Question about Sony FD Trinitron WEGA KV-24FS120 24" TV
32 inch sony wega flat screen but not a lcd
I had a power surge and when i try to turn the tv on it sounds like its gonna come on but nothing at all exept power light
  • 4 Answers
Try to check horinzontal output. and vertical ic.
Posted on Mar 09, 2008
My 32 LCD TV will not turn on without been turned on and off many times. The power lights come on butte screen is black .
O O, it sounds like your power board is going out have a service man come out and tell you whats wrong it cost $600 for the part I just bought another flat screen its cheaper. Good luck
Jul 01, 2014 | Sony Grand WEGA KDF-60XS955 60" Rear...
Troubleshooting 32 inch Philips LCD TV
Sounds like a power supply problem that typically is caused by a power surge of some sort. Check with tvrepairkit. com for their power supply kit to do the repair yourself.
Jun 19, 2012 | Panasonic TH-42PWD6UY 42 in. HD-Ready...
I have a 32" Sony Wega Flat Screen TV. Currently
Check out this article: http://www.ehow.com/how_8256946_fix-sony-32-trinitron-picture.html
It goes pretty in depth in how to troubleshoot problems with your Trinitron TV. Hope this helps.
Sep 01, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Power Outage Problems Sony Bravia 32" LCD TV
try cycling the power (unplug 2 minutes) and plug in and wait 30 seconds and turn back on. if this doesn't work, could have been a surge, your protector should have saved it, but could have been through cable or something. surge protectors will guarantee no damage for several years, check with the manufacturer maybe they'll cover the repair.
Jun 01, 2010 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Sony Grand WEGA KF42WE610 42" turns on and off
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
Please make sure that the videos sources are connected properly to the TV.
Try Power Resetting the TV.
Please disconnect the power cord from the wall outlet (for approximately 1 minute), then reconnect the power cord and check whether the issue is resolved.
Also try connecting the TV to a different wall outlet and check if that helps.
Jun 16, 2009 | Sony Grand WEGA KF42WE610 42" Rear...
Sony BRAVIA 32 inch
I had the same problem with a old Sony TV.
To find out if the problem is temporary
  1. Turn off the television.
IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
2. Unplug the television power cord from the electrical outlet.
3. Let the television remain without power for 60 seconds.
4. Plug the power cord back into the electrical outlet.
NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
5. Turn on the television.
If the light is still flashing the tv has stop working and you will need to buy a new one.
Dec 08, 2008 | Sony FD Trinitron WEGA KV-27HS420 27" TV
Sony wega 32 inch
Hi if light blinks on any sony tv it the fallowing
1 screen adjustment in expensive repair you need a tv center
2 power supply problem fix is 85.00 to 120.00
3 flybak problem high voltage est 225.00
this will at least help you so you will not be taken advantage of when you call a service center
thanks DOCTOR VIDEO LEADINGEDGEREPAIRCENTER SINCE1987
Apr 16, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
32 inch sony wega
power board problem, needs to be repaired or replaced. Any TV tech can do this with the proper replacement parts. Common.
Mar 03, 2008 | Sony FD Trinitron WEGA KD-32FS130 32" TV
Sony kdl 32 inch lcd tv (apprx 2.5 yrs old)
Usually resetting a device like that is done via it's On Screen Display (OSD). Maybe you need to contact Sony Tech support.
You can do this by clicking the below link:
[Sony Tech. Support]
Let me know if they have a solution to your problem.
Greetings,
DarkNeogen
Aug 20, 2007 | Sony WEGA KDL-32XBR950 32 in. LCD HDTV
Sony FD Trinitron WEGA KV-24FS120 24" TV Logo
43 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
