Question about GE WJSE3110A Top Load Washer
Loud cliunking noise in beginning of spin then won't spin
My washer make a loud clunking noise in the beginning of spin cycle, then it stops spinning. the belt moves slow and motor make the clunking, the tub stops spinning.
  • 4 more comments
  • harleycat Jan 11, 2008
    this seems to be a common problem for this machine. I would love to know how the others fixed the problem. There is nothing in there. I have found that there is a problem with the motors on these machines. But how do you tell if its the motor, the clutch, transmission, .............. Its the motor itself that clunking. I have it out and plugged back in on the floor, it jerks and clunks. so now the problem is the replacement motor doesnt wire up the same, (GE discountinued the original motor)
    it was easy. I took the motor out, plug the wires back in. and pushed the washer button to start a load, and it filled up and tried to spin. The blogs I was reading suggested transmission and clutch. And the motor replacement is a motor with a clutch assembly unit. And I was looking at the picture of the transmission unit, which isn't the problem. I'm guessing the board might need to be replaced, or the motor, but I don't know which one. they are both expensive. I love my washer, its only about 4 years old. DETAILED APPLIANCE ILLUSTRATION
    Washing Machine - Top Load GE Style wjse3110A0ww
  • Anonymous Mar 23, 2014
    Loud noise while spinning
  • Anonymous Mar 26, 2014
    Washer makes a loud noise when in the spin cycles
  • Anonymous Mar 30, 2014
    purchased on 2001
    model #23812100
  • Anonymous Apr 01, 2014
    washer wont spin
I have a wjse3110a0ww top loader. The problem is that it starts to go into the spin cycle and slowly begans to sezie. What could be the problem?
Posted on Jul 20, 2009
    President:
  • 1,314 Answers
Get a flashlight and see if a foreign object has fallen down through one of the tub holes and is jamming the tub you have to look real close
Posted on Jan 11, 2008
  • robert samples Jan 11, 2008
    well harleycat its a direct drive systems for one thing they don't have transmissions or clutches there are two motors one is ac one is dc both are produced by Frigidaire for ge im curious how you have the motor wired up with out the mcu or taco generator connected is it jumping and clunking on start up or all the time and in spin mode should reach 800 rpm ive check the factory service bulletins and at this time have found no problems reported with the motors but hang with us and well see if we can puzzle it out if need be ill contact ge technical and see what they say ok i consider this washer to be one of the best on the market have one myself for ten years now hang with us ill get an answer
    ooops sorry guys i thought we was dealing with a front loader boy is my face red sorry look harley go here and enter model number then continue on the next page on parts select select the system you want to see then continue when page comes up click select show diagram will give you a blue print of the system yes there is a tranny yes there is a clutch its my bad man ive dealt with too many in the past week i guess over 320 different appliances on site ill get back with you when i finish with the front loader heres the site http://www3.sears.com/
Whirlpool wtw5100sq0 clunks when put on spin cycle
Does the washer currently work fine aside from the loud clunking noise? Does the clunking noise continue or is it just one loud clunk when it starts to spin? If its just one loud clunk then that is not a problem just ignore it as that is the clutch spring releasing, it probably starting making noise from the grease getting washed off when the washer over filled.
However how did the washer overfill? That issue should be addressed too. Sometimes though, if the tub is not centered from a heavy load the water will spill over the back but its not really an overfill.
Mar 25, 2013 | Washing Machines
Wash machine won't spin all the time and makes a loud banging noise.
Check to make sure that your clothes are not piled to one side causing the load to be off-balance. If that does'nt fix it then, It may be that your machine has a balance stabilizer on it that has worked its way loose or even off.
Jun 11, 2012 | Frigidaire Affinity ATF7000E Front Load...
Makes clunking noise when changing modes--does not spin dry
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 24, 2010 | Amana 3.2 cu. ft. Top-Load Washer
Clunking/thumping with spin cycle, reduces as spin speed increase
It's hard to tell without looking at the washer. But my first response would be that the transmission is wearing out. Inside the plastic cover for the adgitator is a metal drive stem. This assembly has a pulley on the bottom where your motor attaches to; inside the bottom of your washer. It is quite common after many years that these go bad. Have you ever noticed unexplained grease or other stains on your clothes after they came out of the wash?
Apr 22, 2010 | Maytag Washing Machines
Loud noise during spin cycle
what kinda noise, sqeeling, or clunking, mite be sumthing small that made its way behind ajatator an is causeing noise..or one of the springs that hold it broke..sorry i dont no what kind of noise.....
Jan 31, 2010 | Washing Machines
Washer won't agitate or spin out.
Well it is ethier Belt, Cluch ,motor ,Or transmission. But it does sound like your transmission . The loud clunk is the brake in the gear case ( Trans.). It might have broken off.
Apr 05, 2009 | GE WJSR2070B Top Load Washer
Spin cycle noise
pull up and down on your basket to see if it has up and down play in it
kind of rock it side by side too
Dec 30, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
"howling" noise during spin cycle (still there after changing burned off belt)
Travioso, there was two service flashes out on this model concerning the seal and bearing which means they had an issue with this washer. The howling noise you are hearing is the bearing and will need the new designed triple seal and bearing kit. This should be covered under your warranty, I believe it is 5 years. The numbers for the service flashes are TDL-0048A-B. Call Maytag and inquire about these service flashes, these should be covered. Catriver.
Jul 25, 2006 | Maytag SAV5701A Top Load Washer
GE WJSE3110A Top Load Washer Logo
1,053 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
