Agitater is broken don't know how to take it off don't know how to tkae off the agitater
  • 4,102 Answers
Are you talking about the ones that are screwed into the back of the machine to stop the drum moving during transport if you are and the head is broken the only chance you have of removing is with a tap and die set as their is no way of getting to the thread to drill it out.
You can buy tap and die set from hardware store this is the only chance you have of removing it without taking the whole machine apart and i mean you will have to strip it completely to remove it but the tap and die set should remove it for you just dont buy a really cheap one as this will probably just snap aswell as they are tight to undo anyway even without a broken head let me know how you get on and if you need further help
Posted on Jan 11, 2008
    President:
  • 1,314 Answers
What brand is it ill advise dont rate me till were done
The Hot Point washing machine has stopped agitating but does spin-what is wrong?
The most usualthing wrong when the Hotpoint brand washer doesn't agaitate is a stripped agitater coupler,i don't see a model number in your question so i don't know if yours uses that coupler but its by far the leading thing wrong with that problem.
This youtube video will show ya how to replace that coupler,watch it and take off your agitator to see if that's the problem. http://www.youtube.com/watch?v=N26MCQKuXn0
GENE
Oct 13, 2011 | Hotpoint Washing Machines
The agitatae doesn't seem to be cycling the
The agitator is made in two parts. Upper and lower. The bottom part does the actual agitating.
The upper part is supposed to be loosely fitted. It just screws down the clothes to contact
the bottom agitator slowly.
The top part turns one way, and slips the other way. By the action of what is called "Dogs" inside
the top part. These dogs are probably worn and need to be replaced
Take the top off the agitator and there is one bolt in the middle of the agitator. use a long extension
to reach the bolt and remove it.
Pull off top agitator (keep it straight up so you don't lose the dogs_
Go to local Appliance store and ask for Agitator Dogs.
Replace Dogs exactly as they came out
When you re-assemble the top it will be loose. This is normal.
Good Luck!
Thank you for using fixya
Leo Ponder
Please rate me if this helped.
Jul 24, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
How to clean the screen under the agitater
Pull the fabric softener dispenser off the agitator, reach down and pull off the white cover (has 2 ears on it), then remove the bolt holding the agitator to the shaft. It then lifts off.
Jan 28, 2010 | Whirlpool LSR7333 Top Load Washer
My ge washer wpre6100g clicks during agitation part of cycle...
sounds like the agitater drive is stripped its a plastic piece under tha agitater you just grab the agitater work your fingers under the edges and **** up on it and it snaps off then remove the 5/16 screw put a new block on and snap the agitater back on
Jan 29, 2009 | GE Profile WPRE6100G Top Load Washer
Kenmore washer won't agitate,drain or spin.
What you have here is a broken drive coupling
the part looks like this:
To fix it CLICK HERE
Dec 29, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 4025090 washer spins but will not agatate
problem solved ,agitater dogs were broken up inside the agitater hub replaced these and works fine now ,
Dec 10, 2008 | Maytag Atlantis MAV6260AWW Top Load Washer
Estate top load washer
it you pop the top on the agitater you will see 4 gears called dogs, remove the 7/16 bolt upll the top half of agitater out and replace the dogs,you can get them at your local appliance part store,let me know how you do-mike
Oct 27, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Locks while agitating maytag a 208
its either the transmission itself or the upper bearing. most often its the transmission
Nov 20, 2007 | Maytag Neptune FAV6800AW Top Load Washer
Grandma's nylons wrapped around the bottom of the agitater
now you need to pull upward firmly but hard.  there are small splines holding the agitator in position. carefull if the agitator has two parts to it as there are usually plastic (dogs)inside which could spring loose if you are not careful.
Oct 24, 2007 | Washing Machines
Washing Machines Logo
51 people viewed this question
Top Washing Machines Experts
