Question about Maxtor Hard Drive
Cant install xp on my maxtor SATA 6V160E0 UDMA6
HAVE PROBLEMS INSTALLING XP ON MYN HDD, AFTER BEING ATTACKED BY A VIRUS (WILPOLO). BIOS CAN IDENTIFY IT, BUT DURINH INSTALLATION, XP FINDS NO HARD DISK .
  • 102 Answers
*If you have access to another computer with a cd burner*
One way is to download the universal boot cd, boot a linux rescue disk image from it and use fdisk to remove all partitions.
This way the disk will be seen by windows setup again.
This is a silly bug in windows setup i've discovered a long time ago. When it does not understand the partitions on a disc it just hangs during the setup screen.
Download the iso image from http://www.ultimatebootcd.com/download.html then burn the iso image to a blank cd. Put it in your dead machine's cd drive and boot from it. Then choose one of the linux boot options.
When linux is up and running type fdisk ENTER
Then press p and a list of partitions comes up
Press d (delete) and then the number you see after /dev/hda etc.
Do this for every partition you see listed or just for
the first if there is data on the second/third/etc..
Press w (write) q (quit) and reboot with the windows cd in place.
p.s. This does irreversably remove
partitions and data on the disk!
Posted on Jan 11, 2008
Compaq Mini 700EL hdd not recognised
If you are installing Windows XP then -
The problem is that XP installation CD does not have a SATA driver, unless you have a SATA drive on a disk etc. and can install the driver when XP asks for a hard drive driver then, XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS and disable the SATA drive (enable IDE emulation), this will make XP think it is a IDE/PATA hard disk. Then you can install XP normally. When Windows has been installed then install all the device drivers (including the SATA driver), then shut down and boot up and got into the BIOS and enable the SATA drive.
Oct 08, 2012 | Computers & Internet
My HDD got infected with a virus nd I use theCD Mini PE to ormt the partion.When I placed the XP cd in the CD rom for installation of a new XP I got the message missing MTLRD files and the CD does not...
enter the bios and set the cd drive as the first boot device.
bios is usually f1, f10 or delete imediately as the computer starts up, while its on the brand logo screen, befopre windows attempts to load.
Mar 09, 2011 | Smartdisk - Peripherals - HARD DRIVE,...
Displays no hard drive found wen installing win xp
You have to go to BIOS setup, find HDD setup, and change the value to the other one (there are only two possibilities). That will fix your problem. The problem is caused by the fact that the lap top was designed for vista, not XP. and the lap top contains SATA HDD. when installing XP pre-installation doesn't have SATA drivers, so your OS can not see the HDD. Change it in BIOS, and you trouble is gone
Nov 14, 2009 | Toshiba Satellite A200-19501F Notebook
My hdd does not get detected
I too had a similar problem with my laptop. My laptop had a virus attack and somehow I managed to remove all the viruses. However there was one persistent problem which was while booting, My documents used to open automatically. Hence I wanted to repair the Windows XP SP2 and so I went to BIOS and changed the settings to boot from CDROM. While booting the installation CD from CDROM, suddenly I get a message: Hard disk not found! This was nightmare. Then I got this solution:
My laptop was new and the HDD was connected to motherboard with SATA, and we need SATA drivers before installing OS. In the likely event of not getting this driver, we could still solve this problem by confusing the computer. Go to BIOS settings and change the SATA to IDE or any other. Then restart the computer. The HDD now can be seen and you can repair or reinstall the Windows XP SP2.
Aug 12, 2009 | Seagate Barracuda 7200.7 40 GB Hard Drive
Installing xp on vista
I experienced that many many times, installed xp on vista based laptop is not a problem at all... I think it;s just an XP cd's, and it may absolutely contain virus...you can try another booting CD, or disabling antivirus at the bios first.
Jun 07, 2009 | Microsoft Windows XP Professional for PC
Acer aspire 5310 : did not find any hard disk while xp set up
Try with another fresh XP disc. Check your Bios if it shows hard disc. If bios show the HDD than its problem with your installation CD. If bios does not show HDD than check your HDD power and IDE cable. Replace IDE cable to diognose. If this does not solve, replace HDD.
Feb 23, 2009 | Microsoft Windows 2000 Professional for PC
I am facing Problem installing Windows XP with Asus P5RD1-VM series mothboard with SATA Hard drive. My harddrive doesn't get detected while installing Windows XP. While going for coping files for...
I would go into the BIOS and make sure your SATA controller is using the AHCI or IDE setting and not RAID, if it is using RAID then it may need to load a special driver to install windows.
This is the most likely cause of your problem, can you also check and make sure the bios is seeing the HDD at all?
Jan 21, 2009 | Microsoft Windows XP Professional With...
Cannot find hard drive while installing MS XP on a hp nc6220 laptop.
hi
It used to happen like this during the new installation.
goto BIOS setup and check that the HDD is correctely detected. check the size it reported. If its correct, give one more try. else the HDD firmware is corrupted and can be repaired.
thank you
Aug 15, 2008 | Microsoft Windows XP Professional for PC
Problems Installing my 160 GB Seagate SATA HDD
Check the SATA/RAID controller setting. It could have been set to [Disabled] Refer to your user?s manual for a detailed description on how to enable the onboard SATA/RAID controller by adjusting the jumper or BIOS settings. Regards SparkGap
Sep 24, 2007 | ASUS P5RD1-VM Motherboard
Windows Installation gives blue screen errors.
Hi, at the boot up go into your bios [ on MSI press the delte key continuosly] and turn OFF the onboard virus protection. This can block all O/S from loading as they need to write to the bios in the installation process. Ensure you turn it back on after installation, it is there to stop hackers getting into your bios and wrecking your system. Regards mistyman
Sep 04, 2007 | MSI K8MM-V Motherboard
Maxtor Hard Drive Logo
138 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
Phillip Whisenant
Phillip Whisenant
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
