Question about CTX PV 720 17" LCD Monitor
Green light comes on screen would come on after 10 min warmup now nothing.
I have pulled the screen apart and found that heating the high voltage board with a hair drier will allow the unit to come on after about 20 seconds. Previously supplying signal to the monitor for about 10-20 minutes and cycling the power would fix it. Is the indicitive of a bad capacitor or something simple that I could change out on the board?
3 Suggested Answers
6ya staff
SOURCE:
Fix-4U
Cj T
  • 293 Answers
SOURCE: ctx pv 720 lcd monitor backlight drops post plus 30 seconds!
Hi...there,
The problems on the backlight inverter power supply. Open it up and check all the capacitors, it look like a tiny battery cap on the side had writing on it. (Example 1000uf 16v ) if you are lucky you can spot it right away...with a bulged on top of each caps. If not, just replaced all of the caps... Good luck!
Posted on Dec 07, 2008
xanderp
Paul Phillips
  • 6 Answers
SOURCE: My monitor appears to have died. It seems to flicker on once every two seconds, just long enough to see there is indeed something displayed. Is there something simple i can do to fix this or should I
This series of monitor has a bad habit of destroying it's capacitors. I have fixed two S762G monitors (almost the same as a S761) by replacing 2 bulged capacitors on the motherboard with new ones. They cost me 50 cents each (plus shipping of like 3 bucks) from digikey.com. Didn't carry them at my local Radio Shack, but they did have them on the shelf at my local Fry's. (about the same price as digkey if you include the shipping costs.)
I would look for any capacitors on the mainboard that have their aluminum disc top bulged up. That's a sure sign of a blown capacitor. Anyone with good soldering skills can replace those for you. (making sure to put them in the right direction for their polarity, and getting the correct rating/voltage/temp) The two caps I had to replace on my S762G's were C21 and C22 and they were both 1000uF 16v 105c high temp radial electrolytic capacitors. Make sure you get the exact same specs for your replacements as from your originals.
The typical symptom of the blown capacitor on this monitor is that it will power on a few seconds, showing the screen properly, then make a slight pop and the power light will go off, then it will come back on again, and do it over and over. Sometimes they will "Warm up" after a while and stay on, but that will only work for a short time (typically under a month or two). After that, the capacitors will be fried and need replaced anyway. Best to fix them right away, to prevent possible damage to other components.
The difference between this symptom and a typical inverter board failure is that the monitor will power cycle repeatedly. Inverter failures usually show up as the backlight only turning on for a second or two showing a good display, then going off and staying off until the monitor is manually power cycled, and if you look really carefully under good lighting you can still make out the display with the backlight dead.
Hope this helps someone...
Xanderphillips
Posted on Dec 13, 2008
My Gateway ZX4300 screen is not working. The screen does not turn on at all but the fan is working and the hard drive is as well.
gateway zx4300 black screen fix
i think i might have found a fix, if you know how to fix the xbox with the fan trick this one will sound close to the same.
if when you turn the computer an you get nothing not one bit of color or brightness from the screen this is your fix, well it worked for me.
i am not responsible for any more damage you might encounter, this does require disassembly
1. take the computer apart until you have the fan and heat sink in front of you.
2. remove fan and heat sink from mother board.
3. (at own risk) with computer open an heat sink off plug in the power cord and turn the computer on.
4. leave computer on for 8 to 10 mins.
5. turn computer off after 10 mins remove power cord and re install heat sink and fan.
6. hold pwr button down for 15 sec.
7. plug computer back in and you should now have your screen back.
this method worked for me i am using the computer with the bad screen to type this up an has been restarted a couple times an is still working fine! hope this works for you!!
Aug 11, 2011 | Gateway One ZX4300-41 (PWGAW02017) 20 in....
Have sound but no picture on plasma green light is
check out for high voltage regulators near picture board. need servicing resoldering the whle unit and heated area..try it
Oct 27, 2009 | Panasonic Viera TH-50PZ80U Plasma TV
Charging light not coming on
I had the same problem, took the thing apart and checked voltages with a multi meter the battery voltage was 1.5 volts checked all connections nothing wrong put it back together" no go" held the reset button for over a minute, lovely green flashing light! hope it works for you
Jul 03, 2009 | Navman PiN 570 GPS Receiver
Push on button and green light comes on then goes off in 10 sec
my tv been in my storage for about two years i pull it out pluged it in and only the green light on the button comes on you can hear it make a noise like the screen is about to come on but nothing.then the green light shuts off. please if anyone know what the problem is please e mail me.
shadowbowl71
Mar 17, 2009 | RCA HD52W59 HDTV Projection Television
ViewSonic NextVision N4060w 40 in. LCD TV, will not turn on.
While this isnt an exact fix at work, you will at least be able to view your tv. We have one at work that would do nothing when you hit the power on button, just the usual geen led flashing. We pulled the cover off and found the bulging caps, more than likely from brown outs. But we also found that none were holding a charge. So we held the power button on for at least five min, after the led would stay on for about 30 sec and then turn off. We kept hitting the power button and the screen would try to come on. It finally did. After it did come one we can power on and power off aslong as we dont turn it off for more than 10 min. After 10 min of it being off we have hold down power button again and start the whole process again. So the main problem i believe is the caps arent holding a charge, to be able to kick the high voltage circuit on. We did not replace any caps but if we do end up changing parts will post what was changed and cost. Hope this helps
Nov 04, 2008 | ViewSonic NextVision N4060w 40 in. LCD...
Light
I don't know Samsung's warranty policy for Australia so I'd email them right away. It could be an input voltage problem. It could be heating up components in your equipment causing it to shut down and reset when it cools off. As the green light is not even coming on may be an indiction of this. So I'm guessing you are currently shortening the life of your equipment. Rich
Sep 20, 2008 | Samsung SyncMaster 910MP 19" LCD Monitor
No video on a 50H82 Toshiba Projection
If the screen is lit, then there is high voltage. If there is no video, and the screen is lit, then there is a loss of video. The fault can be anywhere along the main video path before it gets decoded in to the red, blue, and green compositions.
If the screen is not lit, most likely there is a high voltage failure, or there is a failure in the bias supply for the tubes.
When there is a loss of high voltage, this can be from any of the components in the high voltage area. Some of the main things that go defective are the flyback, high voltage multiplier, and various other small components.
Have you considered to replace the set with a good Plama or LCD set? This repair may end up being on the expensive side.
Jerry G.
Mar 10, 2008 | Toshiba 50H82 50" Rear Projection...
Hitachi 46UX50B high voltage transformer issue
Hello Bour,Its not too Bad,You gonna need a Couple of Things,Solder Wick,And a Soldering Gun,As you Pull ooff the Back of the Set.Youll find Probley 8 Screws Holding the Deflection Module(that will be the One with The High Voltage Tranformer on it(IHVT)You will have to look good on the board for all screws.....The Red lead tha come out of the IHVT Push down and Turn it should Come loose,The follow the g2 Lead to a Screen focus Bluck and pull on it it will come loose from it Note wher this lead came from,Once you have the Board loose,Turn it over and Put the Solder wick on the Connections and apply Heat,Solder will be sucked up by the Wick and you do this with each Conn,Till the IHVT is Loose(Note)Solderwick is available at Radioshack,Hope this Helps Perry
Jun 20, 2007 | Hitachi 46UX50B 46" Rear Projection...
No heating
Most likly the High Voltage diode or capcitor is bad.
Sep 22, 2006 | LG LRM1250 Microwave Oven
CTX PV 720 17" LCD Monitor Logo
83 people viewed this question
Top CTX Computers & Internet Experts
Jerry Greenberg
Jerry Greenberg
Marvin
Marvin
Damen Wong
Damen Wong
Are you a CTX Computer and Internet Expert? Answer questions, earn points and help others
