Before you run the ROM Update Utility (RUU), make sure you have done the following:
Backed up the data on your device.
Standby or hibernation mode of your PC has been disabled.
Close all running applications on the PC.
Set aside approximately 25 minutes to allow the device to update.
Charged the battery to at least 30%.
Download HTC Sync for Android.
Install the HTC Sync software on your PC if it is not already installed. This software was included in your HTC Hero gift box. The minimum required HTC Sync version is 2.0.28. We have HTC Sync for Android 2.0.40 available for download; newer versions might be available from www.htc.com.
If the HTC Sync application appears on the screen of your PC, you may simply dismiss the wizard by pressing the Cancel button.
Run the Hero 2.1 MR Upgrade RUU file.
Follow the on-screen prompts to install the update for your HTC Hero
WARNING: During the upgrade process, do not attempt to make/receive calls, press any buttons on your device or disconnect the device from the USB cable as this will stop the update and your device may be rendered inoperable!
If you have a problem with the connection between your device and PC be sure to check the connection type in your device. This can be done in the device via Settings -> Connect to PC. Ensure that HTC Sync is selected.
1/ Switch off the phone (either removing the battery or shutting down by holding the "end call" button for few seconds 2/ While being switched off, hold the "home" (house) and "back" (the arrow in the lower right corner) 3/ Hit briefly the "end call" button" while still holding the "home" and "back" buttons. 4/ Release the "home" and "back" button, a white screen containing technical information should appear, with a red message asking for hitting the "menu" button. 5/ Hit the "menu button", the Hero will now boot with factory settings.
There are 3 step to repair htc hero flash component error
If you got htc hero flash component error then there is a 94% chance
that your computer has registry problems. To repair htc hero flash
component error you need to follow the steps below:
* Step 1 - Download a htc hero flash component error repair tool,install this error repair tool.
* Step 2 - Click the Repair All Button.It will scan you pc for Free.
* Step 3 - Then click the Repair All Button again and your done! It is very easy to repair htc hero flash component error.
Here is the url of htc hero flash component error repair tools:
when start your htc, keep pressing the "home" button, do not release at all, while your pressing the power, you'll have a sign apearing on screen an thenrelease both buttons, and press them again in same time... now you enter in boot mode. if you have a boot file on your card you can use it (please check youtube how to do it, they have a solution there), if not, just boot from his software... good luck, hope to help you.
The Flash support for the Hero is still very limited. I think they advertise it as Flash Lite, so you will not get full Flash content loading properly on your phone.
The other issue you may be experiencing is that you have plug-ins disabled from your Browser settings. Flash is a plug-in that needs to be turned on. With your Browser up, go to Menu > More > Settings > Enable plugins.
There are 3 step to repair the HTC Hero flash component error.
If you got htc hero flash component error then there is a 94% chancethat your computer has registry problems. To repair htc hero flashcomponent error you need to follow the steps below:
* Step 1 - Download a htc hero flash component error repair tool,install this error repair tool. * Step 2 - Click the Repair All Button.It will scan you pc for Free. * Step 3 - Then click the Repair All Button again and your done! It is very easy to repair htc hero flash component error.
