Question about Gaggia Syncrony Espresso Machine
When the machine is plugged and turned on the whole screen becomes black
I can not use the espresso machine. when I turn it on the screen become black. I call the company and they told me the electronic group is gone, so I got a new one and the machine still does the same. any ideas, Does the machine has a reset system??
  • 515 Answers
Some models have a reset button on the boiler, some have a fuse that can be replaced.
Posted on Jul 11, 2008
Hello! My Panasonic QuintrixSR picture becomes fuzzy then thick squiggly black lines appear. The whole screen turns black yet sound still on. Can I fix this or is the TV toast? Please help, thanks.
Hi there!
Your tv is not toast yet it can be fixed. get another screen and see if their any changes .if other circuitry are fine your screen should work perfectly
May 18, 2017 | Panasonic Televison & Video
Delonghi EC 820B leak from the bottom edge of the Boiler outlet/ Infusion assembly.
the hose has become clogged up with deposits and split.. you can try to take apart and repair yourself or look up your local shop for repair
Jun 10, 2016 | DeLonghi EC820.B Black Pump Espresso...
My EM100 Espresso Maker will not brew? Water comes out when no portafilter on, but not when filter on for brewing? Help!!
This is a complex problem. 1. remove, check and clean brewhead (round screen above portafilter where water comes out); it can become clogged with gunk. 2. brewhead gasket may be old or damaged, they can be purchased on eBay. 3. brewing basket may have become clogged, I don't know if running cleaner solution through it will help, may have to replace it. 4. Likeliest source of problem is coffee ground too fine and/or tamped down too hard. These are not professional level machines and cannot work with very fine grind or heavy tamping. Try a coarser grind and a light tamp with the larger brew basket. Coffee must be ground with good quality burr grinder for correct consistency. John Saxon/
See my espresso-making blog at motophoto.posterous.com
Dec 15, 2011 | Cuisinart EM100 Stainless Steel Espresso...
E machines flat computer screen began blinking and having colored lines going through it after turning black. By odd mishap I realized when I pressed on the screen it stopped doing that. That has been...
By the way, is it an LCD screen? I guess so. LCDs have small IC's either on the lower portion or in the left side of the screen. When these become loose, the tendency is to have vertical or horizontal lines on the screen. Hot air blower might solve the problem. But most will not. Better claim warranty or replace the unit.
Dec 07, 2009 | E-Machines eMachines Desktop PC
Wen i turn my camcorder on,the whole screen becomes dark and i can see the objects only faintly
Had the same problem. It's ainternal flex wire connecting LCD with camcorder. Got from the repair shop did it by miself and it's like knew. It's a common problem as this cable is bend each time when we open the LCD screen, so the cable become faulty. Good luck
Oct 01, 2009 | Video Cameras
SyncMaster 940B
Sounds like you have a video card problem. If it works on someone elses PC and not yours. Replacing this video card on your PC should fix it..
May 14, 2009 | Samsung SyncMaster 940B 19" LCD Monitor
Problem with screen
ITS MOST PROB THE SCREEN DRIVER FAULT OR WITH YOU LEAVING IT ON ALL NIGHT WITH LID CLOSED THE SCREENS GOT HOT AND DAMAGE THE FLUID INSIDE THAT WHY WHEN IT WARMS UP THE SCREEN FAILS , TRY DOWNLOADING THE GRAFICS DRIVERS AGAIN AND REINSTALL THEM, IF THIS DOESNT WORK YOU MAY NEED A NEW SCREEN
Apr 07, 2009 | Dell Precision M60 Notebook
Cloudy Blue Color Covering Whole Screen
I think its time for sony to face a claas action, they do not supply parts in less than 7 years, and the unit should not have been sold so $high, they should buy them back, that is the best solution
Nov 14, 2008 | Sony KP-65WV600 65" Rear Projection...
Canon sd10 elph , screen is black,turn it on or off still black
Try inserting and removing the A/V cable plug a few times (that TV cable that came with the camera that hardly anyone uses). There's a little contact switch inside that turns off the screen when the cable is inserted. Sometimes the switch can become a little dirty with corrosion and can turn off the screen. Inserting and removing the cable plug a few times can sometimes clean the contact switch. Good luck!
Oct 21, 2008 | Canon Cameras
Gaggia Syncrony Espresso Machine Logo
135 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Michael Vincent Cruz
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
