Kenmore ultra fabric care heavy duty 80 series wont spin
Washer will not spin
  • 3 more comments
  • alexina Jan 12, 2008
    checked that it is clear, I think the belt is broke when I lie the washer down you can see black burt belt but you cant get to the belt just a small edge of it, I spun it and can see damage, but I can't figure out how to get to it to change it. Any help would be much appreciated...thanks
  • Anonymous Mar 21, 2008
    I have an identical machine with the exact same problem. I tipped the machine over and can see that the rubber ring under the spin is broken with the black crumb all over the floor. The machine goes through the cycle but will not spin. It will drain the water. I am looking for parts to replace the rubber ring with no luck.
  • smelp Apr 06, 2009
    have the same problem will drain but not spin, but everything seems encased, how do you find the belts?
  • Anonymous Apr 19, 2009
    hI, any body can tell how to take the motor apart in order to replace the drive coupler #100017? Thanks a lot.
  • resv78f9 May 02, 2009
    i have this washer as well and it to will not spin.it does not look like the belt hooks to anything. how do you fix this without spending a lot of money.
I contacted partsdepotonline.com. They were very helpful. The problem is a broken coupler. Part #100017 from Parts Depot. Part #275753A from Kenmore. Parts Dept is cheaper.
Posted on Mar 14, 2009
    President:
  • 1,294 Answers
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Posted on Jan 12, 2008
You can get most parts for these washers at partsdepotonline.com. PH# 1-877-334-9991. I have had mine for about 16 years ands have yet to not find what I need at this site.Good luck.
Posted on Sep 13, 2008
Wont spin, lifted and found a pile of shredded rubber - what part is this and how do i fix it?
Posted on Apr 11, 2010
F06
Posted on Mar 31, 2008
I have a kenmore ultra fabric care washer heavy duty 80 series with electronic temperature control and I can only get hot water not cold.
If it used to work and now does not, either the valve that controls the water inlet to the hot is bad or the temp sensor in the machine is bad. What is the whole model number?
Mar 22, 2015 | Kenmore Washing Machines
Is there a belt on a kenmore ultra fabric care heavy duty 80 series
No. What is the problem you are having? Let me guess, it's not spinning or agitating?!
What is the model number listed under the lid?
Nov 03, 2012 | Kenmore 24032\24036 Top Load Washer
I have a Kenmore/Ultra Fabric Care IV - Heavy
Sounds like the machine is stopping to me, could be the off balance switch at the rear off the machine. You should know if its getting to the spin cycle.How wet are your clothes ? Hope this Helps.
Sep 15, 2009 | Washing Machines
Direct drive-type Kenmore washer will not spin.
Check the video at the following link. I think you will find it helpful. Hope so and best wishes.
http://www.youtube.com/watch?v=WLPGs2UMUJc
Sep 14, 2009 | Washing Machines
Kenmore washing machine will not drain
Replace the timer.
This is a neutral drain machine. If there is no natural pause in the timer at the end of the rinse cycle the timer is bad.
Mar 13, 2009 | Kenmore Washing Machines
How do I take apart the outer shell to my Kenmore -Series 80 washing machine?
I have Serial # CF2467934 Model # 92588210 Kenmore Ultra Fabric Care Heavy Duty 80 Series. The top agitator is stripped out, how do I take it out to replace it?
Aug 11, 2008 | Washing Machines
Washing Machines Logo
4,370 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
