Question about Maytag Atlantis MDE7400AY Electric Dryer
How do I get to the belt
I want to stop the belt from squeeking and I thought I would put a little wd40 on the pulley.
  • 1 more comment
  • big bobby Apr 19, 2008
    noise sounds like a pulley or bearing or something. How do I get the cabinet off?
  • Anonymous May 16, 2008
    I think my maytag atlantis has a broken belt. How do I get to it
  • Anonymous Jun 04, 2008
    I need to know how to put the belt on the idle pulley
    Novelist:
    Scholar:
  • 70 Answers
These are not the "same" problem.
1. The squeak typically will be from dryer fuzz getting into the mechanism. If you MUST spray WD40 then watchout where you spray it. If you get it on the belt then the belt will degrade and break in a very short period of time. If you spray WD40 on electronics they will probably short the electronics. It may also be a worn out pulley or motor bearing.
2. You must remove the pulley bolt on many dryers, place the belt on the pulley and then thread the bolt back on the arm or nut.
3. Most of the Maytag washers you must remove the doors first and then there are clips that hold the frame together. They are "pop off" with a scredriver and a bump with a gloved hand.
4. see 3. to get the cabinet off. If it sounds like a bearing then it probably is and you will have to replace the pulley and integrated bearing. It may also be a worn-out motor bearing (replace the motor).
Posted on Jun 22, 2008
Very squeeky dryer, starts out quiet then intensifies through the cycle untill it can be heard from outside; has a rhythmic squeek.
The belt is probably rubbed smooth. Since you already sprayed it, after the spray dried out, it starting squeaking again. I suggest examining the belt and replacing it if necessary.
Mar 22, 2016 | Dryers
My kenmore heavy duty extra large capacity 2 speed motor when drying my clothes squeeks when turning to dry clothes can I spray wd40 to make it stop squeeking and how or what do I oil?
Most likely a wheel bearing on the tub of a front loading washer, or the belt tensioner pulley on a top load washer. Either is not fixed by lubrication but replacement is called for. There are usually 3-4 wheels on front loaders that could be out. Replace all of them if you are going to replace one. The belt tensioner is a single assembly that can be ordered from any appliance parts warehouse or Sears.
Aug 01, 2012 | Kenmore Washing Machines
1997 Ford Taurus gets a little hot while driving. Afraid to drive long distances.
try burping the cooling system a few times or could be your thermostat. as far as the belt squeek, you can take a litle bit on silicone grease and put it on the belt in one spot with the car off. let it run for a little bit and the squeek should stop
Jul 09, 2012 | 1997 Ford Taurus
My belt was squeeking and before I got to change it I got off the freeway and it died when I came across the overpass at the light. It will click over but won't start. I thought I jumped the timing belt...
Nothing worse than a squeeking belt. Best solution is to spray WD40 all over the belt and loosen it up so that it deflects 2'' for proper tension.Problem solved,button it up and go drive it hard
Jul 02, 2010 | 2001 Kia Sportage
My ram squeeks when i start it up i have put on a new serpentine belt and replaced the pulley tensioer and it still does it only when it is cold though
hi, to find out exactly where the squeak is get a spray like wd40 and spray each pulley in turn until the noise stops this will then tell you if it is a bearing on the way out and where the exact squeak if its not on the pulleys then give the belt a little spray and see if the noise stops if its does then the noise may go after a couple of days after the belt has wore in a bit.
Let me know how you get on or if you need further assistance ok
Jan 25, 2010 | 1999 Dodge Ram
2001 isuzu rodeo the belt is squeeking and the power steering pulley is maken a squeeking loud
well if i was doing it in my shop i would just put a new belt on because what has happened it the belt on there has stretched out and can be adjusted and retighten but if your in there you should replace it.
if you have more question please ask
Oct 29, 2009 | 2001 Isuzu Rodeo
Engine Squeek
It may be the water pump that is making the noise if the noise is constant.
May 11, 2009 | 1998 Dodge Ram
Major friction/squeeking from serpentine belt!!!!
Keith,it sounds like you may need to clean the grooved surfaces on your pulleys,you could remove the belt and use some aerosol brake cleaner and a stiff brush to remove any build-up on the pulleys.you could also try spraying the same on the pulleys while the car is running,just be sure and wear eye protection and don't get to close to any moving parts.
Apr 29, 2009 | 1992 Mercedes-Benz 190
Belt squeaking have tried tiehtening
are you sure its the belt. i had a similar problem with my dodge caravan, i thought it was the belt but it ended up being one of the pullys was squeeking, and also the pully on the belt tensioner.
Dec 20, 2008 | 1992 Dodge Spirit
Maytag Atlantis MDE7400AY Electric Dryer Logo
94 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
