Question about Hoover U5753-900 WindTunnel Bagless Upright Vacuum
I have the Hoover Windtunnel Bagless U5753 (purpleish one)
I've had it for two months and it sounds normal, however the brushes are not turning and it's not sucking anything. If I use the little hose that works but the main part does not work.
  • 126 Answers
Re: I have the Hoover Windtunnel Bagless U5753 (purpleish...
You have a broken belt. This is a very common problem. The belt is designed to break if something becomes caught in the brush roll. This is intended to protect the motor from becoming jammed and burning out. The belt is very easy to replace and your manual will explain how.
Posted on Jan 12, 2008
0 characters
3 Points
My Hoover Bagless Windtunnel vacuum has no suction on the bottom, although the hose works. Everything else seems to be working properly.
Check the belt, look like we have the same problem, I just unscrew the bottom part where he brush roller is located and found a broken belt
Easy to replace just follow this instrctions
Jan 31, 2011 | Hoover U5753-900 WindTunnel Bagless...
The brush on my hoover windtunnel stopped rotating.We already replaced the belt, and that did not seem to help
Check to see if the brush is frozen up. If you can not rotate it by hand you need to remove it and clean as best you can. Add a bit of WD40 at each end by the pieces that hold it onto the vacuum and turn by hand to be sure it is free. When reassembling, make sure the belt is put on so that the brush turns in the proper direction.
Oct 02, 2010 | Hoover U5753-900 WindTunnel Bagless...
Brush won't turn, belts intact
even though the belt is intact it can still be stretched and not turn the brush. You can get replacement belts here:
Dec 25, 2009 | Hoover U5753-900 WindTunnel Bagless...
Vacuum is hard to push when running,easy when off
I see your question is from July. I just joined Fixya this month so wasn't here to answer. If you're still looking for an answer:
It sounds like the belt is broken or stretched out so much it isn't spinning.
I would suggest replacing the belt and also check the roller brushes for wear and replace if necessary. Here is a link to an online guide with illustrations to change belt and or brushes. Hope this helps.
Jul 15, 2009 | Hoover U5753-900 WindTunnel Bagless...
Hoover Bagless WindTunnel vacuum cleaner.
very easy. you have clog. take the brush off look where the hole is thats where the clog is. it might be in there you might have to take the housing off of the motor
May 08, 2009 | Hoover U5753-900 WindTunnel Bagless...
Hoover windtunnel U5753-900 will not start
The most likely problem is the on off switch. but it could also be related to the motor or a connection.But definitely electrical in nature. suggest to take it in for service.
Feb 21, 2009 | Hoover U5753-900 WindTunnel Bagless...
Hoover Windtunnel
Sounds like you have a bad brush roll(48414115), take it out and see the the ends turn freely or not, if not, then replace it. Also check the the slots that the brush roll sits in to make sure they haven't melted. I am assuming that the motor is running, if not, then it may have froze up.
Feb 28, 2008 | Hoover U5753-900 WindTunnel Bagless...
Hoover U5753-900 WindTunnel Bagless Upright Vacuum Logo
210 people viewed this question
Top Hoover Vacuums Experts
Roger Potts
Ryan S
Ryan S
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
