Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Lint On Clothes
After the clothes washes, there is a lot of lint on the clothes.
  • Anonymous Mar 22, 2014
    after washing there is lint on clothes
  • Anonymous Mar 30, 2014
    Clothes have lint fibers after washing. Is there a lint filter I can clean?
    Sergeant:
    Champion:
  • 310 Answers
Seperate the ones that are leaving the lint
I’m happy to assist further over the phone at https://www.6ya.com/expert/james_1cb31da1bc8c6102
Posted on Jan 11, 2008
6ya staff
SOURCE:
I am getting a lot of lint on clothing is there a cleaning process with my smart drive pride 5.5 fisher & paykel washing machine
clean the lint filter in the machine
put any clothes that are likely to shed lint or are susceptible to collecting lint in a wash bag before putting in the machine
Oct 17, 2017 | Fisher Washing Machines
My washer puts a lot of lint on the clothes after having been washed. How can this be stopped. no lint on my clothes.
Do not wash items like towels rags dish cloths etcetera or other lint producing clothes in the same load. This is not a washer issue.
Jan 17, 2017 | Washing Machines
My dark clothes come out of the washer covered in lint. What's up with that?
The lint may be that a particular garment should not be washed in a machine. Don't wash clothes with something like a bath rug.Be sure pockets are empty and that you are getting disolved paper on your clothes. The color of the,lint might give you a clue about it's source. I have often wondered why lint in my belly button never matches my clothes, so lint can be mysterious stuff. good luck.
Jan 24, 2015 | Washing Machines
Where is the lint filter? Why does it put lint all over clothes?
lint is usually removed in the dryer. If you have lint on clothes after going through the wash, you probably left something in a pocket somewhere.
Sep 20, 2014 | Maytag Washing Machines
Lint all over Clothing after rinse.
My washer accumulates lint between the wash tub and the outer chamber. Whenever you wash a load, all the past dried up lint gets reactivated into the new wash water.
If you get a refrigerator or dryer lint brush, you can reach this area and brush out the accumulation. Also the area above the wash tub can get clogged with lint. If you look under the lip between the tub, you can see the fabric softener/bleach channel dispenser, a lot of lint can accumulate there as well.
Clean both areas after a recent wash load when the lint has softened and is easy to scrub off. For safety's sake, unplug the washer. Be ready to be grossed out! I clean my washer every now and then to keep the lint down.
The washer will smell nice and clean after getting this lint/dirtball out. To maintain this lint free environment, see below.
If this fails and is not the problem, go to a thrift store and purchase the cheapest 100% pure wool clothing, some dark colors, and some white. The wool acts like a magnet for lint and will attach itself to the wool before it attaches to your clothes. It can be used over and over if you hang it out to dry. It will get felted and covered with lint.
Mar 15, 2014 | Roper Washing Machines
Lint on clothes
put the lint up your ***
Feb 13, 2012 | Roper RAX4232KQ Top Load Washer
Clothes are collecting a lot of lint when washing. Is there a lint filter? I have already tried running vinegar through a cycle.
not knowing the make and model,, I can offer you this ,, if your machine actually has a lint trap it will be located right before the pump under the machine, also,, try using a little more detergent, this helps cut down on the lint left in the machine and on clothes, if you reply to this feed i will try and locate your machine and check on the filter
Jul 24, 2011 | Washing Machines
Dark clothes have lint left on them. what could help this problem?
Are you sure it is lint and not soap? My washer does this, and it looks like lint, but it is soap.
If it is lint, always keep the lint collector inside the agitator clean.
If it is soap, and this might work for lint:
1. Turn clothes, particularly black clothes, inside out.
2. Use a concentrated soap with little or no filler.
3. Use less soap than normal.
4. Fully dissolve soap before adding clothes.
5. Run rinse cycle again after completing full wash cycle.
Jun 22, 2011 | Admiral AW22 Top Load Washer
LINT STICKS TO MY CLOTHES IN WASHER
linting is caused by a few things
firstly what sort of soap poweder do you use
i recomend good quality powder
do not wash clothes too long as what you are doing is rubbing all the fibres out of them
good quality washing powder only last about 6 minets in water and after that it looses its qualiteseg
the PH changes in the water
you may be using too little soap powder and this also depends on water quality eg too hard or soft water
is the water levels set corectly
do not mix washing
eg towels with jeans as the lint will come off onto jeans
try using delicate wash on different fabric as the adgitation is different on different cycles
try using warm wash and not cold machine is probable ok but wah times are important
good luck
Nov 27, 2007 | Crosley CAWC529JQ Top Load Washer
Washer leaves too much lint on clothes
There are many things that cause lint. Some are easy to figure out, some aren't. Here are some of the most common things: 1. Separate clothes that are lint givers from lint takers (i.e., sweaters are lint givers and should not be washed with cotton which attracts lint). 2. Check clothes pockets for tissues or paper. 3. Don't overload the machine. 4. Use enough detergent to hold the lint in suspension. Read the recommended usage on the detergent bottle. 5. Use enough water to rinse the lint away. Washing large loads on a water saver mode is not a good idea. 6. Use fabric softener to reduce static attraction of lint. 7. Washing clothes on too long of a cycle, too often can cause premature wearing of the the fabrics. I hope some of this may help you. PS Adding a cup of plain white vinegar to the rinse cycle has also been known as a "cure" for controlling lint.
Apr 04, 2007 | Kenmore 22442 Top Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
230 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
