Question about Mitsubishi VS-50605 50" Rear Projection Television
Mitsubishi vs-50605 TV can't turn on
Hi, my TV unable to turn on. I pressed the "on" button, it clicks and the "timer" button turns green and hear a shut down sound. The TV did not turn on. My son (10 years old) was playing video game on it before the TV was unabled to turn back on again. He told me that tv show that "minutes left" on the screen before the TV turns off. I check the fuse inside the TV is good. What do you think its the problem. Do you think its worth to fix it. Thanks Tom
  • 4,102 Answers
Hi your problem sounds like the power transformer as over heated and is shutting down to prevent further damage this is a common fault with this type of telly if you are unable to get the equipment needed and do the repair yourself then the cheapest option is for you to take the telly yourself to repair shop as calling someone out will charge call out charge and then they charge for transporting the telly from your home to the shop and back.
This fault is common and usually occures just after the warranty runs out it isnt to expensive to repair and is worth repairing just shop around and get the cheapest qoate you can.
Also if you do repair yourself remember you will need to check all resistors arround the transformer as this can cause the fault you describing but without having equipment to test the resistance then you wont no what to look for and might never find the fault let me know how you get on ok
Posted on Jan 11, 2008
    Genius:
  • 1,153 Answers
You need to try self test, this is when you press the Menu and Device/Input button on panel at same time for 5 seconds then release and you should see a 2 digit sequence. Blinks then short pause then more blinks, count them and then you will come up with the error code. If you have an error of 2-3 or 2-4 you need to replace C411 it's a 2200uf @ 35v and C412 10uf @ 50v both on main board!
I have a mitsubishi vs-50605 and when i turn it on the light comes on and clicks and the instantly clicks and shuts back off, I pushed the menu input buttons for five seconds and got one blink then two...
1,2 is no error detected---if during or before this you unplugged the set that clears the errors and you will get 1,2.
To confirm with set plugged in turn it on--when power light goes out repeat the self check.
May 15, 2012 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi Medallion does this
hi there,
Check for bad solder on convergence module. May have bad stk's. Do not neglect looking for bad solder on dsignal and defl boards. Mitsubishi is very prone to bad solder.
`jack
May 26, 2008 | Mitsubishi WS-55411 55" Rear Projection...
Mitsubishi vs-50609 green timer light comes on no
Unplug the tv and leave it unplugged for a couple hours. Plug tv back in press reset button. TV led may flash for a day but should come on. I did this last night to mine and it came on at 11am today.
Mar 29, 2010 | Mitsubishi VS-50609 50" Rear Projection...
No picture . tvturns, immediately turns off
Your TV set is in protect mode .To protect further damage of some component parts.There is something internal problem inside maybe there is a shorted.
Good luck;
Regards:
VOTIT
Jul 01, 2009 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi VS-50609 won't turn on
What a great tv this is Mitsubishi did a fine job making this one, but......only an authorized mitsubishi servicer should repair it. This set records diagnostic led codes that the technician receives to help determine where the problem might be, not the problem, but in which circuit it might be. The one thing to try is, unplug the tv , let it set for a minute, plug it back in , turn it on and hope it reset the micro. Next , call for mits. service.
Jun 11, 2009 | Mitsubishi VS-50609 50" Rear Projection...
Mitsubishi VS-5004R No Picture and No Audio
not enough power, you may need to rebuilt or replaced the power board
Mar 31, 2009 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi VS50605 rear projection TV won't come on
The power supply caps in the light engine power supply were faulty when they were installed. You need to remove the power supply and take it to your local electronics shop where they can remove the (7) faulty 1000uf 16v electrolytic capacitors and insert new ones. If you remove the power supply yourself (takes only a philips screwdriver) and reinstall it yourself, the electronics shop shouldn't charge you for more than an hour worth of time. The caps would be about $10.
Here's a photograph (thanks Don Crawford).
Nov 13, 2008 | Mitsubishi VS-50605 50" Rear Projection...
No picture no sound
Probably, the selftest fails while turning on. If this is the case, press input&menu buttons at the same time for 5 seconds, then the green led will start to blink. Let me know how many times the led blinks.
Regards
Mar 01, 2008 | Mitsubishi VS-50609 50" Rear Projection...
Mitsubishi VS-50605 - Colors separated
You have a convergence problem and need to reset
Nov 26, 2007 | Mitsubishi VS-50605 50" Rear Projection...
Timer light flashes 3 times
the code means that your tv power supply is not functioning your tv needs to be repaired call the tech.good luck
Apr 26, 2007 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi VS-50605 50" Rear Projection Television Logo
97 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
