Question about Maytag M7DH45B2A Dehumidifier
Servicing a dehumidifier
How to keep a dehumdifier services to work properly
  • 283 Answers
Keep the filter clean and when not in use empty the water tank and store the dehumidifier in a dry environment
Posted on Jan 15, 2008
How do i factory reset the dehumdifier Frigidaire FAD704DUD
Hello Roberto, thanks for your post!
From the information you have provided you would like to perform a factory reset on your Frigidaire dehumidifier. The best way to reset your dehumidifier is to disconnect power from it for at least ten minutes. I hope this information is helpful to you. -Matt
Jan 18, 2016 | Frigidaire FAD704DUD Dehumidifier
I HAVE A WHIRLPOOL 25 Pint Dehumidifier model AD25BBL2 serial starts with QM. Anyway it Seems to work ok as water does collect in water tray. About every 30 minutes it makes a single KNOCK NOISE. Unsu
Hello, Consumer. We're sorry to hear about the difficulty with your dehumidifier. Below are links to our Use & Care guides, Parts Diagrams, Troubleshooting information and the Service are of our website. We hope this helps! http://bit.ly/112Lu7q
May 21, 2014 | Whirlpool 25-Pint Dehumidifier
Dehumdifier runs but there is never no water in the bucket and our basement is very damp from all the humidy and the floor is sweeting there should be water in the bucket
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Aug 07, 2011 | Haier HD308 Dehumidifier
Hi- I have a Kenmore dehumdifier that has stopped filling up with water. It sounds like it is working but no water is in the tank. Any ideas?
A dehumidifier works with heat, so you should see if it is getting warm or not. Although the fan is working (sound you hear) it might not be working other than the fan. If you have a clamp on amp meter you could see how many amps it is drawing which is usually quite high.
Jul 22, 2011 | Kenmore Dehumidifiers
Bad smell coming from dehumdifier from the air outlet
Lin, the air intake filter may need cleaning and the water collection bucket may have a mold and mildew buildup. Cleaning both things, may solve the smelly problem.
Jul 14, 2011 | Danby DDR607EE Dehumidifier
Dehumidifier is on but nothing happens
air filter clean.
water level switch problem.
control card problem
start at these points first........
if fan is working may be compressor.
Apr 20, 2010 | Comfort-Aire BHD-501 Dehumidifier
Tank fills up but connected to hose FDL70S1
I had the same problem. It seems that you need to add another hose washer to the drain hose that connects to the dehumdifier. I wasn't able to tighten it enough by hand to keep it from leaking. BE CAREFUL ! ! The plastic connector in the dehumdifier is just that PLASTIC so don't try to overtighten with a pliers, etc... I still get a minimal amount of water in the bucket but only have to dump every 4-6 weeks, if even that.
Jul 24, 2009 | Frigidaire Dehumidifiers
Goldstar Dehumdifier - draining through hose not working
Check the connection where you attached the hose. It may be plugged or covered by a plastic film from when it was molded.
Jun 09, 2008 | Goldstar DH304 Dehumidifier
Delonghi Dehumidifier E! error
I Had an E error (not an E1 error) when I was fiddling with my humidity/temp sensor on the face of the radiator fins (behind air filter).  The sensor was WET.  I dabbed it dry, let it sit all day, and re-assembled.  It works fine now.
Aug 30, 2007 | DeLonghi DE500 Dehumidifier
Dehumidifier Doesn't Deumidify Well
If a dehumidifier seems incompetent, it may be undersized for the space. Check the unit's specifications to be sure it can handle the room size. If you don?t want to replace it with a larger one, try closing doors and dehumidifying your space a section at a time. You can also: 1) Disconnect the power cord. 2) Remove the cover and clean the condenser and evaporator coils, as discussed above. 3) Lubricate the fan motor bearings with a couple of drops of oil if the motor has oil ports (some units don't need to be oiled). While you?re at it, make sure that the condenser isn?t clogged with dust or dirt. 4) If it still operates poorly, call an appliance repairperson for advice or take the unit into an appliance repair shop.
Jan 18, 2006 | Fedders A7DH65B2A Dehumidifier
Maytag M7DH45B2A Dehumidifier Logo
138 people viewed this question
Top Maytag Dehumidifiers Experts
Bill Long
Steve
Mike Squire
Are you a Maytag Dehumidifier Expert? Answer questions, earn points and help others
