Question about Sony PlayStation 2 (PS2) Console
Removing old parental lock out codes on used ps2
My ps2 will not play dvd movies . i bought a used one and do not know the passwords to change this function in order to play movies. what do i do?
  • 6 more comments
  • mijoz2000 Jan 12, 2008
    I have the same problem.
  • 92m30 Jan 13, 2008
    got the same prob
  • akroma Apr 12, 2008
    can't remove old parent lock.
  • Anonymous May 28, 2008
    i brut my ps2 brand new iv had it for 2 years . put a dvd in it today and it asked for the parental lock code im 27 years old i don't need that . its pissing me off how do i fix it
  • Anonymous Aug 02, 2008
    can not take parental lock on my ps2
  • Anonymous Sep 04, 2008
    parental codes
  • millerd303 Oct 29, 2008
    i bought a used one and they dint tell me the parental code
  • mill6945
    mill6945 Jan 24, 2012
    help i getten this ps2 at a yard seal i cant play r rate onit how i fix it
    Genius:
  • 1,003 Answers
Here is the answer to your prayers http://www.techlore.com/article/10505/
Posted on Jan 13, 2008
6ya staff
SOURCE:
When I put a dvd in the sony playstion 2 slim it says (This movie will not play due to the parental setting of the player) how do I remove parental restrictions for dvd's & cd's Thanks
In settings there is the parental lock code. If Bought Brand new, then the defaut password is usually 1234, so give that a try. After which you can set it to the most allowing setting, which i believe is 8 and then any movie shoud play. However if you have set a password then you either need to reset it with a PS2 format disc.
Please Rate
Sep 05, 2011 | Sony PlayStation 2 Slimline Console
There was a parental lock code on our ps2 when we got it, is there a override code I can use to unlock it? I bought it at a yard sale last summer and they never mentioned that they put a lock on the DVD......
Try these directions, they *should* work.
1. Insert a DVD Movie into the PlayStation®2.
2. You should receive a message informing you that the Parental Level has been set, and asking if you?"d like to allow the disc to play. Highlight "Yes" and then press the X button.
3. A new window will appear asking you to temporarily change the Parental Control to a different level. Again, highlight "Yes", and then press the X button.
4. Another window will appear asking you to enter your Password. Above that window are numbers (0-9).
5. Do not enter your password, but instead, press the select button on your Controller. This will change the text in the window from "Enter Password" to "Delete Password".
6. Using the numbers above the window, input 7444. If successful, you will receive a message stating "Deletion Complete".
7. Press Select. You will now be asked to register a new password. Please select a four-digit code of your choosing.
8. You will be asked to confirm your password selection by inputting the same code once again. If successful, you will receive a message stating "Registration Confirmed".
9. Now you need to turn off the password altogether. The movie should of started playing by now. Press select and chose Setup. Go to the parental control "tab" and set the level to "off".
10. Now you should be able to watch any movie
Apr 05, 2011 | Sony PlayStation 2 (PS2) Console
Need to reset code
Found this on another site, from personal experience but its very well written so here you go.
The Playstation 2 is not only a video game system, but also a DVD player as well. In many families, the Playstation 2 serves as the "kids" DVD player, which means that many parents choose to take advantage of the parental lock feature to limit what kinds of movies the Playstation 2 will play back.
There could be instances where you entered in a parental code months ago, and now can't remember it. Or, you may have purchased a used Playstation 2, and you never knew the code to begin with. If you or the prior owner set a parental lock code, the Playstation 2 won't play back many movies without entering the code first. You could try to hunt down the original owners, or start inputting every code possible starting with 0000, but it's easier to reset the password and disable parental lock using a secret code.
Here is the procedure to reset the parental lock code:
  1. Bring up a screen where the unit asks you to enter in the parental code. You can either insert a restricted disc, or enter the DVD setup menu and go to "parental control" under custom setup.
  2. When the screen asks for the code, press the SELECT button, then enter in the code "7444".
  3. The level adjustment under Parental Control dictates the strictness of the player. The lower the value, the more strict it will be. Either increase the value to lower the restriction, or disable the lock entirely by setting it to "off".
  4. Once you have made your adjustments, be sure that the DVD tray is empty, and press the RESET button on the front of the Playstation 2. It is imperative the tray is clear of any DVD or game for the unit to save your settings.
A note for parents: If you're wondering what is stopping your child from using the above procedure to circumvent your rules, you can verify that they haven't reset the parental control very easily. Since the above procedure eliminates the old password entirely, all you need to do is see if your original password still works. If it does, they did not use the above procedure to break the rules. If it doesn't, they might be trying to pull the wool over your eyes.
Please rate accordingly
Justin
Jul 28, 2010 | Sony PlayStation 2 (PS2) Console
Parental password?
Jun 06, 2008 | Sony PlayStation 2 (PS2) Console
Over ride the parental control level
Ok first try 0 1 2 3 because that is the preset code for the ps2 or if that dont work insert any dvd movie, go to setup and access the parental control settings(press select) When asked for your code enter "7444"; It will prompt you again to type in your password. Type "0000" and then scroll down to the movie rating options and choose "off". Hope it helps you out!
Apr 10, 2008 | Sony PlayStation 2 (PS2) Console
PS2 PARENTAL CONTROL CODE
This is the only way to turn "off" parental control lock on the custom setup screen.
1) turn off ps2 with no dvd in drive.
2) turn on ps2 and insert dvd in drive.
3) when it asks about parental password, choose 'yes'.
4) when prompted for password, press 'select'.
5) the prompt will change and say 'delete password'. enter '7444'.
6) enter a new password (0000 works).
7) registration complete, dvd will start playing.
8) once the movie starts, press 'select'.
9) click the 'stop' icon.
10) click the 'stop' icon again (the icon must be gray even when you have it highlighted).
11) navigate to 'custom setup' ('select', setup icon, custom setup icon)
12) move to parental control option, press right directional button, enter password (0000).
13) move down to 'level'.
14) move up to desired level (off is at the top).
15) click 'x'.
16) go back to 'select' menu options, and press 'play'.
17) while movie is playing, eject disk and remove dvd.
18) turn ps2 off using switch on the back, keep off for five seconds.
19) turn on ps2, put dvd back in.
20) happy dance. ;)
Dec 25, 2007 | Sony PlayStation 2 (PS2) Console
Video Game Console
Start a DVD, then stop playback. Clear "resume play" (press stop twice), goto the Control Panel, the select SETUP, then ADVANCED SETUP. Select PARENTAL CONTROL, then press Select. Enter the number 7444.the old password is clear, now you can set a new one and change the rating.
Dec 23, 2007 | Sony PlayStation 2 (PS2) Console
Changing parental control
Start the PS2 up and load the DVD. When it shows the Parental screen select YES. When the Password box pops up. Press the Select button on the controller. Type in 7444. Then your password is reset. It will ask you to enter another password. Do that twice. Allow the movie to start. When it gets going pause the movie, Press the Select button on your controller again. The DVD menu pops up. highlight SETUP. When that setup screen appears go to the 3rd icon from the left. Press X. Then highlight Parental Code. Set the parental lockout level to OFF.
Nov 20, 2007 | Sony PlayStation 2 (PS2) Console
Parental codes
Put a DVD into the PS2 and let it try to load. When the screen says chenge to level four select yes. When the entry window pops up,press the select button on the controller. It should say reset password or something like that. Put in 7444. Then when you rename the password put in 0000. You will have to do it again 0000.
Once the movie starts, not the menu screen, but the movie actually playing, Press Select button again. The PS2 DVD menu should appear. Cursor over to the toolbox or Setup, and press X. Cursor over to the third icon, and press X. Arrow down to PArental and press X. Change the Parental lockout to OFF.
I am not completely sure about the procedure here but the numbers are correct.
Nov 11, 2007 | Sony PlayStation 2 (PS2) Console
Lost my password for ps2
Sony PlayStation 2 (PS2) Console Logo
433 people viewed this question
Top Sony Video Game Consoles & Games Experts
Ekse
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
