Question about Durabrand WD810
CD Player will not load/accept cds!
I don't condone cheap CD players, I warned the person who I installed it for, it's been about a month, suddenly the player will not accept a cd. If you stick it in there, it's like the player sensor doesn't pick up that there's a cd being fed. so you gotta kinda shove it in there. but it won't play still. What you actually have to do to get the player to accept the cd, is hit the eject button, and kinda hold the cd to the point where the wheels are grazing the edge, then when the cycle is done, it'll suck the cd in and play fine. Any way I can just fix this for these people? I really don't like unsatisfied customers.
Re: CD Player will not load/accept cds!
I have had mine for 3yrs and it just smoked last night(12/04-03/08). I had it in one of my demo cars to prove a point. That a properly installed and maintained budget system is possible and will outlast and out perform many Well Know brands. I have 3 show cars for my shop one budget(montero), mid level price point(dodge stealth r/t) and a full blown w/ ppi amps, mb quart speakers eclipse devices(bmw m3)
The PPI amps have smoked several times, to the point that I no longer carry PPI. My point being that no matter what you buy there is a good chance it will breakdown w/o routine cleaning and care.
Posted on Mar 02, 2008
0 characters
3 Points
Cd player will not accept cds
Im a retired installer so let me talk u thru this. If you can disconnect the power plug from back of unit, pull it out give it a few seconds, plug it back in. U should hear a mech. Noise( that's the CD mech loading. If you don't hear any noise, u probly have a def. Unit. It is also a chance u have a cd already loaded and stuck. If u look carefully u can see a disc in it. The other issue could be a power issue on your yellow wire. Last but not least, not knowing the history, your unit mite be binding. Hope that helps
Apr 01, 2014 | Alpine CDA-9885 CD Player
Wont play
you may have an older cd player they have trouble playing burnt cds try regular cds
Jul 16, 2013 | JVC KD-S730 CD Player
Cd player will not play cd's. Error code: TOC ERR
A few things it could be:
No disc has been loaded in the disc magazine.
CDs being used are burned, test using different media or an actual CD.
Very dirty or scratched CDs.
The CDs are upsidedown.
Sep 21, 2011 | Kenwood KDC-MP4028 CD Player
Cd opening wont accept cd. radio works though
I have 3 suggestions for you.
Firstly, many older CD players can't play CD-R's, that is CDs that you have burnt yourself. If you are using original CDs, then that won't be the answer.
Second suggestion is that a very few CD players expect the CD to be inserted upside down - I have a Pioneer CD player that works like that.
Third suggestion, unlikely to work, but you could try a lens cleaner.
Failing that, it will need expert repair and that will probably cost more than the player is worth - just buy a new one.
May 17, 2010 | Car Audio Receivers
Cd player not playing cds
If your CD player isn't playing CDs anymore, its possible that the lens had reached its end of life. If your player is still kinda new, its possible that you need to have your lens cleaned. Get yourself a cheap cd lens cleaning kit and use it on your player.
I hope this helps. Thanks and have a nice day.
- HotRatchet
Dec 14, 2009 | Alpine CDE-9845 CD Player
Cd player wont read most cds
Try a lens cleaner first . If that doesn't work then i would send it in for repair or purchase a new unit .
Dec 28, 2008 | Jensen MP7610 CD Player
i have the same radio and it was acting funky all of a sudden, i just disconnected the power wires to it for a few minutes and re-connected and all was ok and has been for about a year now. hope this helps.
Aug 09, 2008 | Kenwood KDC-422 CD Player
USB and CD Player Stopped Working
Checa en el manual si no activaste un candado con el usb.
Apr 09, 2008 | Kenwood KDC-X591 CD Player
2001 Mustang 6-disk CD player
does it give an error code? usually it just a gear timing problem, will it load discs that are in it?
Jan 02, 2008 | JVC KD-S680 CD Player
Load problem and error message
Did you try to reset it? Look for a small button that only be press with a toothpicker or something that small. Another way to reset is to disconnect the battery. Goodluck.
Sep 30, 2007 | Alpine CDA-9856 CD Player
Durabrand WD810 Logo
158 people viewed this question
Top Durabrand Car Audio Receivers Experts
Daniel Shea
Level 1 Expert
Colin Stickland
Colin Stickland
xxxxxx xxx
Are you a Durabrand Car Audio Receiver Expert? Answer questions, earn points and help others
