Question about Panasonic DP190 All-In-One Laser Printer
Printer does not print
I have all the drivers installed. Printer was working prior to us mocing it and now it does not print at all. The netwrok locator cannot find it either. I also tried connecting it to the usb and installed drivers and still yet the printer does not print. What do i do?
  • Anonymous Mar 10, 2008
    statusaddress of aprinter was not
    found:
    Sergeant:
  • 284 Answers
You need to uninstall everything. there is a clean up tool to do that if you cant yourself. delete teh usb driver because your not supposed to plug in the machine till the software tell you to. anyother problems feel free to leave a msg
Posted on Sep 22, 2008
6ya staff
SOURCE:
Will not print but it will scan and copy
Some times printer manufacturer provide print and scanner drivers separately, did you try to find "print driver"?
Or... some times when you plug your device prior to start installation agent, it do not work until... you re-connect your printer in to other USB port. Try it!
Aug 22, 2012 | Lexmark X4530 InkJet Printer
I just installed my third printer, a HP D2600, and the printer will print from Word and other installed programs, but will not print anything from the Internet using an email print icon or the printer icon...
this could be a very complex problem if you hooked your printer up to your pc prior to running the driver instalation disk. most printers requie you hook them up when qued by the install. the best advice i can give would be to uninstall the printer remove the printer connewction from the usb and insure it is removed from the device manager located in the properties section of you computer.
Jan 19, 2011 | Compaq Presario CQ5320F PC Desktop
I have sign in HP photosmart to internet wireless connection and is notconnecting but still searching What do I do now.
connect it with ethernet cable to router. then press setup button scroll to netwrok setup press ok. scroll to view netwrok settings or print netwrok settings press ok. scroll to print netwrok configuration page. get ip adress. open internet explorer type ip adress in adress bar at top. then hit enter. it will open pritner ews page. at top click on networking. then on top left corner under connectivity click on wireless then click on ipv4 configurations. under that click on manuall and put same ip address and default gateways and subnet mask that u see on netwrok configuration page. adn hit apply. then go to netwroking tab and look for wireless setup wizard. click on that run wireless setup wizard from computer. it will successfully connect pritner to netwrok. then disconnect ethernet cable and turn on wireless radio. ur pritner is ready to go. print one more netwrok configuration page to check if u r getting same ip address after disconnecting ethernet. and then try to open ews of pritner again from internet explorer by putting ip address in address bar. if it is successfully opening page ur pritner is connectd to network.
Nov 19, 2009 | HP Photosmart C7180 All-In-One InkJet...
Cannot print from computer. printer will print test pages, though
How the printer is connected to PC Via USB or using Network Cable. If it is connected Netwrok cable than printer configuration page and on netwrok configuration there will be IP Address if this is valid IP Address than reinstall drivers and upgrade the Firmware of the printer.
If Printer is connected USB than try different USB Cable and try different USB Port on the computer
If USB port on the computer is working fine and check in Device Manager if the printer has detected as unknown device or not detected at all.
If detected as unknown device than reinstall printer driver if not detected at all than USB Port on the printer is faulty you need to set up hardware repair of the printer.
Oct 16, 2009 | HP Color LaserJet 3500 Printer
Ricoh Aficio MP 2510 netwrok printer all jobs from users are Acce
the reason why the job(s) at the workstation say they are completed, and there is no job at the printer, is because the user code management has been turned ON.
if you turn user code management on, and do not setup users, with user codes, then jobs will continue to run like they are now. either turn OFF user code management, or setup users in the address book of the printer.
Mar 26, 2009 | Ricoh FT5832 Copier
Setting up a wireless printer
Hi Rob,
The situation seems very vague, First off, you have to identify if you're using this for a corporate environtment usage or are you using this on a home network? Next question would be,if the network you're connecting the dell wireless adaptor to has reserved the ip address for the allocation of the printer. If not, then there are a few possible reasons for your situation:
  • IP Mismatch. If you're connecting the dell wireless adaptor directly to your printer and network, ensure that the IP ADDRESS of the printer is matching that of the ipaddress of the printer driver in your computer (Control panel>Printers>Right click printer>properties)
  • Driver Error. Download the latest driver for your model printer and install it on your notebook. Once this is done, make sure you are able to "see" the printer by printing a test page.
  • Not conencted to the netwrok. Sometimes, this happens when you're not connected to the netwrok (but you think you are just casue you see a "connected" icon). Make sure you're conencitng to YOUR network everytime you reboot and not mooch on some other netwrok.
Hope this helped. Please do let me know how it goes. Thank you.
- Technomancer
Jun 03, 2008 | Dell Inspiron E1705 Notebook
Pagepro 1350w install/print problem, vista document stuck in queue,error
Go to control panel, printers, right click the pagepro and select properties. Click the ports tab and make sure that the port is set to a USB port. This did it for me.
Mar 17, 2008 | Konica Minolta PagePro 1350W Laser Printer
AR-207 on a network
Driver - Download correct driver for your model and install after deleting old.
http://www.driverskit.com/Printer/Sharp_Electronics/page2.html
Nov 08, 2007 | Sharp AR-207 Copier
Dell printer won't communicate with computer
REINSTALL THE PRINTER DRIVER FROM DISC THAT CAME WITH YOUR PRINTER.
IF YOU DONT HAVE DISK SEARCH THE WEB FOR PRINTER DRIVER FOR DELL 924 PRINTER (your need to know what operating system you have win 98,xp ETC.. )DOWNLOAD AND INSTALL THE DRIVER YOU NEED AND INSTALL HAPPY PRINTING
Oct 17, 2007 | Dell 924 All-in-One InkJet Printer
Dell Printer will no longer communicate
RELOAD DRIVER FROM DISK THAT CAME WITH YOUR PRINTER.
IF YOU DONT HAVE A DISK DO INTERNET SEARCH FOR DELL PINTER DRIVERS DELL 924
YOU NEED TO KNOW WHICH OPERATING system you are using Windows 98,xp ETC.
DOWNLOAD DRIVER INSTALL AND HAPPY PRINTING.
Panasonic DP190 All-In-One Laser Printer Logo
50 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Shannon Murphy
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
