Question about Hoover Portapower C2094 Bagged Canister Vacuum
High rpm The machine runs very loud and sounds like the rpm is to high
  • 126 Answers
These machines are noisy to begin with, but will become worse if anything is allowed to enter the fan area of the motor. I have seen debris clog the front fan and put the motor out of balance so it will really scream when it runs. This work is best left to a competent professional
Posted on Jan 12, 2008
Hoover makes a loud noise and does not pick up
Issar 702:
Take the machine to a room that has no carpeting, (this is 'gonna get messy :-) First, make sure that the machine is unplugged from the wall, then remove the wand with the hose and verify that the hose, wand and vacuum head are not clogged up... check carefully, some clogs or items stuck in the hose and wand assembly can be hard to find! Then check the hose from end to end making sure that the hose is clear of debris. Then open the canister and check to see that the gasket around the top of the canister is not damaged, then check the belt coming off of the motor driveshaft is not binding or damaged. You should be able to rotate the belt by hand with the machine off and unplugged.
Jan 06, 2013 | Vacuums
When running it makes a very loud quite high pitched long clicking sound . What can I do about it as I do not want to continue to use it like this
If the noise is continuous from switching on and slows down to a stop when machine is tured of it has to be some thing on contact with the motor or the brush roller the brush roller is easy to check the motor isnt but is less likly to go wrong
Jul 25, 2010 | Dyson DC04 HEPA Bagless Upright Cyclonic...
Envirovac kicks debris back at my feet and is loud
It's clogged!
Many so-called "environmentally friendly" vacuum cleaners have multiple stage filters; the usual configuration is a standard filter followed by a HEPA filter or equivalent. Standard filters can be a paper bag or a bagless, removable container.
From time to time, the secondary filter will get clogged, so it doesn't matter whether you change the bag or empty the container, performance will not improve.
If you have access to compressed air, try removing the secondary filter and blowing it clean with a high pressure air nozzle. If that doesn't work, check the hose to make sure it's clear. If you are using a rug beater attachment, make sure it has not clogged at its inlet.
Sep 06, 2009 | Eureka High Filtration s Mighty Mite...
There seems to been a high pitched sound in the motor. I'd describe it as a 'dry' sound, and the high pitch of it is very loud. I want to stop vacuuming because it's so loud. Are there any oil/greasing...
High pitched noise is not good. It may indicate that a bearing is going out. I would not use Kirby as it may lead to burned motor.
If you feel that it vibrates quite a bit too - then it may be only broken fan blade.
Fan blade - you are looking ar around $40-$50 and if this is a motor bearing - $60-$80. If anyone wants to charge you more - we will repair it but you will have to pay shipping both ways (roughly another $30 both ways all together)
Ohhh yeah - try it with the hose. If no sound then brush roll bearings may be bad...
Good Luck,
Rocky
If you want to send it for service - go to GoodVac.com click on SERVICE, print form, fill out and ship it here.
Apr 04, 2009 | Kirby Generation 3 Bagged Upright Vacuum
Rainbow E series sounds "whiny" and loud while running
The whinning sound may be the bearings are bad. This will have to be taken care of or it will wear your motor brushes down very quickly. It is not generally caused by the filter, but by not be cleaned properly and may have been stored on its water basin.
Jan 20, 2009 | Rainbow E series Canister Wet/Dry Vacuum
High pitched sound when vacuum is on
You may be loosing your bushings on the motor,if this is an expensive machine it may be cheaper to have it fixed,if not it will burn up eventually.Also try taking the beater bar out and make sure you don't have something rapped around it causing a noise.
Hope this helped.Let me know by rating me
For more help go to live chat.
lenwest
Jan 19, 2009 | Dyson DC14 All floors Bagless Upright...
My vacuum is very loud ...
If it sounds really high pitched or like a airplane i would bet your motor is shot in which case it would exceed cost of your unit.
Oct 10, 2008 | Eureka Altima Upright Vacuum Model 2996AVS...
My Hoover runs at a high rpm
Hi. Check the carbon brushes they may be breaking down.
Sep 12, 2007 | Vacuums
Hoover Portapower C2094 Bagged Canister Vacuum Logo
102 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
