Question about Samsung SGH-E630 Cellular Phone
How to unlock sgh-a737
How you have the codes and the instructions to unlock sgh a-737
My sgh-a737 (att US) is frozen and needs to be unlocked for non US SIM cards. Any idea?
  • 1 more comment
  • Harry-sys Jan 13, 2008
    What exactly will the cable do to my phone ?
    What access would the "cable" allow, I would not have using the key pad ?
    Harry
    Hi dahaka,
    sorry it is not the question of the password and the security lock.
    Also on page 97 of the manual for the SGM-a737 I see instructions for "shopping for music" and "Transferring music from the Digital.....". The download refers to different phone and there only to the SIM lock (to my understanding).
    I tried to unlock the phone from its exclusive use with AT&T SIMs. Using the offered sequence of numbers (probably more than 3 times, the phone did "freeze".
    other working sim cards (from other phones) did not result in getting the phone back to life.
    So how do I get a) my phone out of the "FReeze" state and b) if then still needed unlocked form using AT&T Sim only?
    Harry
  • Harry-sys Jan 14, 2008
    Hi Darklord,
    Thanks, this not quite a "solution" that I had expected, but it looks like I have to give up to get the phone out of its Freeze state by myself. Go to the AT&T phone shop is difficult if you are in Europe. But I will shop around.
    Harry
  • 2,427 Answers
Ok if you are using a code calculator you will have 3 chances and then it can be only unloked via a cable, you can do this at your local dealer of you can buy one on line..
here is a calculator link,,, they post you 7 codes, 1 of the 7 will work but you only got 3 chances
http://www.freeyourmobile.com/samsung%20free%20unlock%20codes.htm
Posted on Jan 11, 2008
  • 1 more comment
  • Rishi Roshan Ali Jan 11, 2008
    PS the link I posted above contains all the different unlocking solutions aviable,, from code calculators, to software ,, even cables,,, some of the software are free others you have to pay for
    BTW I WOULD RECOMEND YOU GO TO YOUR LOCAL PHONE DEALER AND GET IT UNLOCKED WITH A CABLE,, ITS SAFER AS well as you will be sure you wont screw up your phone and need it flashed..
  • Rishi Roshan Ali Jan 14, 2008
    When said the cable, its actually a device with a cable for your phone. what it does is when connected it reprograms your phone removing all network and sim card restrictions. this allows modification such as changing networks with just changing the sim, multi sim anology as well as duelo sim modification support. etc..
    Basically it unlocks everything so you can do as you like with it..
    these are expensive thats why i recommended that you take it to a local dealers as they would have stuff like this and be able to use it correctly...
    If you use the calculator, you will only have 3 chances to enter the correct code, if that fails its permentantly locked and can only be opend by the cable.
    there are software on line that use the normal usb cable.. but these often result in dead phones and quite frankly isnt worth the risk..
    as my suggestion to you i again reommend that you take it to a dealer , it only takes a couple of minutes and you are sure you wont wind-up with a dead phone.
    Sergeant:
    Champion:
  • 347 Answers
Hi Harry,
Try this code
355992011780565
and let me know if it didnt worked
  • 1 more comment
  • Santiago Vallejo
    Santiago Vallejo Jan 11, 2008
    What happend before the sim froze? you typed your PIN several times wrong?
  • Santiago Vallejo
    Harry in the page 97 of the manual you can find the answer,
    copy paste this link if you dont have the manual
    http://downloadcenter.samsung.com/conten...
    "Phone Lock
    When the Phone lock feature is enabled, the phone is
    locked and you must enter the 4- to 8-digit phone
    password each time the phone is switched on.
    The password is preset to “00000000” at the factory. To
    change the phone password, see "Change Password" on
    page 95.
    Once the correct password has been entered, you can use
    the phone until you switch it off.
    The following options are available:
    • Disable: you are not asked to enter the phone password when
    you switch on the phone.
    • Enable: you are required to enter the phone password when
  • Santiago Vallejo
    IF you already removed the phone lock and keep having the same problem you should call your phone dealer or try to use another sim of the same phone dealer.
Mi telefono Samsung a 737 esta congelado (AT&T) pueden ayudarme a encontrar el codigo de desenllave con el imei 35599201512228/5 04 e indicarme los pasos para descongelarlo? Gracias
Hi unlocking via unlock code is the safe way to unlock your mobile..you can try Classicunlocking.com to get unfreeze code for your Samsung A737 and get it unlocked from AT&T..
Feb 27, 2012 | Eforcity For SAMSUNG SGH-A737 A-737 AT&T...
Samsung a737 sim unlock code
Good place to get a unlock code for your Samsung SGH-A737 model mobile here Classicunlocking.com , it gives you a step by step instructions for getting the unlock code for your samsung mobile from the network lock.......
Nov 17, 2011 | Samsung Cell Phones
Unlock samsung SGH-A737
You have the right information, the IMEI#. You just need to contact your provider for the unlock code. Because the unlock code is IMEI specific. If you try and go on web site, they'll sell you the unlock code. Why not go to the source, and get it free. If ATT won't give it to you, go to the Manufacture. But, you MUST use your carrier first.
Cheers!
Feb 04, 2009 | AT&T Cell Phones
Unlock code
For your samsung SGH E630 here is some code try it
*2767*3855#
*2767*2878#
*2767*688#
this code reset eprom,which removes your SP lock
Jan 05, 2009 | Samsung SGH-E630 Cellular Phone
Type *#9998*627837793# Go to the 'my parameters' and there you will find new menu where you can unlock phone.(not tested-for samsung C100)
To unlock a Samsung turn the phone off take the sim card and type the following code *#pw+15853649247w# .
Java status code: #*53696# (Samsung X600)
If you want to unlock your phone put a sim from another company then type *#9998*3323# it will reset your phone. Push exit and then push 7, it will reset again. Put your other sim in and it will say sim lock, type in 00000000 then it should be unlocked. Type in *0141# then the green call batton and it's unlocked to all networks. This code may not work on the older phones and some of the newer phones. If it doesn't work you will have to reset your phone without a sim in it by typing *#2767*2878# or *#9998*3855# (not tested)
Dec 29, 2008 | Samsung SGH-a737 Cellular Phone
ASK FOR A UNLOCK CODE WHEN I TURN IT ON
Nov 23, 2008 | Samsung SGH-a737 Cellular Phone
Unlock a sgh samsung 737
i need the unlock code for a samsung sgh-a737...
but it is on phone freeze how to i fix that?
please email to me vule0260@sbcglobal.net
Aug 23, 2008 | Samsung SGH-E630 Cellular Phone
Need help unlocking my samsung sgh-737 please help me please
IMEI : 359673014197777 02
MY EMAIL vule0260@sbcglobal.net
Aug 14, 2008 | Samsung SGH-E630 Cellular Phone
Samsung A737
If you have an AT&T account:
FOLLOW THESE STEPS TO NETWORK UNLOCK SAMSUNG SGH-A737
GET THE UNLOCK CODE FROM ATT CUSTOMER SERVICE 18003310500
1. REMOVE SIMCARD AND TURN ON HANDSET
2. The display will read INSERT SIM CARD
3. TYPE #7465625*638*--------# .THE DASHES ARE YOUR 8 DIGIT UNLOCK CODE OBTAINED FROM ATT CUSTOMER SERVICE.
4. U WILL GET A MESSAGE SAYING NETWORK LOCK DEACTIVATED.
after the second asterisk, you'll see a dash ("-") on your screen instead of the number you type.
Apr 27, 2008 | Samsung SGH-E630 Cellular Phone
hi there
there is a one way press this code without sim card *2767*3855#
Jan 10, 2008 | Nokia 1600 Cellular Phone
Samsung SGH-E630 Cellular Phone Logo
147 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
