Question about Kodak EasyShare Z7590 Digital Camera
Camera lens my camera lens is stuck in and i have another camera so i want to fix it myself. how do i remove the lens?
  • Anonymous Feb 26, 2008
    The Lens will not retract outward even after a battery change. Has anyone had trouble with the lens on the Z7590 Kodak Digital Camera?
  • 3 Answers
This is a simple one. The lens is tilted at an angle. Most likely you will find your lens cap doesn't fit correctly and all you need to do is align the lens correctly. Then when you turn on the power, the lens will autmatically extend.
Posted on Nov 16, 2008
6ya staff
SOURCE:
Lens on my camera not working I want to fix the camera myself
If the lens is stuck out then you will find it is usually one of a few reasons.
1. Check the
batteries. (obvious I know).
2. The
camera has been dropped or knocked.
3. The camera has grit or dirt in the lens mechanism.
Providing the batteries are ok then 2 and 3 usually mean a professional repair. The lenses tend not to be something that the average
home user can remove and take apart. The cost of repair also might be more than the camera value so you will need to find a good repair shop near you and get a quote.
May 30, 2010 | Olympus FE-20 Digital Camera
Canon PowerShot A720IS Lens Cover Won't Close
This blog post outlines repair procedures for stuck lens covers. An A400 is used as an example. The A720 is more complex, but the base procedures are similar:
http://camerarepair.blogspot.com/2007/11/repair-of-stuck-lens-covers.html
Mar 28, 2009 | Canon PowerShot A720 IS Digital Camera
Lens Stuck open on Mz67 hp camera Error code Mz60-022
Was this stuck fully open or was the lens partially opened, or was the lens jammed?
The lens can be removed and replaced with another lens from another non-functioning camera (See ebay). The lens component can also be dissembled. Putting the lens back together is tricky because the parts have to be aligned just right for the lens to work. If working with a Jammed lens, extra care has to be considered not to break any of the moving plastic parts of the lens or that part (if not entire lens) is junk.
With the motor detached from the lens, the lens should extend and retract freely. Use this to test the lens when you dissemble the camera. Be careful of the flash board.
Mar 15, 2009 | HP Photosmart MZ67 Digital Camera
How can i fix a stuck lens on a Nikon COOLPIX L11?
I have the same problem with my nikon coolpix s200. After 2 months the lens of my camera won't go inside. On the lcd screen stood lens error. I went to a shop with this problem. He took the battery out of my camera and press the off and on button for a while. Then he put the battery back in the camera and press the on button. The lens of the camera was now going inside en outside and inside and outside with a strange noise. And also on the screen stood lens error. Okey, the lens is inside the camera. But how can I fix this camera? What is the problem? What have you done? Please let know..!!
Jul 13, 2008 | Nikon COOLPIX S200 Digital Camera
Lens Stuck
YOU CANNOT REPAIR THIS SOPHISTICATED CAMERA YOURSELF!!
I guess pushing the lens inside may have made the problem worse.
I follow a rule- if you drop an electronic equipment and a problem occurs- it usually takes a professional repair!
For all you kamow there is a minor problem in the camera, like something stuck inside or something like that. and most certainly you will aggravate the problem by trying to do it yourself..
do post when you get it repaired, for all of us to know what goes wrong when lens gets stuck..
take care
Jun 17, 2008 | Sony Cyber-shot DSC-S700 Digital Camera
E:61:10, can I fix it myself?
the problem of your camera is the lens assembly.... one of the lens motor is not running or stuck up...try to remove the connection of the lens assembly and back it again...
Aug 11, 2007 | Sony Handycam DCR-TRV350 Digital Camcorder
Stuck Lens
You will not fix it, the mechanism is not usually fixable If you take it apart ,you will then need the new camera.
Aug 04, 2007 | Fuji FinePix A700 Digital Camera
Kodak EasyShare Z7590 Digital Camera Logo
153 people viewed this question
Top Kodak Cameras Experts
Ekse
Vitally Alcher
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Kodak Camera Expert? Answer questions, earn points and help others
