cause these leaks to occur.
Jan 05, 2014 | Maytag Washing Machines
Mav2755aww spins slow. you can stop the tub easy passive connection not direct connection
You will need to replace the thrust bearing on your unit if it is not reaching full spin. It comes with instructions on how to replace it. Here is the "thrust bearing kit" you need. It is a really simple project to complete.
Oct 27, 2012 | Maytag MAV2755AWW Dependable Clean Top...
Water is leaking from the bottom of the tub straight down. What's up? Thanks, Paul.
It may be a water hose leak or where the water hose connects to the washing machine. With the power off, use your finger to trace the water leak. Also use a flashlight.
Aug 17, 2010 | Maytag Washing Machines
There is a leak at the bottom of the washing machine. Water is coming out the bottom front and bottom left.
The leak is from the drain hoses or the fill pipes.
No need to worry.It's a common issue and easy
to fix of your own.
Sep 01, 2009 | Maytag Washing Machines
Maytag top load washing machine leaking water from bottom
The machine is leaking water from the bottom, I think the leak is in the area near where the motor is mounted. Before we noticed the water comes from underneath the washer, we smelled like burning rubber.
Al Bana
Jun 26, 2009 | Maytag PAV2300 Top Load Washer
Washing machine is leaking from bottom of machine
Wow, this washer is very old. im sure the drainage hoses will need to be inspected or replaced asap. i would also check the pump housing for cracks as well. make sure the water inlet valve assembly ins in good condition as well. Replace any hose or valve that is leaking or, damaged.
Jun 05, 2009 | Maytag Washing Machines
Washing machine
Try replacing the rubber washer inside the female side of the hoses
Aug 29, 2007 | Maytag Performa PAV2200
Maytag MAV2755A Top Load Washer Logo
594 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
