Question about Kenwood CD-323M 200-Disc CD Changer
Stuck CD My Kenwood Multy CD player model CD-323M was moved with a CD inside It was stuck and I was able to remove the CD by taking the cover off the unit. It is still stuck with no CD in it. How can I get it to operate again. I unpluged it and reset it. I can hear the motor trying to move the carousel by it only makes a sound and the display light keeps flashing "Please wait"
  • PopiandMimi May 18, 2008
    Kenwood DV-705 Multiple DVD/VCD/CD PLAYER
    When power is turned on you hear noise as if the disc is out of the tray and loose somewhere in the Player. Viewer says "Load" but door doesn't open.
    All 5 disc slots are lit. None of the function keys are functional. We can't remove the DVD from Player.
    Problem Solver:
  • 35 Answers
Hi there bguedes
best solution take top cover of and as it says pleasewait and you hear the noise just give the tray a bit of a jolt to help it around but beware of electric wires and static that should fix your problem
hope this helps an please if you have the time please rate me if you dont mind
thank you
fixya
Posted on Jan 12, 2008
Machine lights up but wont move; repair?
It will be a belt, spring or gear that is broken on the inside. You will have to take this apart to find out.
Jan 18, 2015 | Kenwood CD-323M 200-Disc CD Changer
How do i fix a multiple cd player kenwood, when a cd is stucked and not playing?
We have one of these and had to open it up and manually remove the excess, stuck CD's from the inside manually. After that it is playing normally.
Nov 26, 2014 | Televison & Video
Cd in kenwood car stereo, car is dead
yes open the stereo and get the cd from inside out
Apr 15, 2013 | Kenwood KDC-MP642U
Panasonic DVD player reads ho 1 and then powers down
Take the cover off and see if anything is jammed inside. Remove any cd disks that are inside. Move the head to the outer edge of the rails. See if it slides easy. Rotate the spindle to make sure that it is not stuck. Try again. The head should move towards the center of the disk when it is looking for a place to start. Make sure that the rails that it travels on are clean.
Mar 10, 2013 | Televison & Video
Can i hook up my cd player which is a kenwood cd-323m to a vr507 kenwood receiver
hi,
Yes you will be able to connect the same. Connect the line output of the KENWOOD CD 323M to the CD input of the KENWOOD VR507 receiver using a stereo RCA cable. The picture of the cable is added.
ok
Sep 12, 2011 | Kenwood VR-507 Receiver
The disc is stuck up in dvd player how can i open it up to remove the disc thanks
Remove DVD player from the mains. Look for the slotted opening covered with plastic cover at the bottom front, which can be opened easily by hand without much force. After opening it put a small flat screwdriver (locate the stud inside) & move it so that the tray will just open. Then pull the tray & remove your CD.
Aug 13, 2011 | Philips DVP3982 DVD Player
Cd is stuck inside how to eject
if there is a tiny hole on front place a paper clip in there it will eject it does on other systems
Apr 16, 2010 | Pioneer CDJ-1000 CD Player
I have a kenwood dp-r99 cd player and the cd is stuck inside with an ee message. How do I open the CD player?
6 or 7 phillips head screws. 2 or 3 across the back and two on each side. Slide the top towards the back then up. You will be able to get to all CD's with the top off. Hope this helps
Nov 07, 2009 | Kenwood CD-206 5-Disc CD Changer
I have a cd stuck
If the cd is stuck and the player is not turning on or not allowing and eject, then you will most likely have to Use the special tools, or screwdrivers and pry out stereo, take cover off, and manually remove your cd.
Sep 15, 2009 | 1999 Nissan Pathfinder
Kenwood CD-323M 200-Disc CD Changer Logo
314 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
