Question about PROimage PRO IMAGE 5" BLACK&WHITE TV W/RADIO BLAC Television
Flourescent picture on my television - PROimage PRO IMAGE 5" BLACK&WHITE TV W/RADIO BLAC Television
  • 70 Answers
This means picture is too bright. so the video output stage havinf a problem so pls check the video output transistor voltage it should around 75v if its lower than this may be a couse. check video driver stage as well
Posted on Jan 15, 2009
6ya staff
SOURCE:
How do I change a small flourescent light bulb
most flourescent light bulb are twist in and twist out
Sep 17, 2012 | Televison & Video
I have sound but no picture. Just pitch black
the back light inverters will need to be replaced.they produce the high voltage to fire up the flourescent tubes.
Apr 01, 2011 | LG Televison & Video
Low brightness
replace back light - it is a flourescent bulb which gets darker as it gets used ( like all flourescent bulbs do - they start getting black on ends and get dimmer as they are being used)
Mar 25, 2011 | Televison & Video
Sound only, no picture.
Most likely, the CCFL (cold cathode flourescent lamp) bulbs are bad or they are not getting power.
Your picture is probably there, but because the backlighting is out, you cannot see it.
If you still have a warranty, exchange the set. Otherwise, you can go to any good TV repair shop and they can fix it for you. Make sure you get an estimate first.
Feb 12, 2011 | Toshiba 42AV500U 42 in. LCD HDTV
We have sound and you can see the sound bar on screen but no picture
Open the back of the TV. Then turn it on. You should be able to see white light indicating the flourescent lamps are on. Don't touch anything tho because there are high voltages there. If the flourescent light dont come on then it is the board that powers it. If the white lights are on at the back then it is the main picture board. I may add though that the power supply that powers the flourescent lamp has higher failure rate.
Jun 26, 2010 | Televison & Video
PT-53TW53 53 in. Rear Projection has sound but no picture
It is. And I hope you some cash set aside for this extremely costly repair.
I once had a rear projection TV and was told by the repairman that each of the 3 flourescent lamps run about $200.00 to replace.
Needless to say I did not get it fixed
Oct 12, 2009 | Panasonic PT-53TW53 53" Rear Projection...
I have a 32" TV/DVD combo westinghouse LCD TV. When I turn the TV on I get no picture. There is sound. DVD player does not show picture either, I have sound but no picture.
This is a backlight or inverter Problem. Based on the model you have, I am guessing the inverter is defective.
Inverter is defined as the board in the TV that supplies power for the flourescent lights inside the LCD TV that provide backlighting for the TV's Display
Jun 22, 2009 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Screen flashes several times before picture comes on. Sound OK.
sounds like your bulb may be flickering at start similar to a flourescent, do a search on google for bulb+your model, and you should see plenty of sites to compare prices.
Hope this helps, please give a good rating
May 12, 2009 | Televison & Video
Flourescent Colors on my LCD
try adjusting brightness and sharpness! is this problem something new or has lcd always looked this away
Oct 26, 2008 | Panasonic TC-32LX60 32 in. LCD Television
Picture color
IHave a look under my solutions for this model... You need to have the convergence adjusted in the I2C menu..
Bill
Nov 20, 2007 | Hitachi 50V500 50 in. HD-Ready LCD...
Televison & Video Logo
Top PROimage Televison & Video Experts
Marvin
Marvin
Are you a PROimage Televison and Video Expert? Answer questions, earn points and help others
