Question about KLH HT-9930 System
KLH tweeters stopped working
I have a pair of HLH 2 way speakers model AV 3000.  Both the tweeters stopped working at the same time but they are not blown. I removed them and put them in a pair of working speakers and they did not work their either.  The working pair was a different brand does that matter?  Is there a way to fix them or do I need to replace them?  Why would both tweeters go out at the same time?
  • 1 more comment
  • Durwood187 Jan 12, 2008
    I did disconnect the tweeters and checked them directly with the speaker wire and got no sound is that what you meant?  I can probably borrow a ohm meter from the physics department here so when I do were is the tweeter coil located and how do I check it?
  • Durwood187 Jan 13, 2008
    k I checked it and got no resistance from the tweeter.
  • Durwood187 Jan 14, 2008
    k that is what I figured.  Thank You
  • 238 Answers
Hi, have u first disconnected the tweeters and then checked, as if its on a cross over, the tweeter is in series with a capacitor,if u have a ohms meter or a continuety tester check the tweeter coil if its open,secondly you can have the coil replaced, check if u can get one before buying a new,let me know
Posted on Jan 12, 2008
  • ravi chavan Jan 13, 2008
    hi, just put the probes of the meter on the two terminals of the tweeter and see if u can get a continutey, or some resistance, if it dows not than the coil is open.. . the coil as u know is in the center of the spider or the cone.u.... cannot see it.let me know
  • ravi chavan Jan 14, 2008
    hi, bad luck buddy, they r out. see if u can get it re-coned from a speaker repair shop, some tweeters can be recoiled, depends what type of coil u have??or new ones buddy..
How to hook up Panasonic SB PM19 speakers to SA-PM23 reciever
yes you can. these are called "bi wired" speakers which means there's a hook up for the woofer and the tweeter individually. If your amp have just 2 speaker hookups it's no problem to hook the woofer/tweeter wires of each speaker together. If your amp had 4 speaker hookups, you could put the tweeters in 1 and the woofers in the other but it will still work fine with 2 speaker hookups.
Mar 21, 2013 | Panasonic Audio Players & Recorders
My speakers stopped working
Heating of the power transistor
can be one of the causes.
you may have to take out the complimentary pairs to check.
The pair may take out the drivers and some components along with it.
These may take some time, (troubleshooting)
But have a tech to guide you, if you need to DIY.
Good luck, let us know what you find or needs further assistance.
Oct 02, 2012 | Samson SX1200 Amplifier
I have a pair of acoustic solution powerforce 2000 speakers and i need a replacement tweeter and cannot find one anywhere and want to know where i can purchase one
I think this seller would be a good bet on sourcing the tweeter
this might be the actual device you are after
Jun 24, 2011 | Audio Players & Recorders
Blown tweeters on pair of The Amazing Alphas
check on radio shack maybe there got something that fits your necesities
Feb 06, 2010 | Audio Players & Recorders
Can't find specs/maker of klh 900b tweeter
KLH 900B tweeter specifications: 6 ohm, 40 watts. By the way, KLH's QC for speakers could be improved. One of my 900B tweeters quit because the spacing for the voice coil was way off reasonable tolerance and the body of the speaker coil base pillar (ie: magnitized part) was off-center - and cauesd the coil to ware and short. I contacted KLH but they did not respond.
Sep 19, 2009 | KLH 900B Main / Stereo Speaker
2002 Grand am gt monsoon, hook up rear aftermarket speakers
You have to test them, either should work fine (as in use either pair) if that doesn't work connect one pair at a time and listen for the difference, one pair might be for factory midrange and other for tweeter.. there are two different wiring configurations...
Jan 28, 2009 | 2002 Pontiac Grand Am
Tweeters & Midrange Speakers
If you have a Ohm Meter, check the resistance to the speakers. If it is very high, the speakers are burned, (or the crossover is (just capacitors, and If it is close to 4 ohms check the wiring and and at the speakers, most likly the receiver/amp is not blown.
Apr 20, 2008 | KLH 1230SB Main / Stereo Speaker
Hi oddone
You may have a problem with either blown tweeters, or a faulty cross over, or both. If you have a multimeter, you can remove the tweeter, and check it DC resistance. They normally have their impedance marked on the back of the magnet. If not, you can assume they should measure 8 ohms. If they measure open circuit (high resistance), then they have failed.
A good speaker repair guy can often fix an open circuit tweeter as they often break where the very fine wires attach from the voice coil to the terminal. you can take a turn of the voice coil and reterminate to solve this problem. If the voice coils are burnt, they will need to be replaced.
If the tweeter meters ok, then you may have a problem with the crossover capacitors going dry. Generally they are 2.2uf to 6.8uf in value, the smallest cap in the crossover. If the plastic coating on them is split, or they look a different colour to the rest of the caps, replace them, if they sound "hollow" replace em, if you are not sure, replace em. other than that there is not alot more to look for with a speaker box tweeter Good luck and happy listening.
If you have any dramas, get back to me here and we can talk more about it.
Mar 16, 2008 | Audio Players & Recorders
KLH HT-9930 System Logo
751 people viewed this question
Top KLH Audio Players & Recorders Experts
Vito Vacirca Jr.
Are you a KLH Audio Player and Recorder Expert? Answer questions, earn points and help others
