Question about Motorola Mobility RAZR V3
Razr display goes dark
I got a new razr v3a & the display turns off. I turned off the battery power save feature & set all the settings so that it would always be on. It still goes dark. Is there a way to fix this?
Thanks.
I have just got that and I think it happened during the night they changed the time back to winter time. It might be a bug. Everything goes dark but the little front display LCD still shows data.
Anyway, don't reset it by removing the battery. II did five times and it didn't clear the problem. Instead turned it of using the red OFF button. Wait for 10 sec and turn it on using the same button. Everything came on as normal.
Posted on Nov 03, 2009
    Problem Solver:
  • 11 Answers
Yes i think that in the phone you go to option menu in menu settings in setting displays is the option there you have the option to either turn off the display or choose the interval like 1 minute or 2 minute.
Posted on Jan 12, 2008
THE CAMERA GOES DEAD VERY SOON WHEN IT TURNS ON. IT HAS GOOD BATTERIES.
Hi, I've scoured the 3 page manual and come up with this.:-
There is nothing wrong with your camera. The camera has a built-in power saving
feature that turns the camera off after 30 seconds of inactivity (default setting) to
conserve battery power. The auto off time setting can be changed in the set up menu.
Changing the Auto Off Time Setting:
1. Set the camera to Camera Mode.
2. Press the Menu button to display the main menu.
3. Press until the Setup is highlighted.
4. Press to enter the Setup submenu.
5. In the Setup menu, press to highlight “Auto Off Time”.
6. Press to enter “Auto Off Time”. Press to highlight the time you want.
7. Press the OK button to save your selection.
Hope this helps
Mar 05, 2010 | Concord Camera Eye-Q 4060AF Digital Camera
I have a Motrola Razr V3a. Occasionaly the screen
there is a problem in the power strip of your phone take it to any of the servicing centres of motorola and get it fixed
Nov 15, 2009 | Motorola Mobility RAZR V3
No display machine goes into Power Save Mode
Not much to go on here.
I assume you mean the machine goes into power save mode and you can't get it back out again?
There are power mode setting in control panel.
You might need to turn it off so the power save feature is not activated.
There are also power save setting in the BIOS settings.
Again you may need to disable it or try different settings.
Sep 20, 2009 | AcerPower 2000-UD431C - Core 2 Duo E4300...
Motorola Razr V3a Backlight Stays On
From the manual, p. 31:
"BACKLIGHT
Set the amount of time that the display and
keypad backlights stay on, or turn off backlights
to extend battery life.
Find it: (on menu) > Settings > Initial Setup > Backlight"
Jun 22, 2009 | Motorola Mobility RAZR V3
Cant send pics with my motorola v3a
Hi you will need to set up GPRS and MMS settings on your phone. If your phone already connects to wap internet then all you need is to adjust MMS setting (found in messaging section / mms settings). Speak to your network operator as they should be able to send setting over the air and when you receive just save and it is done. If after this it still does not work ask your provider to make sure your provisioned for GPRS as some older accounts may not have it enabled. Being its a Motorola I recommend getting over the air settings...its easier.
Found this on Motorola site...
https://motorolasetup.tarsin.com/home.htm?locale=en_GB&country=GB
Your model is not listed but if you change the sites region to yours, as I expect your not in UK, you should find it under mobile/support/settings mms,gprs. Hope that helps?
Mar 13, 2009 | Motorola Mobility RAZR V3a Cellular Phone
E153fp goes dark into power save mode after Windows start up
may be your power saving option have small time .
check in control panel power option check power shemes.set it to 20 minutes.
Nov 27, 2008 | Dell E153FP 15" LCD Monitor
X205-S9359 Display going dark
while on battery right click on the desktop and then properties check your power saving options you may have a wrong setting for how it should behave on mains power... could have accidently set it to turn off display to save energy
Oct 20, 2008 | Toshiba Satellite X205-S9349 Notebook
My psp has no image but it has sound
Dude, I had the same problem, the screen everything works fine when I use the TV out,
Check it out and tell me. I already call Sony and they will replace it with a new one, I recommend you call them if you still your warranty and your receipt.
or'
If the LCD screen suddenly turns dark
  • Check the Backlight Auto-Off setting
    If the Backlight Auto-Off setting is turned ON, the backlight will turn off after a set period of time. Press any button to turn the screen back on.
    To check the Backlight Auto-Off setting:
    1. From the XMB™ menu, go to icn_settings.gif (Settings) > [Power Settings] and press the icn_btnx_color.gif button.
    2. Highlight [Backlight Auto-Off] and press the icn_btnx_color.gif button.
    3. Select a time interval and press the icn_btnx_color.gif button to save. Select OFF if you wish to disable this feature.
  • Check the Auto Sleep setting
    If the Auto Sleep setting is turned ON, the screen will turn dark after a set period of time. Press any button to turn the screen back on.
    To check the Auto Sleep setting:
    2. Highlight [Auto Sleep] and press the icn_btnx_color.gif button.
  • Check the Display Button
    Check the Display button on the front of the PSP system. Pressing the Display button (located to the right of the PSP logo on the bottom front) will cycle through the brightness settings of the LCD screen.
    The brightness setting can only be used when the PSP system is plugged into an electrical outlet with an AC adaptor.
Aug 15, 2008 | Video Game Consoles & Games
Key pad light
Sounds like you have the "Battery Save" feature set to "ON". Go into settings and set the "Battery Save" feature to OFF.
Good luck.
- Jim
Jan 28, 2008 | Motorola Mobility RAZR V3
My new Razar V3a makes buzzing sound
If the buzzing is coming from the keyboard then it's a known problem/feature. Got the same on mine when the keypad is lit up, so rag Motorola, who said sorry, known feature with that model.
Aug 29, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
131 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
