The tv have a problems known as a tv convergence pictures problems,it is dead.Tv set have any colors lines like R,G,B mis alingnments,have colors shadows pictures or a 3D pictures look alike?Yes,than the tv set convergence board it is dead to causes all these pictures problems.The tv set convergence board must have to be repair like replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the tv set convergence board to solved the tv set covergence pictures problems.The tvs shops will cost u like $300-350 for parts and labors.
Go in ur tv menu go "Picture"go down to reset.Press it,will go back to Factory setting.The colors should be back to factory setting.Not,than ur tv Main Tuner signal board is the cause must change to fix.
hello there this is an easy fix unplug the tv and take the back of the set, once inside the set you will see 3 coloured bulbs and a big mirror in the back theses over time get dusty and dirty and if you smoke it can get really bad you simply just need to clean the bulbs and the mirror with computer screen wipes or some sort of window cleaner be sure not to get everything wet inside this should sort if for you nice and clear again!
If the screen is bouncing...expanding/shrinking you need to get a repair kit from www.TvRepairKits.com
If your screen looks 3d in color, has a stationary bow, or if you can't adjust one or more colors from the "convergence" menu you need to buy a convergence repair kit. You can get one from the same site listed above.
You have a convergence problem. Here are some of the most common symptoms.
Screen looks 3D One or more colors can't be adjusted when using the convergence menu. Screen is bowed in but stationary.
Solution: You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kit for your exact model. The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself.
Sounds like it has an intermittant connection somewhere which is very
common now a days due to the lead-free solder all the makers went
to. Resolder everything that looks suspicious, especially the
bigger components. It could also be a failure of the flyback
transformer though which often times fail like this.
Hope Ya Fix It.
