Question about Microsoft Windows Mobile 2003 for Pocket PC
CHARGING THE HP POCKET 2003
Good day to you. My wife has an HP Pocket pc 2003 that she purchased from a good friend. unfortunately the manual was lost. we just put in a new battery into the charger.
our 1st question is does the charge go from a blinking amber lite, to a solid amber lite then to Green or how do we know when it is fully charged?
Also keep anything important on a storage card - unlike newer Pocket PC devices (Windows Mobile 5.0 and up) if the battery dies completely, everything on the Pocket PC is erased.
Posted on Jan 05, 2010
    Problem Solver:
  • 7 Answers
The light will be green when fully charged the only thing is to make sure you charge it every night also when you do charge it and you are ready to unplug the power supply from the pda make sure you pull it straight out as the conection is very delicate,do not wigle it please
have a great day
Posted on Aug 18, 2009
    Master:
  • 619 Answers
Green means full charge.
Posted on Jan 12, 2008
Software for Compaq iPAQ 3850 Pocket PC
Compatible software will be available on the Compaq or HP web site.
Sep 14, 2017 | Computers & Internet
Looking for a manual for a HP iPAQ rz 1710 Pocket PC
Look here, and download the user manual you need.
Cheers! Carlos
Apr 30, 2010 | HP iPAQ RZ1710 Pocket PC
Ipaq 1940 losing programmes during main battery changeover
  1. Plug the charger adapter into the charging port on the bottom of the HP iPAQ Pocket PC.
    Figure : Charging the battery
  2. When the power indicator on the top of the HP iPAQ Pocket PC turns solid amber, the unit is fully charged and can be disconnected from the AC adapter (approximate time to fully charge a unit is four hours).
NOTE: The amber charge light blinks while the battery is recharging and turns solid (nonblinking) when the battery is fully charged.In the event of a low backup battery warning, charge the unit immediately before removing the main battery to avoid data loss. To view the amount of charge left in the backup battery, tap Start, Settings, the System tab, and Power.
Charging with the universal desktop cradle and AC adapter Use the universal desktop cradle to charge the HP iPAQ Pocket PC, or synchronize the HP iPAQ Pocket PC with a computer.
Follow these steps to charge the HP iPAQ Pocket PC using the universal desktop cradle:
  1. Plug the AC adapter into an electrical outlet and connect the other end of the AC adapter to the AC connector on the universal desktop cradle.
  2. Connect the serial or USB cradle cable into the appropriate port on the desktop PC.Figure : Connecting with the cradle
  3. Slide the bottom of the HP iPAQ Pocket PC into the cradle and push firmly to seat it.
CAUTION: To avoid damaging the HP iPAQ Pocket PC or the cradle, make sure the pins are aligned before pushing the HP Pocket PC into the cradle.
    Figure : Charging with the universal desktop cradle
  1. AC adapter into electrical outlet
  2. AC adapter into universal desktop cradle
  3. HP iPAQ Pocket PC into cradle
NOTE: The amber charge light blinks while the battery is recharging and turns solid (nonblinking) when the battery is fully charged.There are stabilizers located in the universal desktop cradle that assist in aligning the unit when there is no expansion pack attached. When placing the HP iPAQ Pocket PC with an expansion pack attached into the universal desktop cradle, the stabilizers will be pushed down by the expansion pack. To release the stabilizers for use without an expansion pack, press the button on the back of the cradle.
Charging with the optional USB Autosync cable Charge the HP iPAQ Pocket PC using the optional USB Autosync cable by connecting the Autosync cable to the HP Pocket PC and the personal computer. The HP Pocket PC will be charged using power from the personal computer.
For more information on charging the HP Pocket PC using the optional USB autosync cable, from the Today screen, tap Start, Settings, the Systemtab, Power, the USB Charging tab, Settings, and Help.
Charging a low battery The HP iPAQ Pocket PC will not turn on if the battery has a low charge (less than 3.2 Volts). Fully charge the battery prior to using the HP Pocket PC.
If the charge on the battery goes below the 3.2 Volts as a result of not being connected to the universal desktop cradle or the AC adapter, no damage will occur to the battery. However, the HP iPAQ Pocket PC charge indicator light will not flash until the battery reaches the minimum charge of 3.2 Volts and a normal reset is performed.
Follow these steps to charge and reset the HP iPAQ Pocket PC:
  1. Connect the HP iPAQ Pocket PC to an A/C power supply.
  2. Charge the battery to the minimum level of 3.2 Volts (this will take 5 to 30 minutes depending on the current charge level).
  3. Perform a normal reset by using the stylus to lightly press the Reset button on the bottom of the HP iPAQ Pocket PC.
  4. Turn on the HP iPAQ Pocket PC.
Keep the HP iPAQ Pocket PC connected to the universal desktop cradle or AC adapter when it is not in use.
Aug 25, 2017 | HP iPAQ H1945 Pocket PC
I have an HP Ipaq h1940 pocket PC. It won't charge!
Charge the dead battery with other good battery for a while first.
Jul 29, 2009 | HP iPAQ H1945 Pocket PC
I have a manual hp ipaq pocket pc 2003 pro w/outlook 2002
Early versions don't charge through the USB cable. They need a separate power connection. You'll need to buy a power cord.
Jun 12, 2009 | Microsoft Windows Mobile 2003 for Pocket...
Hp ipaq pocket pc built in tom tom
You can download the manual from the link below: http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?&lang=en&cc=us&contentType=SupportManual&docIndexId=179166&prodTypeId=215348&prodSeriesId=322916&lang=en&cc=us You can download the software from the link below: http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?&lang=en&cc=us&pnameOID=306698&taskId=135&prodTypeId=215348&prodSeriesId=322916&lang=en&cc=us If the Windows operating system has been removed you will need to purchase another copy of Microsoft Windows for Pocket PC 2003 or check any CD's that came with the device. Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 18, 2007 | HP iPAQ H5555 Pocket PC
Microsoft Windows Mobile 2003 for Pocket PC Logo
225 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
